Lens shift question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 01-25-2012, 04:27 PM - Thread Starter
Adz523's Avatar
If I mount my 137.7 diagonal screen on a wall at the top of my ceiling and then mount my JVC RS35 projector on the ceiling so that its at the top of the screen about 20 feet away, but there is a large wood beam about 5 feet in front of the projector running across the room that hangs about 10 inches from the ceiling, I assume that the image will still project onto the full screen due to lens shift and not onto the beam? Sorry if this is confusing.
Adz
Adz523 is offline
post #2 of 9 Old 01-25-2012, 05:06 PM
bbrio's Avatar
Uh oh, we're not in Kansas anymore Toto.
bbrio is offline
post #3 of 9 Old 01-25-2012, 05:09 PM - Thread Starter
Adz523's Avatar
hahaha. i also put this in the wrong forum. Can't delete it or move it to projectors.
Adz
Adz523 is offline
post #4 of 9 Old 01-25-2012, 08:00 PM
Mike Garrett's Avatar
Quoted: 5602 Post(s)
Liked: 3587
As long as the line of sight from the lens to the top of the screen is clear, then no problem. Did not expect to see a projector question here. By the way, nice projector.
mjgarrett100@gmail.com
Mike Garrett is offline
post #5 of 9 Old 01-26-2012, 05:59 PM
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
It doesn't sound as if there's line of sight...
psgcdn is offline
post #6 of 9 Old 01-27-2012, 05:49 AM - Thread Starter
Adz523's Avatar
Mike -- If I drop the projector down using a 12" pipe so that the lens is firing below the 10" beam, but that darn beam is still about 5-6 feet in front of the projector, would that work?
Adz
Adz523 is offline
post #7 of 9 Old 01-27-2012, 06:50 AM
wlhungdude's Avatar
Quoted: 180 Post(s)
Liked: 223
you could just affix a string to the screen wall at the same height as the top edge of the screen , then draw it out to the back of the room... you can determine exactly how much drop you'll need at the projector's location to clear the beam. make sense? btw... painter's tape for no residue on your wall, and mason string doesn't stretch.
mods, can we have a 'dislike' button ?
wlhungdude is offline
post #8 of 9 Old 01-27-2012, 08:00 AM
Looneybomber's Avatar
Liked: 25
This sounds like a middle school or high school geometry problem.
A=15ft. The distance from the screen to the beam
B=10". The distance the end of the beam to the ceiling.
X=4A/3. The ratio of the distance the projector is from the screen compared to the beam.
10" * (4/3) = 13.3".
So make sure your lens is 13.3" below the ceiling and you will have line of sight. If however, your screen is not at the meeting point of the wall and ceiling, but is instead a couple inches down, you won't have to have the lens as far down.
YID DIY
Looneybomber is offline
post #9 of 9 Old 01-27-2012, 12:16 PM
DonH50's Avatar
Quoted: 1795 Post(s)
Liked: 1330
^^^ Nice job! So, we are in Kansas...
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
Reply Speakers
