What causes tweeter dents? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 01-20-2012, 12:51 PM - Thread Starter
Ericthemidget's Avatar
The tweeter on my 6 month old Def Tech 8040 center has two dents in it. I noticed an increased silibiance recently and low and behold, there were the dents.
What could cause this? My speakers are calibrated to 75dbs at -10 volume on my Denon 791 AVR and I have my receiver set to never go louder than -10.
Ericthemidget is offline
post #2 of 15 Old 01-20-2012, 12:55 PM
chashint's Avatar
Quoted: 18 Post(s)
Liked: 54
errrrr........ something / someone touched the driver.
Charlie
chashint is offline
post #3 of 15 Old 01-20-2012, 12:56 PM
Ron Alcasid's Avatar
fingers
Ron Alcasid is offline
post #4 of 15 Old 01-20-2012, 12:58 PM
pokekevin's Avatar
Liked: 102
kids.
pokekevin is offline
post #5 of 15 Old 01-20-2012, 01:01 PM
TheWind's Avatar
Liked: 30
Call CSI; have them dust for prints.
TheWind is offline
post #6 of 15 Old 01-20-2012, 01:25 PM
joeyvaz's Avatar
Quoted: 68 Post(s)
Liked: 29
Lmao
joeyvaz is offline
post #7 of 15 Old 01-20-2012, 01:27 PM
Phil Tomaskovic's Avatar
Quoted: 35 Post(s)
put a piece of tape on them and sometimes you can pop the dent back out
Phil Tomaskovic
Phil Tomaskovic is offline
post #8 of 15 Old 01-20-2012, 01:27 PM
cschang's Avatar
Quoted: 107 Post(s)
Liked: 164
I don't think the dents cause the sibilance though.
-curtis
Owner of Wavecrest Audio
Volunteer Mod at the Ascend Acoustics Forum
Like all things on the Internet, do your research, as forums have a good amount of misinformation.
Help beat breast cancer!
cschang is offline
post #9 of 15 Old 01-20-2012, 01:32 PM
Big Whitey's Avatar
Using tape can damage the tweeter if you are not careful.... so if you do it that way, be gentle.
Another thing to try is simply sucking with your mouth (keep it clean boys!) on the tweeter and see if you can pop it out. If you are not comfortable doing that you can try using a vacuum.
Depending on the dent it may not be the problem you are hearing however.
Going Deaf.... And Lovin' It
Big Whitey is offline
post #10 of 15 Old 01-20-2012, 01:42 PM
spork42's Avatar
Something poked it.
Unfortunately, it looks like the tweeter used in your speakers is aluminium and not a soft dome.
Like with most dome tweeters, you can try to gently pop the tweeter back out using tape which does not leave a residue. Unlike with soft dome tweeters, however, metal-based tweeters are not very resilient to dents in that even after you pop the tweeter back out there will still be slight, potentially barely perceptible, creases in the metal.
From past experience, I will tell you that it is impossible to return a partially dented metal tweeter to a perfect pre-accident state. This is not to say that the tweeter won't improve significantly after the "tape" repair, it very well may, but if you are like me, "close enough" may not satisfy you.
Before messing with the tweeter further, it may be worth it to contact Def Tech and ask them if they will send you a new tweeter. Dome tweeters generally aren't a very expensive part, and when I asked the same thing of Mirage when one of my tweeters was dented, they sent one out right away.
In the case of Mirage, they sent me the entire tweeter assembly, and the repair required nothing more than a hex wrench and ten minutes of my time.
Good luck!
spork42 is offline
post #11 of 15 Old 01-21-2012, 05:02 AM
buzzy_'s Avatar
Quoted: 66 Post(s)
Liked: 89
Bad advice for metal tweeters. Most of the time the result will be no better or worse.
buzzy_ is offline
post #12 of 15 Old 01-21-2012, 05:06 AM
buzzy_'s Avatar
Quoted: 66 Post(s)
Liked: 89
Originally Posted by spork42 View Post
Something poked it.
Good luck!
You're describing visible changes, not audible changes. Most of the time a dent alone won't be audible.
A dent alone shouldn't produce sibilance. Maybe there's some other damage, or maybe it's something else. Try listening to just the "good speakers". And try making sure it isn't something else in the room vibrating, or the grills, or something.
buzzy_ is offline
post #13 of 15 Old 01-21-2012, 05:26 AM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 521
It's a matter of taste, but if you were my friend I would gently suggest that this is a great excuse to get some better-sounding speakers.
The deaftech speakers all have a harshness to their treble that drives me up the wall; a sure recipe for listener fatigue, IMO.
Speakers that sound very good to many people include PSB, Monitor Audio, KEF and B & W. They have much better-sounding tweeters, plus outstanding overall performance.
If you really want to keep what you have you should get a new tweeter from the manufacturer and replace it; it cannot be repaired. There is no way to restore it to its original shape and rigidity once it has been deformed, which would be essential to restoring its original performance. Any thought of repair is nonsense.
commsysman is offline
post #14 of 15 Old 01-21-2012, 05:34 AM
tigerstripe's Avatar
pets, kids, your belts or your wife's ring could be the reasons for the dents. Since they are just 6 months old you may contact Def Tech to see if the damage is covered by warranty
tigerstripe is offline
post #15 of 15 Old 01-21-2012, 08:08 AM
Looneybomber's Avatar
Liked: 25
I'd be surprised. That's the same as hail damage on your car being covered under warranty.
BTW, my 18mo old decided to help daddy with the speaker daddy was working on. He dented the tweeter so bad he tore it (CMMD infinity tweeter).
YID DIY
Looneybomber is offline
Reply Speakers
