Titling surrounds - any benefit? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-28-2012, 05:41 AM - Thread Starter
RamKat's Avatar
I am installing a 7.1 system in my smallish 12 x 16 basement rec room where the 4 surround speakers will, due to practical reasons, not be ideally located. The side surrounds will be about a foot higher than the recommended 6 feet (to limit head bumps when walking past) and the rear surrounds will be ceiling mounted inside the box that is built around duct work between the duct work and a structural beam.
Can I expect any improvement in the listening experience by tilting the side surrounds slightly down and tilting the rear in ceiling speakers slightly forward? I have seen ceiling mounted speakers that are tilted about 15 degrees inside the enclosure. Although those are not the ones that I am planning on buying, it is the same idea. The rear surrounds will be about 5 feet behind the listening position at the 45 degree of-axis angle. Further to the back is an open stairway and washroom door etc which make wall mounted rears impractical.
Epson 8500UB (R); Elite Electric100 16:9; Yamaha RX-V671; Polk Monitor 60 x 2, Polk CS2, Polk Monitor 30 x 4
RamKat is offline
post #2 of 2 Old 01-28-2012, 07:27 AM
Smigro's Avatar
Quoted: 212 Post(s)
Liked: 220
You should not experience any problems doing that. It is actually recommended that you tilt the side surrounds down towards the main listening position.
Xbox GT / PSN ID - Smigro
my blu ray collection - http://www.blu-ray.com/community/col...0&categoryid=7
Smigro is offline
Reply Speakers
