Focal's for HT?!? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-26-2012, 06:41 PM - Thread Starter
PhilT3's Avatar
Hey guys...
I am running a full 7 channel Focal Chorus system.
Fronts are 836V
Center is 800CC
Sides are 800SR
Rears are 705V
They are all running off a Pioneer Elite SC-05.
They are in a dedicated theater. 100% movies.
My dialog seems very low. I know I can increase the channel level of the center and/or decrease the other channels in the AVR.
But at the end of the day, the center channel is only 2-way with three total drivers... The fronts are 3-way and have 5 drivers each.
I have to imagine the channel level adjustment is only going to get me so far.
I have an investment in these speakers... How 'bad' would it be to upgrade only my center to something like the Paradigm CC690?
It seems like the center channel I have was an afterthought from Focal!
PhilT3 is offline
post #2 of 5 Old 01-26-2012, 06:53 PM
chrisvw16's Avatar
Quoted: 27 Post(s)
Liked: 46
yes the center is not the greatest, especially to match the 836's. i would not however switch brands.
look into the profile cc908, it is a 3way, the tweeter is very similar to the chorus. this would probably match better than a paradigm.
i have a pair of 807 as my fronts and i need to get a center. i'm kinda in the same boat as you, i dont really want the cc800 as my center. but i'm thinking of buying another 807 to put in the center that way i will have 3 matching speakers across the front.
but i am assuming you cant fit a tower in the middle to match your l/r. besides it would be hard to find a single tower for sale.
check ebay there is a cc908 for sale right now, you can probably get it cheap. i would buy it if i had the money...
chrisvw16 is offline
post #3 of 5 Old 01-26-2012, 06:58 PM - Thread Starter
PhilT3's Avatar
Thanks Chris.
I agree with you on not wanting to switch brands. But man... That Paradigm 690 is a monster!
I am going to look into the profile and electra lines from Focal.
PhilT3 is offline
post #4 of 5 Old 01-26-2012, 08:05 PM
chrisvw16's Avatar
Quoted: 27 Post(s)
Liked: 46
yeah those paradigms are huge!, its the only reason i had considered going with paradigm before going with focal. The electra BE line is sweet, but expensive! hopefully one day.
post #5 of 5 Old 01-27-2012, 04:46 AM - Thread Starter
PhilT3's Avatar
Thanks... Bump.
PhilT3 is offline
Reply Speakers
