$3000 budget; 5.1 speaker recommendations? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 23 Old 02-05-2012, 10:24 AM - Thread Starter
JMann2380's Avatar
Hello all,
I'm spending around ~$3500 on a new home theater. The receiver is gonna be the HK 3600 for $500 On closeout. The sub will likely be an outlet SVS, either tube or sealed for $1000ish, unless you have other suggestions?
So that leaves ~$2000 for fronts, center and surrounds. I like Klipsch if that gives you an idea of taste.. So bright.
My room is 11.5' x 23' x 8'h ceiling. Viewing distance is 9' with sectional against back wall, so surrounds will have to be on that back wall either mounted directly or with omnimounts.
Listening is 90% movies/ 10% music.
Any suggestions?
-Josh
JMann2380 is offline
post #2 of 23 Old 02-05-2012, 10:34 AM
smasher50's Avatar
Quoted: 379 Post(s)
Liked: 19231
5 chase home theater sho-10's $2000 or sho-10 and vs18.1 sub package-$ 3000
i'm so laid back,i'm laid out
smasher50 is offline
post #3 of 23 Old 02-05-2012, 10:38 AM
cel4145's Avatar
Quoted: 2668 Post(s)
Liked: 3002
+1
For a dedicated HT setup, seems like one of the best choices in your budget range.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | HE-400i | NAD HP50 | Sony MDR-1A | Soundmagic E50 & E80 | X5ii | DX50 | E12
cel4145 is offline
post #4 of 23 Old 02-05-2012, 10:53 AM - Thread Starter
JMann2380's Avatar
Thanks for the quick replies. I've been out of the game a while and hadn't heard of these. Seem to be well regarded. Problem is the center, I only have room for a 9" tall speaker in my tv stand. What's everyone doing about that, I'm sure it's a common issue.
post #5 of 23 Old 02-05-2012, 10:59 AM
cream puff's Avatar
i think you can do better than that harmon kardon for the 500 (i had one, replaced it with a marantz that i like much much better)
for the speakers kef q series sound outstanding and can be had within your budget.
cream puff is offline
post #6 of 23 Old 02-05-2012, 11:07 AM
zieglj01's Avatar
Quoted: 1714 Post(s)
Liked: 1632
Klipsch Reference - Tower
http://www.vanns.com/shop/servlet/it..._c=site_search
Center
Surrounds
__________________________________________
Who AM I
Speakers -- Canton GLS 2 > Boston VS240
Receiver -- Integra 50.2
zieglj01 is online now
post #7 of 23 Old 02-05-2012, 11:14 AM - Thread Starter
JMann2380's Avatar
The HK model is well regarded. Can you link some other suggestions?
post #8 of 23 Old 02-05-2012, 11:24 AM
zieglj01's Avatar
Liked: 1632
Also, take a look at the refurbish Denon
http://www.accessories4less.com/make...eceiver/1.html
Who AM I
post #9 of 23 Old 02-05-2012, 11:26 AM
madhuski's Avatar
Quoted: 650 Post(s)
Liked: 352
Hello all,
Any suggestions?
-Josh
I had a very similar budget ($2000 for a 5.0) and ended up going with the Boston Acoustic VS 260/325 series (thanks again Jim/Zieglj01 & phantomchess)
4 of the VS 260 bookshelf and 1 VS 325 center retail for $3700, but they are on closeout now from Vann's for $1350.
The center will fit under the 9 inch limitation you have. I use a corssover of 80, and find it blends very well with my SVS PC12-NSD. As a bonus, you'll come under budget by quite a bit (towards a better receiver/sub?)
Here are a few links to reviews of the series:
http://www.hometheater.com/content/b...speaker-system
http://www.soundandvisionmag.com/art...speaker-system
edited to add: just saw you like "bright". I would classify these as transparent, rather than bright (if that makes sense).
Selling in AVS Classifieds
Salk Songtower RT (RAAL)
URC MX-880 Remotes
madhuski is offline
post #10 of 23 Old 02-05-2012, 11:29 AM
AcuDefTechGuy's Avatar
Quoted: 175 Post(s)
Liked: 262
I would go for NHT Absolute system (Tower/Center/& Absolute Zero).
http://www.amazon.com/s/ref=sr_nr_se...qid=1328469563
Or KEF Q900/Q200C/Q100.
http://www.accessories4less.com/make...er-Each/1.html
http://www.accessories4less.com/inde...=kef+q&x=0&y=0
And for sub, I'd get 2 Rythmik FV12 subs @ $500 each.
http://www.rythmikaudio.com/FV12.html
AcuDefTechGuy is offline
post #11 of 23 Old 02-05-2012, 12:05 PM
the Son's Avatar
You mentioned liking Klipsch.
I recommend buying used Klipsch. I REALLY like the RF-83s and RC-64 center. I started with RF-82s and RC-62. They were great, but then I found some used 83s and 64. Absolutely no regrets.
If you're close, I'll let you have a listen.
Some bookshelves will probably be the best fit for surrounds in your layout. Maybe find a pair of RB-61s?
the Son is offline
post #12 of 23 Old 02-05-2012, 12:18 PM
coytee's Avatar
Quoted: 224 Post(s)
Liked: 363
I agree with the Son.
How's about being patient and nabbing some LaScalas over time? Guy in Indy has a 7.? all LaScala system and it's .... unreal.
Could be better with larger however, for the price/performance that you can get with LaScalas and the dynamics of all horn loaded .... ouch.
coytee is online now
post #13 of 23 Old 02-05-2012, 12:34 PM - Thread Starter
JMann2380's Avatar
http://www.hometheater.com/content/b...speaker-systemO
ok I'm digging these BA's. I'm a sucker for a good deal. I just wish they had them available in Cherry. Any idea where I could find them in that color?
post #14 of 23 Old 02-05-2012, 12:36 PM - Thread Starter
JMann2380's Avatar
Thx for all the suggestions! I just don't have the time or patience for used right now. I'm leaning towards the Bostons with KEF in second place for more money.
post #15 of 23 Old 02-05-2012, 12:41 PM
zieglj01's Avatar
Liked: 1632
The Boston's are on closeout - it seems that piano black, is the only
color left - and the piano black really looks sharp. They are real good
with movies, games and music. They will easily crossover to a good
subwoofer, and they can take the power and get loud.
Good Luck with your decision.
Who AM I
post #16 of 23 Old 02-05-2012, 08:31 PM
madhuski's Avatar
Quoted: 650 Post(s)
Liked: 352
VANN's has a 15 day return policy, so you can demo the Boston's and send them back (minus shipping) if you don't like them
Good luck!
URC MX-880 Remotes
madhuski is offline
post #17 of 23 Old 02-05-2012, 10:11 PM
the Son's Avatar
OK. That's my one regret. Not being patient. Not that the 82s/62 aren't great - they ARE!!
it's just that I found better, within my budget, and went with them instead. Now I have all kinds of extra Klipsch speakers sitting around the house.
the Son is offline
post #18 of 23 Old 02-06-2012, 08:31 AM
firebook23's Avatar
I would also look at brands like PSB Speakers and PAradigm... they offer great value for money as well
firebook23 is offline
post #19 of 23 Old 02-06-2012, 10:37 AM - Thread Starter
JMann2380's Avatar
I couldn't pass up the Boston Acoustics deal from Vann's. I wish I could have gotten in when they had the towers or the cherry finish, but for $1300 I picked up (4) VS-260's and the VS-325C center.
I just need to get my receiver and sub ordered and I'll be all set.
Thanks everyone for your help and madhuski for pointing me towards the deal.
post #20 of 23 Old 02-06-2012, 10:41 AM
zieglj01's Avatar
Liked: 1632
Good deal - have fun!
Make sure you feed them, with good clean power.
Who AM I
post #21 of 23 Old 02-06-2012, 01:28 PM
Kini62's Avatar
Quoted: 1746 Post(s)
Liked: 1558
I don't think he'll find more power and preamp outs for less.
Sure it lacks some of the whiz bang features and doesn't use audessy (which could be good thing for some), but it has a great amp, nice GUI and looks great.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #22 of 23 Old 02-06-2012, 02:18 PM
sagecounsel's Avatar
Jmann
Got in on the Vanns VS deals over Black Friday
Here's how it turned out with our room.
http://www.avsforum.com/avs-vb/showthread.php?t=1380682
You are going to be extremely happy
sagecounsel is offline
post #23 of 23 Old 02-06-2012, 04:32 PM
wattsiskey's Avatar
Right now, the NHT Classic 3 are on sale for $299 a piece, so I'd get 4 of those along with a ThreeC center for $499 which leaves about $300 for stands or wall mounts. The above is exactly what I will have once the 2 additional Classic 3's arrive that I just ordered. I also have 2 SW2 subs and a homemade 15" sub, 2 SuperOne presence and some Boston Acoustics that I will be moving from surrounds to surround rear.
wattsiskey is offline
Reply Speakers
