Watts to speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 23 Old 01-20-2012, 06:37 PM - Thread Starter
Mugenstylus1's Avatar
Here are the speakers I have
Front - Polk Audio A9's
Center - Polk Audio CSi A6
Rear - Polk Audio Rt/i A6's
I don't have a sub yet.
I was thinking about getting the Pioneer vsx-521-k
It's about 125w per channel. Should I get a different receiver or will I be good with this?
Mugenstylus1 is offline
post #2 of 23 Old 01-20-2012, 07:15 PM
crazyrob425's Avatar
Quoted: 443 Post(s)
Liked: 337
How much money do you have to spend on a receiver?
Those are great speakers and you are pairing them with a poor receiver IMHO and not good for your speakers
Don't look at the manufacturer specs cause they are generally aspirational and many of the companies test their wattage differently
crazyrob425 is offline
post #3 of 23 Old 01-21-2012, 12:11 AM
toofarzong's Avatar
Bingo and bingo. Look for a better quality AVR.
toofarzong is offline
post #4 of 23 Old 01-21-2012, 03:24 AM
commsysman's Avatar
Quoted: 973 Post(s)
Liked: 523
It seems extremely unlikely that the VSX-521 would be appropriate for those speakers.
That VSX-521 receiver is rated for 110w/channel with 2 channels driven, which might seem to be enough power for the front 2 speakers. That power rating is VERY misleading, however.
The problem is that when you look at reviews and actual power tests that Home Theater has run in the past on receivers in this very low price category, it turns out that with all 5 channels driven they will only put out 30 to 50 watts before distortion exceeds 1% (if that...).
That receiver probably has only about 250 watts TOTAL available to run all of the speakers, so divide it up among 5 channels...do the math.
When listening to movie sound tracks, the loud peaks will take that much peak power, so you probably will have a lot more distortion than you want to hear.
Denon receivers have shown in past Home Theater magazine tests that they will come much closer to delivering some actual power to 5 channels that is closer to their 2-channel power rating than most other brands. This is easy to verify by reading their reviews which have test results on the actual power.
Denon typically delivers 80% to 90% of their 2-channel power rating to all 5 channels, where other brands frequently deliver less than 50%.
The Denon AVR-3311CI would be a good choice for your speakers. It is rated for 125 watts per channel, and past test results would indicate that it can probably deliver AT LEAST 90 watts per channel with low distortion with 5 channels fully driven, which will do a much better job with your speakers.
This receiver sells for around $800, which seems reasonable for speakers which would seem to sell for twice that much.
The Denon AVR-2311CI is a bit less expensive and would also be suitable.
commsysman is offline
post #5 of 23 Old 01-21-2012, 07:35 AM - Thread Starter
thank you all. I'll just go with one of the elite. Thanks guys.
post #6 of 23 Old 01-21-2012, 07:52 AM
commsysman's Avatar
Quoted: 973 Post(s)
Liked: 523
The current 2011 Pioneer Elite VSX-53 or similar would be good, but beware of the 2012 models, which are going to have digital switching amplifiers. They have a reputation for poor sound quality (and reliability is unknown...).
post #7 of 23 Old 01-21-2012, 08:16 AM
Looneybomber's Avatar
Liked: 25
Are you talking about the fact they have an SMPS (Switch Mode Power Supply, does it have one?) or due to its specific new amp topology not being designed well?
YID DIY
Looneybomber is offline
post #8 of 23 Old 01-21-2012, 09:15 AM
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
I would personally spend a bit more than $200 on a receiver, but in no way do you have to spend $800 because you spent $1600 on speakers. There is no law of proportionality here. If you bought a receiver with all channels pre-outs (or at least the front three), then you would be free to add an external power amp later if the receiver wasn't enough in terms of power. The amp will last will decades whereas the receiver will be obsolete in 5 years.
Many people here have said that a 125 WPC receiver like that will only output 50 Watts max to the front three, and things like that. Okay, so what? 50 Watts might be enough for you anyway; it's only 4 dB less than 125W. The surrounds speakers are likely fed 10 dB less than the front three during a movie, so around 5W while the fronts if the peaks are getting peaks of 50W.
psgcdn is offline
post #9 of 23 Old 01-21-2012, 09:22 AM
joehonest's Avatar
Quoted: 90 Post(s)
Liked: 37
Onkyo AVRs have the most bang for the buck for amp output, 609 would be a good starting point...
joehonest is offline
post #10 of 23 Old 01-21-2012, 09:25 AM
ccotenj's Avatar
Liked: 101
the poster is incorrect... pioneer vsx models are class a/b amplifiers...
sc models are class d amplifiers... which have exhibited no issues...
- chris
ccotenj is offline
post #11 of 23 Old 01-21-2012, 09:32 AM
joehonest's Avatar
Quoted: 90 Post(s)
Liked: 37
Class D amplifiers are good for subs, but are they really good for full range speakers, sound wise... I know there very green and run cool. but sound wise..
post #12 of 23 Old 01-21-2012, 09:32 AM - Thread Starter
what about Pioneer VSX-1021-K or Yamaha RX-V671?
post #13 of 23 Old 01-21-2012, 09:36 AM
afrogt's Avatar
Quoted: 1056 Post(s)
Liked: 757
1021 isn't that powerful either, go with 1121 or higher end Elite models. The Onkyo NR709 would be a pretty good choice too.
Afro GT
afrogt is offline
post #14 of 23 Old 01-21-2012, 10:08 AM - Thread Starter
thanks i am looking at the 709 now.
post #15 of 23 Old 01-21-2012, 10:34 AM
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
Good choices! as would be the Harman Kardon AVR 2600 (except no pre-outs)
psgcdn is offline
post #16 of 23 Old 01-21-2012, 10:35 AM
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
But does he need the extra few dB for double the price?
psgcdn is offline
post #17 of 23 Old 01-21-2012, 10:52 AM
afrogt's Avatar
Liked: 757
It isn't double the price. 1121 is on sale for $449 at Newegg with promo code EMCNJJA37. Plus you get preamp outputs in case he wants to add an amp later.
http://www.newegg.com/Product/Produc...82E16882117401
That makes it less than the RX-V671 and only $50 more than the current price of the VSX-1021
http://www.amazon.com/Yamaha-RX-V671...7168372&sr=1-1
http://www.amazon.com/Pioneer-VSX-10...7168509&sr=1-1
Afro GT
afrogt is offline
post #18 of 23 Old 01-21-2012, 12:06 PM - Thread Starter
Im about 1 minute away from ordering the Onkyo TX-NR709
post #19 of 23 Old 01-21-2012, 12:19 PM
Quoted: 443 Post(s)
Liked: 337
That will certainly meet you needs and you feel you need more power you can easily add an external amp as the 709 comes with pre-outs
post #20 of 23 Old 01-21-2012, 12:21 PM - Thread Starter
also 12awg wires are the standard speaker wires right?
post #21 of 23 Old 01-21-2012, 12:23 PM - Thread Starter
Awesome I am ordering it!
post #22 of 23 Old 01-21-2012, 12:32 PM
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
Yes for 12 AWG, cheap from monoprice. Get the in-wall version if you are going to actually run them in walls or ceilings.
psgcdn is offline
post #23 of 23 Old 01-21-2012, 12:37 PM - Thread Starter
probably will be run along the trim of the wall. and all my cables come from monoprice. and my wall mounts.
Reply Speakers
