Can my speakers handle the power of my new sub? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 21 Old 01-21-2012, 11:15 PM - Thread Starter
skichiiwa's Avatar
Am i getting too much sub for my speakers. the sub is so freaking big.
bought a outlaw lfm-1 ex
own def tech UIW RLS III In-Wall Reference Line Source Speakers as fronts.
onkyo 609
thanks
skichiiwa is offline
post #2 of 21 Old 01-22-2012, 04:39 AM
Ericthemidget's Avatar
onkyo 609
thanks
No, you are fine. Set the crossover @100hz and it should blend well
Ericthemidget is offline
post #3 of 21 Old 01-22-2012, 05:13 AM
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
Nice!
Why 100 Hz Eric? I see the speakers are rated to 24 Hz (a bit hard to believe, but anyway) so the standard 80 Hz should be okay.
psgcdn is offline
post #4 of 21 Old 01-22-2012, 05:42 AM
pixel*entity's Avatar
From the Definitive Tech page :
UIW RLS III :Specifications
Outer Flange Dimensions | Metric :7 W x 25 H | 17.8 x 63.5 cm
Cut Out Dimensions | Metric :5-7/8 W x 23-3/4 H | 14.9 x 60.3 cm
Depth from Flange | Metric :3-13/16 | 9.7 cm
Driver Complement :One 1" pure aluminum dome tweeters; Two 5-1/4" cast-basket bass/midrange drivers pressure coupled to two 5-1/4 bass radiators
Frequency Response :24 Hz - 30 kHz
Impedance :Compatible with 8 Ohm outputs
Sensitivity :92 dB
Recommended Associated Amplifier Power :10 - 325 watts
A/V Receiver Crossover Setting :60 Hz
Inputs :One pair of gold plated spring loaded posts
pixel*entity is offline
post #5 of 21 Old 01-22-2012, 06:54 AM
chashint's Avatar
Liked: 54
Frequency Response :24 Hz – 30 kHz
Baloney !!!!
The Supercubes are not even flat to 24Hz.
Regardless of the recommended crossover IMHO 80 or 100Hz would be much more appropriate.
Charlie
chashint is offline
post #6 of 21 Old 01-22-2012, 07:19 AM
Mupi's Avatar
Liked: 26
Originally Posted by psgcdn View Post
Nice!
DefTech is well known for putting ridiculous specs for their speakers. Heck, even their tiny Promonitors can go down to the 20's according to the idiots at their marketing dept. Either put the corrects specs or dont put anything at all.
Mupi is offline
post #7 of 21 Old 01-22-2012, 07:54 AM
cjsiv's Avatar
Liked: 40
Also, Audyssey on the Onkyo should give you a nice starting point with the sub level. Mine on my Denon does a pretty good job of keeping the bass appropriate. I think there is no such thing as too much sub. Enjoy that new Outlaw!
cjsiv is offline
post #8 of 21 Old 01-22-2012, 08:00 AM
cel4145's Avatar
Quoted: 2662 Post(s)
Liked: 3000
When configuring the EX, set the gain (volume) on the back of the sub to about 9 or 10 o'clock on the dial. Run Audyssey. If Audyssey sets the channel (trim) subwoofer level on the receiver to below -3db or above +3db, adjust the gain on the sub appropriately and run Audyssey again. Repeat until you end up with Audyssey setting the gain in the -3db to +3db range, even if you have to turn the gain on the sub down further than you think. Then, you can bump the sub channel level a couple db if you need more bass. After running Audyssey, make sure your speakers are set to small (not large or full range) and try different crossovers. I'd go with 80hz first, but try 100hz and 60hz, too. Use whichever sounds best to you.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #9 of 21 Old 01-22-2012, 08:33 AM
craig john's Avatar
Quoted: 530 Post(s)
Liked: 741
Why do you think it's important to be in the +/- 3 range? I would rather be at -6 than +3. If you start at +3 and you want to bump the levels a little bit, you have to go more positive. You then run the risk of overdriving the input on the sub amp, causing distortion. If you start at -6 and you add 3, you're still at -3. Seems like a safer choice to me.
Craig
Lombardi said it:
Perfection is not attainable, but if we chase perfection we can catch excellence."
My System
craig john is offline
post #10 of 21 Old 01-22-2012, 08:37 AM
cel4145's Avatar
Liked: 3000
Craig
This is the general advice that is often given in the Outlaw Owners Thread and seems to work for people. Go argue with them
cel4145 is offline
post #11 of 21 Old 01-22-2012, 09:25 AM - Thread Starter
skichiiwa's Avatar
Ok thanks for the setup info guys , I'll start that when the sub get here. However I still want to know if I could get away with less sub is this overkill ?
post #12 of 21 Old 01-22-2012, 09:59 AM
cel4145's Avatar
Liked: 3000
You could buy an Epik Legend or Rythmik FV12 for just a little more (because of the shipping) and they'll have a less overall output and a little less low end extension, but maybe a little better SQ for music.
Below the $500 price point that gets you into this class of 12" ID subs made by Epik, Rythmik, Outlaw, and HSU, the 12" ported budget subs available generally have reduced sound quality, less low frequency extension, and not very flat frequency response. You could buy a 10" ported HSU or Outlaw ID sub in the $400 to $500 range that would have decent sound quality--better than the budget 12" subs--but they wouldn't have the same low frequency extension for movies as the EX and they might be challenged in your room space because of the lower SPL (volume output)--depends on how big your room is. Also, you should check. My guess is that the EX would have a little better SQ than those 10" ID subs
cel4145 is offline
post #13 of 21 Old 01-22-2012, 12:31 PM - Thread Starter
skichiiwa's Avatar
mainly talking size of this beast the outlaw lfm1 ex. its huge . May have issues hiding it. haha.
post #14 of 21 Old 01-22-2012, 12:38 PM
cel4145's Avatar
Liked: 3000
Keep in mind that even a very good sub can perform poorly in some spots in a room. If your placement options require hiding, it may not do as well as in other positions. This is why people recommend doing the sub crawl to find the best spot.
cel4145 is offline
post #15 of 21 Old 01-22-2012, 12:43 PM - Thread Starter
skichiiwa's Avatar
you shoulda started off as too add to your issues. I only have 2 locations where this beast can go front left front right otherwise it is a coffee table or side table.
also is there any literature or guide for dummies to understand how to do calibrate the sub .
also what do you listen for during a sub crawl?
noob i know...lol
post #16 of 21 Old 01-22-2012, 12:51 PM
cel4145's Avatar
Liked: 3000
If you mean as a side table near the listening position, then one of these two locations generally works well. The sub crawl can tell you which is better. Also, even moving the sub a couple of feet one way or the other can make a difference.
Read all but part III (that's for dual sub setup)
http://www.avsforum.com/avs-vb/showt...5#post14456895
See the sub crawl link I gave you,
"Play a bass heavy CD or other format (not 8 track!) that you are familiar with and turn the volume up so that the sub is really working."
cel4145 is offline
post #17 of 21 Old 01-22-2012, 01:18 PM - Thread Starter
skichiiwa's Avatar
thanks bud!
post #18 of 21 Old 01-22-2012, 03:39 PM
chashint's Avatar
Liked: 54
Craig
Well it would be best to have it at 0dB trim but it seems like it's too much to ask of people to put that much effort into it hence the +/-3dB.
Charlie
chashint is offline
post #19 of 21 Old 01-22-2012, 03:50 PM
craig john's Avatar
Quoted: 530 Post(s)
Liked: 741
Originally Posted by chashint View Post
Well it would be best to have it at 0dB trim...
Why? What is the downside of a negative trim setting?
Lombardi said it:
My System
post #20 of 21 Old 01-22-2012, 08:01 PM
chashint's Avatar
Liked: 54
0 is typically right in the middle of the range so it should be the most linear.
If the trim is set- the gain of the sub is set higher tham necessary and again less linear.
Like all things its not Gospel, it's a good starting point.
Charlie
chashint is offline
post #21 of 21 Old 01-23-2012, 08:34 AM
craig john's Avatar
Quoted: 530 Post(s)
Liked: 741
Linear? It's a volume control.
What would be less "linear" at -6 or -8 than at 0?
What would be less "linear" with a higher gain setting on the subwoofer amp?
Craig
Lombardi said it:
My System
Reply Speakers
