KEF vs Paradigm - AVS Forum | Home Theater Discussions And Reviews
post #1 of 19 Old 02-02-2012, 04:57 AM - Thread Starter
-BASO's Avatar
Hello all, this is my first time joining a forum and posting so please forgive any mistakes
I've narrowed my speaker choices down to either
1-Paradigm - Signature S8 + C5 + ADP3
2-KEF - Reference 205/2 + 204/2 + 206/2
If anyone has any input/insight into my speaker choices please reply with your opinions.
-BASO is offline
post #2 of 19 Old 02-02-2012, 07:06 AM
Stylz25's Avatar
Paradigm hands down!! IMO. Have you listened to both? Try and let your ears make the choice!! Both would be great but Paradigm is hard to beat!! Amazing speakers!!!!
Stylz25 is offline
post #3 of 19 Old 02-02-2012, 07:43 AM - Thread Starter
-BASO's Avatar
i can't listen to them
my dealer don't have stock
-BASO is offline
post #4 of 19 Old 02-02-2012, 08:30 AM
lulimet's Avatar
Quoted: 94 Post(s)
Liked: 92
Don't buy speakers that you can't listen to especially when the speakers you are looking at cost thousands of $$. Go to a dealer that has them on stock.
lulimet is offline
post #5 of 19 Old 02-02-2012, 10:00 AM
brianlsu's Avatar
I do agree on listening, but even that has limitations. The system, power and speakers, and environment where you listen to equipment plays a HUGE part. A cheap system well dialed in for the room will sound better than a very expensive system not properly tuned.
I would opt for the Paradigm. The KEF's I'm sure are very nice but they have Ti tweeters. The Paradigm Sig's have Be. Big difference if you like clean highs. The Be tweeter's are generally used on much more expensive speakers.
brianlsu is offline
post #6 of 19 Old 02-02-2012, 11:49 AM
Matts's Avatar
I agree that you definitely need to listen to the speakers before you buy. What area of the country do you live in BASO. Paradigm is a fairly well distributed brand and should have a dealer somewhere in your area, unless you live in a rural area or something. Even if you have to drive an hour or two I would recommend it. The Paradigm set you are interested in is going to retail around $15,000 or so. I may be slightly off on that figure as it has been a while since I priced Paradigm top line. KEF speakers are generally well regarded on this forum also, but harder to find a dealer in certain areas of the country. If you must buy sound unheard make sure you get something in writing that states you can return the speakers if you are not happy.
I have listened to the Sig 8, but this was a few years ago when they first came out. They are very rich and detailed and their highs are right up there with some of the best. Very good tight bass as well. You might also consider asking around the forum in the Meet Forum to see if anyone might have either one of these setups in your area. They may allow you to come by and have a listen.
Matts is offline
post #7 of 19 Old 02-02-2012, 04:04 PM
sivadselim's Avatar
Quoted: 159 Post(s)
Liked: 154
Big difference, huh? To base a speaker purchase on that difference alone would be absurd. Even if the OP gave a thorough listening test to both speakers and preferred the Paradigms, being able to definitively attribute that preference to the Be tweeters would be fantasy. C'mon. Honestly, to enter into a speaker buying comparison with that sort of biased thinking would be foolish.
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is offline
post #8 of 19 Old 02-04-2012, 11:14 PM - Thread Starter
-BASO's Avatar
my english is not so good so please forgive me for any mistakes
i live in saudi arabia and the nearest dealer to me will be in other country and will take like 10 hour drive and he don't have stock
i afraid The company announces to signature v.4 soon
and i have Another query about the difference between studio and signature is worth the difference in the amount
-BASO is offline
post #9 of 19 Old 02-04-2012, 11:48 PM
DigsMovies's Avatar
Quoted: 34 Post(s)
Liked: 57
Although the advice to listen before purchase is good, it is not always possible.
Both of the options you are considering are very good systems!
Between just the 2 systems you propose:
I would choose the KEF system, although it would come at higher cost in the U.S.. Either is capable of excellent performance.
DigsMovies is offline
post #10 of 19 Old 02-05-2012, 12:15 AM
datranz's Avatar
Quoted: 57 Post(s)
Liked: 40
I heard both and I really like the kef, I thought they image better. I found the sig to be a bit more open a more sensitive. I like the style and the finish on the kef more.
datranz is offline
post #11 of 19 Old 02-05-2012, 12:24 AM
Fanaticalism's Avatar
Fact of the matter is that there Paradigm owners outnumber Kef owners at least 12 to 1 on this site which is evident in the amount of owners in this forum recommending the digms with pretty ridiculous reasoning like Be tweeters.
I could easily say get the KEF as they have a flatter response both on and off axis, but what does that mean to the OP exactly (although my statement is more objective)?
If you ask me, since sound is subjective and you'll have no clue what they sound like, I would go for the product to be known for slightly better quality control, and that would be the KEF.
Fanaticalism is offline
post #12 of 19 Old 02-05-2012, 01:30 PM - Thread Starter
-BASO's Avatar
thanks for everyone
-BASO is offline
post #13 of 19 Old 05-10-2013, 08:02 AM
Sam Ash's Avatar
Quoted: 216 Post(s)
BASO - what did you eventually buy - KEF or Paradigm ?
Sam Ash is offline
post #14 of 19 Old 05-10-2013, 08:21 AM
AcuDefTechGuy's Avatar
Quoted: 175 Post(s)
Liked: 262
I would unequivocally get the KEF Reference.
KEF Reference or Revel Ultima.
AcuDefTechGuy is offline
post #15 of 19 Old 05-10-2013, 06:22 PM
Modicen's Avatar
Quoted: 84 Post(s)
Liked: 32
KEFs all the way, my humble opinion.
Modicen is online now
post #16 of 19 Old 05-10-2013, 06:26 PM
golfheaven79's Avatar
I own Sig 8's so therefore biased. I love them and would purchase them again without question.
golfheaven79 is offline
post #17 of 19 Old 05-11-2013, 01:05 AM
pinoy ako's Avatar
Liked: 26
I own Kef 3005SE, Kef R-Series and Kef Reference Series. Well, I am biased too..biggrin.gifbiggrin.gifbiggrin.gif
Anthem Statements | Kef Reference 205/2 | Kef LS50 | PSA Triple XS30SE | Panasonic AE8000 | Dalite 110" PJ Screen | CAPS V3 Zuma | Synology DS1512+ (15TB) | Cambridge Azur 651BD
pinoy ako is offline
post #18 of 19 Old 05-11-2013, 03:55 AM
jima4a's Avatar
Quoted: 275 Post(s)
Liked: 146
Which R series and which model Reference?
Main Kef: Reference 205/2 & 202/2c, Surrounds: Kef XQ40, Velodyne Optimum 12, Integra DHC 80.3, Ayre K-5xeMP, Oppo BDP-103, Bryston 4Bsst2, Parasound Halo A31. Second B&W: 685 (3), CCM618, Def Tech Powerfield 1500, Onkyo TX-NR1008, Zone 2 Klipsch AW650.
jima4a is offline
post #19 of 19 Old 02-19-2014, 11:24 AM
Tfleming675's Avatar
I have Kef and spent a lot of time testing both. BTW, I live in Canada and the KEFs are British and much less common in North America.
At the end of the day it comes down to what they sound like to you.
Pioneer SC-65
KEF, Q5 Front, Q9 Center, Q1 rear, Q800DS
Epson 3020 Projector, 135 in 235.1 screen
OPPO 103D, Apple TV, XBOX 360
Tfleming675 is offline
Reply Speakers
