Get your TV off your center channel with this stand - AVS Forum | Home Theater Discussions And Reviews
post #1 of 29 Old 01-27-2012, 12:26 PM - Thread Starter
cel4145's Avatar
Quoted: 2655 Post(s)
Liked: 2985
My 46" LCD TV and audio console is in front of a window, so there is no easy way to wall mount the TV. Previously, I had the TV on top of the center channel, but now have found a better solution: Convenience Concepts Designs-2-Go 2-Tier Swivel TV Stand. Rated up to 60lbs.
Just got an Energy RC-LCR today, and it fits perfectly with about 1/2 inch on each side and 1/4 inch above.
It appears to be some kind of thick MDF with black wood grain finish that is very similar to the Energy RC series, close enough match that someone might think it was intentional. The posts are heavy duty metal chrome (very solid), and the end caps you see in the 2nd picture on top are a plastic chrome screw on type (wish those were metal) that attach to the metal posts. The caps are also on the bottom, locking the posts firmly in place.
Before putting the TV on top of the stand, I removed the plastic swivel platform from the bottom to increase stability. The top of the swivel platform pops off and then just a few screws to remove it the rest of the way. I then put thick stick 'em furniture pads on the bottom; this step is necessary because of the plastic corner caps on the bottom.
Anyway, hope this helps someone else. I think it looks a lot better and reduces risk of scratching the center with the TV stand. Because it also allows me to shift the center farther forward, and because the center is up off the main entertainment console center an inch more, I'm hoping this helps improve dispersion.
UPDATE Fall 2016: The TV riser held up very well. However, I decided I wanted a much larger center channel. I upgraded to a custom TV riser from Syracuse TV Risers: http://www.syracusetvrisers.com/ Great product from them, but of course much more expensive.
erhurd likes this.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #2 of 29 Old 01-27-2012, 12:55 PM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 521
Now THAT is a Center Speaker, cel...lol!!!
Is that really a hi-fi speaker or did you get it when they tore down Shea Stadium...?
It looks about that big...rofl.
That stand is a VERY nice-looking stand, and obviously practical for that setup.
commsysman is offline
post #3 of 29 Old 01-27-2012, 12:59 PM
eljaycanuck's Avatar
Quoted: 1227 Post(s)
Liked: 1798
To paraphrase Crocodile Dundee: "That's not a center speaker, THIS (3' wide, 70lbs.) is a center speaker!"
Nice, solid-looking TV / center speaker stand, though, and a good tip for anyone looking for a similar solution. Great fit to your Energy RC-LCR, too!
eljaycanuck is offline
post #4 of 29 Old 01-27-2012, 01:13 PM - Thread Starter
cel4145's Avatar
Liked: 2985
Be nice to do the dedicated HT room setup with the big center. I've seen yours before
I could have put the center in the console underneath. But in a crowded home living room, it really seems better to have it up in the air more. And I've seen other pictures where people have the same issue where their console is already full anyway and no room for the center. At $34 and $1 worth of those furniture leg stick 'ems, works pretty well even for those with small budgets.
Gmonski likes this.
cel4145 is offline
post #5 of 29 Old 01-27-2012, 01:21 PM
Liked: 1798
Yup, that's a hell of a deal for an attractive and clearly functional stand that opens up some shelf real estate for other electronic toys.
post #6 of 29 Old 01-27-2012, 01:30 PM
chikoo's Avatar
chikoo is offline
post #7 of 29 Old 01-27-2012, 01:50 PM
Djoel's Avatar
Quoted: 543 Post(s)
Liked: 416
I doubt my cent would fit under there, it's HTM3S a little over 9" tall I forget how wide but it big.
Djoel
Djoel is offline
post #8 of 29 Old 01-27-2012, 02:19 PM - Thread Starter
cel4145's Avatar
Liked: 2985
Sorry. The RC-LCR is 7.5", and you can see there is maybe 1/4 inch of clearance above it.
cel4145 is offline
post #9 of 29 Old 01-27-2012, 04:15 PM
YeuEmMaiMai's Avatar
my TV stand is tal enough that my center fits in front below the screen but that is a nice nice setup there.....
Strong or weak in the end we are all dead
YeuEmMaiMai is offline
post #10 of 29 Old 01-27-2012, 06:57 PM
Joshjp's Avatar
Quoted: 13 Post(s)
Liked: 115
Do you guys think that thiss will work with my setup
Klipsch RC-62
Samsung PN51D490
HT~
PANASONIC TC-P50ST60, OPPO BDP-103D, ONKYO TX-NR818, PANAMAX MR4000, KLIPSCH RF-62's, RC-62, RS-52's, PSA TRIAX
2.1CH~
ADAM AUDIO F5's, EMOTIVA STEALTH DC-1, SVS SB-2000
Joshjp is offline
post #11 of 29 Old 01-27-2012, 07:18 PM - Thread Starter
cel4145's Avatar
Liked: 2985
There's only about 7 3/4" of height clearance. I think your center is taller than that.
cel4145 is offline
post #12 of 29 Old 01-27-2012, 07:40 PM
pokekevin's Avatar
Liked: 102
I see you got your lcr...what about the 50s?
pokekevin is offline
post #13 of 29 Old 01-27-2012, 08:23 PM - Thread Starter
cel4145's Avatar
Liked: 2985
Yep. Got them, too. They are breaking in
cel4145 is offline
post #14 of 29 Old 01-29-2012, 12:28 AM
TEE HEE's Avatar
Here's another Ikea hack. TV riser
TEE HEE is offline
post #15 of 29 Old 01-29-2012, 06:28 PM
Sonyad's Avatar
Quoted: 177 Post(s)
Liked: 103
Thanks for that link. I had considered those legs awhile ago and never pulled the trigger. After putting my tv on my Rolykit behind my Pioneer center, I later found a $4 wire shelf from Goodwill that puts the tv over the center. Kind of ghetto/trailer park, but it's working for me at the moment.
Sonyad is offline
post #16 of 29 Old 02-11-2012, 01:59 PM
its phillip's Avatar
Quoted: 62 Post(s)
Liked: 115
I finally got my riser in too. Unfortunately the base of my tv is somewhat larger than yours, but it still fits It's just barely sitting on the rear plastic caps.
its phillip is offline
post #17 of 29 Old 02-11-2012, 02:06 PM - Thread Starter
cel4145's Avatar
Liked: 2985
Looks great. For just $34, it's a good aesthetic match for the black RC-LCRs, with the chrome supports and black wood grain veneer
cel4145 is offline
post #18 of 29 Old 06-28-2012, 12:25 PM - Thread Starter
cel4145's Avatar
Liked: 2985
Just an update. I upgraded my TV to a 60lb+ Panasonic 50UT50. The TV stand fits well between the silver support caps on top, and it seems to have no problem supporting the weight.
cel4145 is offline
post #19 of 29 Old 06-28-2012, 12:31 PM
pokekevin's Avatar
Liked: 102
pics??
Sent from my SCH-I405 using Tapatalk 2
post #20 of 29 Old 06-28-2012, 12:47 PM - Thread Starter
cel4145's Avatar
Liked: 2985
Originally Posted by pokekevin View Post
pics??
394
cel4145 is offline
post #21 of 29 Old 06-28-2012, 01:06 PM
Quoted: 62 Post(s)
Liked: 115
post #22 of 29 Old 06-28-2012, 01:19 PM
flickhtguru's Avatar
Liked: 110
Also check out Z-Line Designs TV stands. They are made so that the TV mounts/hangs on an upright. I have my TV (60" plasma) to the highest position and it allows me to fit my 10" H Acoustech PL-28 with dual 8" woofers below it but still on the top shelf. Here is what I have... http://www.bhphotovideo.com/c/product/711894-REG/Z_Line_ZL564_44MU_Vitoria_Flat_Panel_TV.html
Here is a pic of my setup... http://i1264.photobucket.com/albums/jj489/flickhtguru/IMG_0280.jpg
Shawn
flickhtguru is offline
post #23 of 29 Old 06-28-2012, 01:20 PM
pokekevin's Avatar
Liked: 102
post #24 of 29 Old 06-28-2012, 01:27 PM - Thread Starter
cel4145's Avatar
Liked: 2985
What? Did you put two EXs on either side of your audio cabinet, with the 2x4s across, and put the TV on top of that? tongue.gifsmile.gif
cel4145 is offline
post #25 of 29 Old 06-29-2012, 10:57 AM
sdg4vfx's Avatar
Quoted: 81 Post(s)
Liked: 140
Another option for raising the TV.
http://www.homefurnituremart.com/pltvstbe9.html
sdg4vfx is offline
post #26 of 29 Old 06-29-2012, 12:17 PM
pokekevin's Avatar
Liked: 102
:DDD. Gives the tv a rumble effect :d
post #27 of 29 Old 06-29-2012, 12:31 PM - Thread Starter
cel4145's Avatar
Liked: 2985
Pokekevin's D-Box theater--where even the screen moves LOL
cel4145 is offline
post #28 of 29 Old 06-29-2012, 04:04 PM
TheWind's Avatar
Liked: 30
Another DIY TV Riser Suggestion (easy to do.)
I posted the above a while back. At the moment, selection seems down (especially color) and prices are up, but, fwiw, here are three starting points.
black; external width = 23.5”.
ebony; external width.= 26.5”
espresso; external width.= 28”
TheWind is offline
post #29 of 29 Old 06-30-2012, 07:12 PM
sdg4vfx's Avatar
Quoted: 81 Post(s)
Liked: 140
Someone posted these top-of-TV-shelves on another thread ...
http://www.crutchfield.com/g_348550/Speaker-Shelves.html?tp=36255
Any idea on how much weight would be safe to put on one of these? If the weight is pulling back could that put torque on the TV screen?
sdg4vfx is offline
Reply Speakers
