Huge room setup, need some help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 27 Old 01-22-2012, 07:39 PM - Thread Starter
systrex's Avatar
Hello all,
So I just purchased a new home and I am looking to setup a new system in the living room for mainly music and the occasional HT.
Currently I have the following which I would like to keep in the setup or use as secondary components if possible.
Onkyo TX-NR709
2 Polk Monitor 70's
Polk PSW 505
I listen to a lot of rap/techno/dance/dupstep type music so bass is very important (I am not sure if I have ever heard a system that had to much bass for me)
The room is huge in my opinion.
Living room is 15x20 with about 20 foot ceilings, which opens up into the dining room which is about 14x12 and the kitchen is right next to that which is 20 x 15, the staircase comes down into the living room which opens up to a pretty open hallway that is wide open into the hallway I mentioned earlier. As you can imagine its a pretty open floor plan which I love but might not be the best for music.
I dont have a budget exactly, I would just like to keep sub(s), amps, speakers under $4,000. Also I would like to invest the most in amps/front channel speakers/ and subs if its best and then added the surround sound speakers later when money permits. I really love Emotiva amps for the price, I dont mind Polk speakers, but I am not very happy with the Pol subwoofer I have had. I does not appear to hit the lows very hard and feels loose
ANY suggestions/help would be great, especially since I would like to do this right the first time around.
systrex is offline
post #2 of 27 Old 01-22-2012, 07:53 PM
Geoff4RFC's Avatar
Quoted: 317 Post(s)
Liked: 1573
Welcome to the forum!!
I've got a pair of M70's as well, very nice speaker, I also have the step up receiver as you with the 807.
Unless you're doing the high end polk subs, you need not apply. I messed around and got myself an Epik Empire sub, this thing is AWESOME!!! I'll give you the link so you can take a look. Not badly priced and you get quite a punch. Theres a lot of killer subs out there and this isn't the best but it sure does deliver.
http://www.epiksubwoofers.com/
Spinning the rear tire at 150mph while at 3/4 lean angle will put wrinkles in your seat
Set up:
Integra 70.4--Oppo 103--LG50"Plasma--Emotiva: XPA-3, XPA-2 x 2--PolkAudio: RTiA9 x 4--CSiA6--FXiA6 x 4--Epik: Empire x 2--XBOX 360--Furez 10awg homemade cables
Geoff4RFC is offline
post #3 of 27 Old 01-22-2012, 08:08 PM
cel4145's Avatar
Quoted: 2657 Post(s)
Liked: 2987
Ditto on the Empire. But you might need two.
Not too much bass? You posted in the wrong forum, especially if you like rap/techno/dance/dupstep. You should be discussing this in the AVS subwoofer forum with the people who know bass
Look at the HSU website (HSU is one of the top subwoofer brands) and click on the loudness icon with their products. You'll see that even their top rated 12" sub, the VTF-3 MK4, is only recommended in rooms up to 6,000 cubic feet. You have a single room that size opening to others. Meanwhile, the PSW505 might (but doubtful) have as much output as the smaller VTF-2 MK4, and it certainly doesn't have the SQ or low frequency extension for HT.
So, depending on whether or not you want serious bass, you could easily spend $1000 to $2000 for a sub for that space. I think you should go do your research and ask questions in the subwoofer forum, first, and then make decision about how much of your budget to put towards the sub before talking about speakers. Here's a good post to start with: SHOOTOUT! Epik Empire vs HSU VTF-15H vs CHT CS18.1 vs Rythmik FV15 vs eD A7s-450
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #4 of 27 Old 01-22-2012, 08:21 PM - Thread Starter
systrex's Avatar
Thanks for the reply and the suggestions on the Epik's, I had not checked these out. I like the M70's so far, at least the highs seem really clear but I had been looking into the RTI9's for example and was not sure how they compared to these. A thought I had was to buy something such as the RTI9's and move the m70's to be rear speakers.
systrex is offline
post #5 of 27 Old 01-22-2012, 08:26 PM - Thread Starter
systrex's Avatar
Thanks for the suggestions, I went ahead and posted in the sub-woofer thread, shall see what those guys have to say. I dont mind spending a larger chunk of money on the subs as I know to me those are one of the most important pieces. I suppose I could also do something such as buy 1 and add another later, at one point I had envisioned 4 subwoofers for the room with one being in each corner. I had not though about cubic feet of the room so you are right, my living room alone is 6000sq feet.
I think another thing I need to think about is power. I believe the living room is on two different 15 amp breakers so assuming I dont wanna go over 80% load, I have about 2800-2900 watts of power to play with.
systrex is offline
post #6 of 27 Old 01-22-2012, 08:48 PM
pokekevin's Avatar
Liked: 102
You'll be fine on power! I'm running to ex's plus all my gear on two 15 amp outlets and all has been well. Might be the same circuit
pokekevin is offline
post #7 of 27 Old 01-22-2012, 10:01 PM
cel4145's Avatar
Liked: 2987
People assume a 300 RMS, 1000 watt peak subwoofer can use 1000 watts of power. But as I understand it (and this a question for the AVS sub forum), the extra wattage comes from the current in the capacitors stored up by the amplifier--it's for quick dynamic peaks. So the actual current draw is related to the 300watt RMS output.
cel4145 is offline
post #8 of 27 Old 01-23-2012, 11:19 AM
smasher50's Avatar
Quoted: 354 Post(s)
Liked: 15621
heres a suggestion take a look at chase home theater. 5 of their sho s-10 speakers and 18" passive sub and sub amp all for under $3000 these can get loud without alot of power.might save you some money on amp side. just my 2 cents
i'm so laid back,i'm laid out
smasher50 is offline
post #9 of 27 Old 01-23-2012, 01:13 PM
Eyleron's Avatar
Quoted: 250 Post(s)
Liked: 142
If you are not going to be adding acoustic room treatment panels to the side wall reflection points, you should focus on constant directivity designs that focus more of the sound at the listeners and less splash on the sidewalls.
The Chase Home Theater speakers mentioned above, or others like JTR Triple 8 will have the sensitivity you need for a such a big place.
I have a list of more sensitive speakers.
SEOS Fusion 10 Max, 88 Special, Volt 10 LX, SVS PB10 and DIY SI18 subs, Denon X4000, JVC RS400 & 2.35:1 AT Screen
Eyleron is offline
post #10 of 27 Old 01-23-2012, 09:28 PM - Thread Starter
systrex's Avatar
Looks like for the subs I will be going with two FV15HP's. Any suggestions on a set of loudspeakers for the front that would match these subs well?
systrex is offline
post #11 of 27 Old 01-23-2012, 09:35 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
So you are going to spend over $2000 for 2 subs, with a $4000
budget for amps, speakers and subwoofer?
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #12 of 27 Old 01-23-2012, 09:49 PM
cel4145's Avatar
Liked: 2987
budget for amp, speakers and subwoofer?
You don't hang out with the bass loving sub crowd much, do you Jim?
cel4145 is offline
post #13 of 27 Old 01-23-2012, 09:56 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
I like bass - however, I want good all around balanced speakers, to go
with it. He will have lots of bass!
Who AM I
zieglj01 is offline
post #14 of 27 Old 01-23-2012, 09:58 PM - Thread Starter
systrex's Avatar
Correct, so that leaves me with about 2k for a set of speakers and an amp.
I had looked into the Emotiva xpa-2 which will run me about 800 so that leaves me roughly 1200 or so for a set of front speakers. I had looked into the Polk RTi9's but not sure if there are better options for around 1k.
systrex is offline
post #15 of 27 Old 01-23-2012, 09:59 PM - Thread Starter
systrex's Avatar
Can never have to much bass
systrex is offline
post #16 of 27 Old 01-23-2012, 10:13 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
With the music that you enjoy and your room size, and with the
remaining budget - the Polk Rti9 or Klipsch RF82 - the treble of
the Polk RTi series, is easier on my ears.
Klipsch RF 82
http://www.vanns.com/shop/servlet/it..._c=site_search
http://www.jr.com/klipsch/pe/KLP_RF82II/
Who AM I
zieglj01 is offline
post #17 of 27 Old 01-23-2012, 10:30 PM
cel4145's Avatar
Liked: 2987
He also has a 6,000 cubic feet of living room that opens into lots of other areas that could easily double the space. I suggested he might start with one, but he wants two (partially because of the 10% discount), and that's a not unreasonable for that kind of space. Heck. I understand. I have an Outlaw EX in my living room that is part of 6,000 cubic feet, and I really want a second one to do it right
systrex: Eyleron suggested you look at high sensitivity speakers given your big living room. For example, the Chase Home Theater speakers he suggested have 97db sensitivity; I would imagine that your Polks have 90db or so. That means for the same volume that produces 90db with the Polks, you get 97db with the CHO speakers. Considering you have to double the wattage from an amp to a speaker to get 3db more, high sensitivity speakers will definitely help you achieve more volume along with the amp you want to buy if volume is one of your primary goals.
cel4145 is offline
post #18 of 27 Old 01-23-2012, 10:34 PM - Thread Starter
systrex's Avatar
Thanks cel, makes a lot more sense. Ill check into the chase speakers
systrex is offline
post #19 of 27 Old 01-24-2012, 07:08 PM - Thread Starter
systrex's Avatar
I think I can swing the following... but curious what are the main differences between the JTR Quintuple and the JTR Triple 8HT, worth the money difference? any major performance differences?
systrex is offline
post #20 of 27 Old 01-24-2012, 07:17 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Have you been over to the thread - they will answer your question.
Go big now - keep from upgrading later.
Go here
http://www.avsforum.com/avs-vb/showt...t=jtr+official
http://www.avsforum.com/avs-vb/showt...icial&page=121
Who AM I
zieglj01 is offline
post #21 of 27 Old 01-24-2012, 07:55 PM - Thread Starter
systrex's Avatar
Go here
I have not, I went and posted over there now. Its a lot more money once you take into account the amps needed, so thats why I am wondering if its worth it vs something like the speakers you posted earlier.
systrex is offline
post #22 of 27 Old 01-24-2012, 08:15 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
I do not have experience with JTR, or the SHO-10 > the SHO-10
should do a good job in your room. Also just for info, the Klipsch
RF-82 is rated at 98 db sensitive.
This is JTR contact info
Customer Support
847-714-6878
sales@jtrspeakers.com
Tech Support
847-714-6878
jeff@jtrspeakers.com
Who AM I
zieglj01 is offline
post #23 of 27 Old 01-24-2012, 08:33 PM - Thread Starter
systrex's Avatar
Customer Support
847-714-6878
Tech Support
847-714-6878
I am very shocked by the lower power needs of the SHO-10's
systrex is offline
post #24 of 27 Old 01-24-2012, 08:37 PM
cel4145's Avatar
Liked: 2987
Chase also has a forum at their website for discussing their speakers: http://www.chasehometheater.com/foru...isplay.php?f=7
cel4145 is offline
post #25 of 27 Old 01-25-2012, 04:55 AM
smasher50's Avatar
Quoted: 354 Post(s)
Liked: 15621
get cheap 7.1 or 7.2 avr (upgrade later) and 2 -18" subs just a little over budget but damm sure it will fill your house with sound
post #26 of 27 Old 02-29-2012, 12:34 PM - Thread Starter
systrex's Avatar
Why would I get a cheap 7.1 and 7.1 when I need amps anyway? a decent AVR that has pre-outs is going to run 400-600 anyway, I might as well buy a decent audio/video processor (which I ended up doing, the UMC-1 for 325 and still has 4 years of warranty (love craigslist). I ended up getting the UMC-1, two Rythmik FV15HP subs, emotiva xpa3 and xpa2, and I am still looking for speakers. My thoughts are on 3 JTR 12HT's for the front L/C/R
systrex is offline
post #27 of 27 Old 02-29-2012, 07:18 PM
Eyleron's Avatar
Quoted: 250 Post(s)
Liked: 142
You said in response to being steered to the JTR threads:
I'm not sure what you meant by that. Did you think that you needed "more amp for bigger speakers" (a common misconception, since it depends on the sensitivity)?
In the case of JTR Triple 8's, you'd be fine with LESS amp: like 1w average and 20w for peaks, if you were listening 5dB below reference level.
Or 100w for the highest peaks if you do want reference level (sitting 12 feet away in a well-treated room).
Here it's apparent you realize how little power you'll need with these speakers.
So I'd think you'd want to get the speakers first, and then the amps?
But then again, there's nothing wrong with overkill, headroom, and the satisfaction of cool gear.
Congrats on your purchases. The extra 3dB of output you'll get from the amps mean that you can look for speakers that are 3dB less sensitive than what you may have considered before. For instance instead of a 97dB CHT Sho-10, it could be a 94dB speaker.
I just wish there were more in the medium-high sensitivity category.
At least Elemental Designs eD[c]6 are in that category at 93dB anechoic.
Eyleron is offline
Reply Speakers
