optical to LFE? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-29-2012, 05:48 AM - Thread Starter
Muddeprived's Avatar
My buddy got me a JBL SCS500.5 surround sound system. It uses a purple LFE cable to connect to the tv. I have a Panasonic P50ST30 that has a digital audio out port on the back (optical). I have zero experience with connecting this stuff but I assume I am going to need an adapter or converter of some sort?
Muddeprived is offline
post #2 of 4 Old 01-29-2012, 07:21 AM
eljaycanuck's Avatar
Quoted: 1228 Post(s)
Liked: 1802
Why do you want to hook up the sub to the TV? The SCS500.5 is a 5.1-speaker system (five satellites + a sub) - it should be connected to an A/V receiver, as shown in the manual (PDF).
eljaycanuck is offline
post #3 of 4 Old 01-29-2012, 07:34 AM
BobL's Avatar
Liked: 56
There is no way to connect the two. A sub can't accept a digital input. You need a receiver to power the speakers and the sub connects to the receiver. Your sources (ie cable box/Satellite box, DVD/Blu-Ray, gaming consoles, etc.) connect to the receiver and then the receiver connects to the TV. The receiver is the main hub for a surround system, everything connects to it with various type of connections.
BobL is offline
post #4 of 4 Old 01-29-2012, 07:39 AM
MikeBiker's Avatar
Quoted: 12 Post(s)
As eljaycanuck said, your system is not complete. You need to get a receiver to power the speakers and to interface between the TV and the speakers. There are quite a few low-cost 5.1 receivers that will work well with the speakers.
MikeBiker is offline
Reply Speakers
