AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   Speakers (http://www.avsforum.com/forum/89-speakers/)
-   -   klipsch rf 62ii as rears? (http://www.avsforum.com/forum/89-speakers/1391378-klipsch-rf-62ii-rears.html)
cedkarpar 02-01-2012 02:52 PM
I just got a pair of Rf 62ii over a month ago but now I wish I had gone with Rf 82ii. I have a friend looking for speakers too and willing to buy my 62ii. But should I just use the 62ii as rears in a 7.1 setiup? Can the Rf 62ii be used as rears or bookshelf speakers are better?
eljaycanuck 02-01-2012 03:23 PM
... should I just use the 62ii as rears in a 7.1 setiup ... or [are] bookshelf speakers are better?
Yes, the RF-62 II's can be used as rear surrounds but, IMO, it's a bit of overkill to use towers for that purpose.
KMFDMvsEnya 02-01-2012 03:43 PM
Using towers as surrounds is not necessarily overkill simply not as common in home theater.
I listen to quite a bit of multichannel music in addition to movies and having direct radiating towers sounds better for me.
My surrounds are the RF-82s and they work marvelously.
Best Regards
KvE
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
