My speakers made a loud pop, now they don't work. Help? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-27-2012, 07:20 PM - Thread Starter
CrossCut49's Avatar
It came out of nowhere and sounded like a gunshot, completely jumping me out of my chair. My music was relatively quiet, you probably couldn't hear it outside the room if I closed the door.
After the pop, my speakers stopped working and my music stopped playing. My receiver stayed on but there was no sound, and rebooting had no effect. I double checked all the settings and it all seemed to check out.
I've tried to connect my speakers to my onboard motherboard sound, but there's still nothing. I'm not sure if it could be plugged in wrong or not, but it appears right. This leads me to believe it's the speakers themselves, but then again I doubt that 1 pop could stop 5 speakers and a sub from working all at once.
I've got a 5.1 Logitech setup w/an X-Fi XtremeMusic
Thanks for any help, guys.
CrossCut49 is offline
post #2 of 5 Old 01-28-2012, 04:28 AM
YeuEmMaiMai's Avatar
most likely the amp croaked (the loud pop) and possibly took your speakers with it....
Strong or weak in the end we are all dead
YeuEmMaiMai is offline
post #3 of 5 Old 01-28-2012, 05:24 AM
commsysman's Avatar
Quoted: 1080 Post(s)
Liked: 569
An easy test to see if a speaker is completely burned out is to remove the grille so you can see the cones, and disconnect the wires from the receiver.
Then bring the wires ends around to the front of the speaker and use a 1.5 volt battery to check for cone movement.
Just touch the wire ends to the AA or C battery for a moment and you should see the cone move in or out, and then return when you disconnect it.
If the cone moves when you connect voltage, the speaker is not completely burned out
commsysman is offline
post #4 of 5 Old 01-28-2012, 08:49 AM
Kal Rubinson's Avatar
Quoted: 805 Post(s)
Liked: 571
What kind of a setup do you have? The X-Fi XtremeMusic is a sound board. The Logitech 5.1 setups are integrated amp/speaker combos. What receiver is there? How is all connected? Seems likely to me that you blew the electronics in the Logitech.
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #5 of 5 Old 01-28-2012, 10:01 AM
helicopterpilotd's Avatar
That does not sound good at all. Almost sounds like something might have shorted out. Hope it's not too bad.
helicopterpilotd is offline
Reply Speakers
