Is this overkill for a centre channel? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 36 Old 01-27-2012, 02:24 PM
chikoo's Avatar
Originally Posted by JHAz View Post
Those two tweeters will cancel each other out and add together at different frequencies, and those frequencies will change if you lean left or lean right. Not a good design. Never flat (ie never accurate), plus possibly noticable changes in the sound if you move your head an inch . . .
Somebody somewhere is making these...
http://www.avsforum.com/avs-vb/showt...4#post21351484
chikoo is offline
post #32 of 36 Old 01-27-2012, 02:26 PM
chikoo's Avatar
chikoo is offline
post #33 of 36 Old 01-27-2012, 03:20 PM
zamboniman's Avatar
There's no such thing as an overkill center.... I've seen plenty of underkilled centers..
It's where all the magic happens!
zamboniman is offline
post #34 of 36 Old 01-29-2012, 03:21 PM - Thread Starter
skichiiwa's Avatar
Yea not worried about overkill anymore, just timbre
Matching a center that will be worth buying due to of axis issues, I assume all def tech centers will have this issue.
I'm leaning mythos 8 someone have this as a center? Horizontal?
skichiiwa is offline
post #35 of 36 Old 01-30-2012, 07:31 AM - Thread Starter
skichiiwa's Avatar
Originally Posted by Kal Rubinson View Post
Don't.
Kal, what do u suggest I do other then vertically place the center, or what speaker should I buy to place on my mantle
post #36 of 36 Old 01-30-2012, 02:54 PM
Kal Rubinson's Avatar
Quoted: 693 Post(s)
Liked: 472
I am not able to help you with this problem if there is no room for a well-designed center. How much space do you have? Where is it situated?
Kal Rubinson
"Music in the Round"
Kal Rubinson is online now
Reply Speakers
