Worth taking a drive for - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-02-2012, 09:04 PM - Thread Starter
dsaylor2008's Avatar
I've been looking for local used speakers without much luck. Anyway, I have a free afternoon and I'm trying to decide if I should spend over an hour each way driving to listen to one of the following speakers:
A pair of Snell CIII (possibly CIVs)-asking $300
A pair of Infinity Kappa Series II 6.1 (w/Kappa center)-would take $250
Both sets look great in pictures and I'm mainly looking for the option that would give me the best 2.1 setup.
If you were going to spend 3 hours driving, which one would you audition?
dsaylor2008 is offline
post #2 of 5 Old 02-02-2012, 10:34 PM
klh007's Avatar
Quoted: 37 Post(s)
I think the Snells are worth the drive, easy to drive, play loud & goes deep, less colored than the Kappas.
Kemper Holt
klh007 is offline
post #3 of 5 Old 02-03-2012, 02:45 PM - Thread Starter
Thanks KLH. I am leaning in that direction,but am having trouble getting in touch with the seller through audiogon.
As a point of reference would the Kappa 6.1s sound similar to current Infinity's
post #4 of 5 Old 02-03-2012, 02:49 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Snell
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #5 of 5 Old 02-03-2012, 02:56 PM
Venomous's Avatar
Kappas have some very intense bright highs for most too.
Venomous is offline
Reply Speakers
