Suggestions for Speakers newly finished HT room in basement - AVS Forum | Home Theater Discussions And Reviews
post #1 of 36 Old 02-07-2012, 10:39 AM - Thread Starter
markdweasel's Avatar
I just finished my basement and got the following setup.
Open Concept basement -
1. HT room - 21'x13' - projector on 13' wall
2. Optoma HD33 projector ~13-14' from screen on ceiling
3. 120" Mustang motorized projection screen - mounted 6" from ceiling on bulkhead.
4. Denon 2112CI receiver
5. prewired for 7.1 surround.
6. PS3 for 3D content/gaming/movies.
7. HD cable box
My budget is not more than $2K for complete speaker solution including a sub. I have been looking @ Energy brand and here's what I came up with.
Surround ( both mid and backs):
Energy Connoisseur Surround Bookshelf Speaker (CR-10)
Energy Connoisseur Bookshelf Speakers (CB-20)
Center
Energy Veritas LCR Speaker (VMINICR)
Front:
Energy Reference Connoisseur 4-Way Tower Speaker (RC-70) - Black - Single
Not sure on Sub 8" or 10".
I am more into audio fidelity and quality of sound - clear, concise and rich. I don't need volume or power as my wife will simply kill me
Excellent Music listening is also something I'd like to have as well. Classical music is something we all enjoy.
Your feedback is most welcome and appreciated.
Thank you,
Mark
markdweasel is offline
post #2 of 36 Old 02-07-2012, 10:44 AM
NBR
NBR's Avatar
IMHO, you should get a bigger subwoofer.
NBR is offline
post #3 of 36 Old 02-07-2012, 10:47 AM
ambesolman's Avatar
Quoted: 1096 Post(s)
Liked: 919
7. HD cable box
Center
Front:
Thank you,
Mark
This should do you well. I have a pair of the HB-1s and love them, excellent for music and movies. My father has this set up (minus 2 speakers) in a 40x20x20 room and rocks it with no problem. I have the same sub in 25x15x8 room. This is an excellent system, period, but definitely at this price. Read around for reviews.
http://www.hsuresearch.com/products/enthusiast3.html
ambesolman is offline
post #4 of 36 Old 02-07-2012, 10:51 AM
eljaycanuck's Avatar
Quoted: 1343 Post(s)
Liked: 1956
+1. 12" at a minimum.
eljaycanuck is offline
post #5 of 36 Old 02-07-2012, 10:57 AM - Thread Starter
What don't you guys understand? My wife will kill me
I was originally going for a 10", conteplated an 8". Guess I'll have to tell my wife to get seriously good noise cancelling headphones and get the 10".
As for the surround speakers, I can get the CR-10s at the moment for $250 a piece. Should I get all 4 surround as CR-10s or should I mix and match CB-20 for the mid surrounds and put the CR-10s strictly for the rears?
Your help is much appreciated. Thanks for the prompt responses.
Mark
post #6 of 36 Old 02-07-2012, 11:01 AM - Thread Starter
One last thing....
should I get banana plugs for the receiver/speakers?
for receiver (6 pairs):
for speakers (6 pairs):
Will those work? I have no clue what the connections are like as my receiver is still in the box
Mark
post #7 of 36 Old 02-07-2012, 11:07 AM
Liked: 1956
Nah, she'll appreciate the fact that you bought the right-sized sub for the job.
I see that the CR-10s are $249/pr., and the CB-20s are $199/pr. You should audition them both and go with the ones you prefer.
(My preference would be for the CB-20s, although they would require stands, while the CR-10s would not.)
post #8 of 36 Old 02-07-2012, 11:11 AM
Liked: 1956
One last thing....
Banana plugs are a "nice to have" convenience feature. IMO, they're worth having. Get plugs, not pins. With thicker wire, the compression type can be a pain to screw together, so I prefer this type.
post #9 of 36 Old 02-07-2012, 11:12 AM
flickhtguru's Avatar
Liked: 111
Definitely a 12"+ subwoofer from an internet direct company. Since your budget is $2k, I would spend $1k on 7 speakers and $1-$1.2k on dual subs.
FYI, I spent $998 on dual subs and $980 on 7 speakers.
Shawn
flickhtguru is offline
post #10 of 36 Old 02-07-2012, 11:26 AM
commsysman's Avatar
Quoted: 1080 Post(s)
Liked: 567
First of all, you need a sub with a 12-inch woofer and at least 350 watts of power. It's not about volume. You can adjust the subwoofer volume control to suit you and the wee lady. It's about distortion. Smaller woofers do not have the cone size or power to reproduce frequencies below 50 Hz without excessive distortion. This is far more critical with music than movie-booms.
If you don't want to reproduce those frequencies you have no need for any subwoofer at all.
For the money you are going to spend, there are one hell of a lot of speakers that are much better than those Energy speakers (especially for your type of listening!).
I suggest Monitor Audio speakers:
The Bronze BX-5 tower speakers run about $750 per pair. The Bronze BX Center is $300 and will pair perfectly with them. The M1 speakers will be very good for the other four and cost $400 for the four speakers. $1450 total.
(NOTE- there is a company called M-audio that makes a BX-5; DIFFERENT COMPANY!)
To complete the system get the Rythmic FV-12 subwoofer for $500. This is a powerful clean-sounding subwoofer that will give plenty of bass in your room. The only way you would need two subs would be to simulate World War II in your room, and it doesn't sound like you want to go there. It is plenty for music.
This system will be miles ahead of the Energy speakers in sound quality IMO, and the Rythmic subwoofer is also very highly regarded for its price.
The Energy speakers are OK for people who just want to blast movies, but for those of us who care about the sound of music, particularly classical music, they are not what you want to listen to..
7. HD cable box
Center
Front:
Energy Reference Connoisseur 4-Way Tower Speaker (RC-70) - Black – Single
Thank you,
Mark
commsysman is offline
post #11 of 36 Old 02-07-2012, 11:51 AM
Kini62's Avatar
Quoted: 1691 Post(s)
Liked: 1507
+1. Great recommendation.
As for "needing" at least a 12" woofer and 350 watts.... that's rubbish advice.
Paradigm has a sub with 10" woofers that does 12hz at -3db so.......
A pair of SVS SB12s would do nicely for music and movies. Or Rythmik FV12s or Epik Legends...... they're are quite few options.
For 7 speakers for $1K it might be a little tougher. 5 for now would be easier to find at about $1K.
The HSU recommendation would be a good choice too.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #12 of 36 Old 02-07-2012, 11:56 AM
Liked: 111
I got the 7.0 BIC Acoustech Platinum 8" setup with 2 - Outlaw Audio LFM-1 Pluses.
Shawn
post #13 of 36 Old 02-07-2012, 12:03 PM - Thread Starter
Would these plugs fit the speakers or do I need the pins?
I would get all plugs if the speakers will take them.
Mark
post #14 of 36 Old 02-07-2012, 12:06 PM
Liked: 1956
As long as the speakers you buy have standard binding posts - and these days, they pretty much all do - plugs will fit them.
-- Edit --
Just looking at a pic of the back of the CR-10s and, with those speakers, pins might be better just in case the "well" the posts are in isn't deep enough to ensure that the plugs+wires won't interfere with wall mounting. For bookshelf speakers, towers and the AVR, I'd go with plugs.
post #15 of 36 Old 02-07-2012, 12:18 PM
Liked: 1956
+1. Some options include:
- the SVS PB12-NSD ($749), available in Canada through SonicBoomAudio.com;
- the Outlaw LFM-1 Plus ($549) or, when on sale, the LFM-1 EX (also $549); or
- the Epik Empire ($799).
post #16 of 36 Old 02-10-2012, 08:30 AM - Thread Starter
Monitor speakers? you have piqued my interest. Now, the problem is that I'm in canada. I wonder if they have a local shop where i can listen and buy them. I'm in Toronto so if anyone knows a local reseller/distributor, I'd love to check them out. If I can get the prices you've quoted and I like the sound, it would be an easy decision.
For the curious ones, I checked out the Energy Bookshelfs vs. the surround ones
I found the bookshelfs much cleaner sound with a greater range - sound was richer, especially the base. my only concern is the mounting.
Currently, I have the wiring set up for ceiling mount. Would you recommend a level shelf just below the ceiling or down firing mount?
I can always fish the wires to more of a wall mount - but I feel my wife wouldn't like it very much.
Recommendations?
Mark
post #17 of 36 Old 02-10-2012, 08:58 AM
pureiso's Avatar
Another route you could look at is DIY to extend the cash even further.
GR Research, Madisound, etc. have some amazing value if you do not mind soldering, building/buying cabinets, and turning a few screws.
As for recommendations, I always say a great 3.1 setup will beat a good 7.1 setup if you are looking for incredibly clear dialog or detailed music.
I personally recommend Rythmic subs for their direct servo design. Extremely low distortion.
Also, a note on the GR Research speakers. He has a tour of the bookshelves (N2X sealed design) that could possibly be auditioned in house. Just contact him and see if it is possible, nice guy I still have yet to buy anything from.
pureiso is offline
post #18 of 36 Old 02-10-2012, 09:13 AM
Liked: 1956
IMO, if you're wall-mounting the CB-20s...
- up high, use adjustable speaker mounts and angle them down toward the listening position;
- a couple of feet above the listening position, a level shelf would be fine.
Else, you can stand-mount them on either side of the listening position.
post #19 of 36 Old 02-10-2012, 10:22 AM
Eyleron's Avatar
Quoted: 267 Post(s)
Liked: 167
Will your wife let y'all listen to grand pianos, or only smaller pianos? String bass, or only cellos? Tubas, or only french horns?
Classical music has all sorts of instruments that have lower frequencies that an 8" cone will typically have trouble reproducing at even medium volumes, without distortion.
And the generalities about 8" vs 10" and 12" only go so far. There are other factors, like the excursion of the driver and its power handling, the size of the box, and the amount of power driving the woofer.
An 8" driver CAN reproduce low bass of those instruments (because even an ear bud can do that, at some volume), but to reach medium volumes on the dynamic peaks of classical music, the woofer would have to have so much excursion that the lowest sounds it puts out are distorted.
My 10" sub can produce down to 18Hz, but it's in a huge box.
A 12" has enough surface area it doesn't have to move in and out as much, and thus would probably exhibit less distortion, and it can use a smaller box.
SEOS Fusion 10 Max, 88 Special, Volt 10 LX, SVS PB10 and DIY SI18 subs, Denon X4000, JVC RS400 & 2.35:1 AT Screen
Eyleron is offline
post #20 of 36 Old 02-10-2012, 11:58 AM
smasher50's Avatar
Quoted: 376 Post(s)
Liked: 18463
a suggestion i would look into something like the hsu enthusiast 3 package for $1600
i'm so laid back,i'm laid out
smasher50 is offline
post #21 of 36 Old 02-10-2012, 12:42 PM
cel4145's Avatar
Quoted: 2662 Post(s)
Liked: 3001
Why don't you look at Paradigm, too, since you are in Canada? That's a Canadian company that makes great speakers. Maybe I'm wrong, but seems you ought to be able to get as good or better deals on them that we can get here in the US.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #22 of 36 Old 02-10-2012, 12:53 PM - Thread Starter
They sound interesting. Now, anywhere in Toronto area I can see them or possibly buy them?
I would hate to see how much they're going to ding me with taxes and duties if I elect to ship here.
Mark
post #23 of 36 Old 02-10-2012, 12:55 PM - Thread Starter
What's the overall recommendation here?
Which set of Paradigms would be ideal for my requirements & budget?
Obviously, best bang for the buck is my motto.
Thanks in advance.
Mark
post #24 of 36 Old 02-10-2012, 12:57 PM
kapone's Avatar
Quoted: 260 Post(s)
Liked: 209
Agreed. When it comes to subs, woofer surface/cone area is king. Hell, even a crappy but big sub will sound half way decent.
Which is why I have dual, dual 15" drivers. When we move into our new house, these get doubled...
kapone is offline
post #25 of 36 Old 02-10-2012, 01:07 PM
cel4145's Avatar
Liked: 3001
Thanks in advance.
Mark
I think that there are many Paradigm dealers in Canada (use their website to locate one). Just go in and see which ones you like, then come back and ask how they compare to other speakers you might consider
cel4145 is offline
post #26 of 36 Old 02-10-2012, 01:15 PM
smasher50's Avatar
Quoted: 376 Post(s)
Liked: 18463
Mark
you maybe sol because they are an on line company.it don't cost nothing to call and ask.
by the way i live in niagara falls n.y only an hour drive down q.e.w you could have them sent to my house and pick them up. lol
post #27 of 36 Old 02-10-2012, 01:22 PM
Eyleron's Avatar
Quoted: 267 Post(s)
Liked: 167
Do you mean they're "on line" as in, "they have a website," or "they are internet direct"?
They sell through brick and mortar dealers.
Eyleron is offline
post #28 of 36 Old 02-10-2012, 01:31 PM
Eyleron's Avatar
Quoted: 267 Post(s)
Liked: 167
I think one of the most confusing and biggest misconceptions in home theater is the exponential aspect of the decibel scale, and reaching the lowest frequencies.
People would be well served if they could easily see that this "stuff" exists, and it's VERY difficult to achieve properly.
Even large and expensive subs compress on the lower frequencies at high levels. And the dynamic peaks are truncated for most peoples speakers.
Eyleron is offline
post #29 of 36 Old 02-10-2012, 01:36 PM
smasher50's Avatar
Quoted: 376 Post(s)
Liked: 18463
they do have a web site and they are internet direct and they do not have dealers
post #30 of 36 Old 02-10-2012, 02:14 PM
Eyleron's Avatar
Quoted: 267 Post(s)
Liked: 167
Sorry, I thought one of us was going insane here. I had been reading on my phone and thought Mark's and your comment was about Paradigm. But I see it's about Hsu.
Eyleron is offline
Reply Speakers
