New setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 02-08-2012, 02:05 AM - Thread Starter
new2polkguy's Avatar
Ok I am new to polk world and just received part 1 (cs1 center speaker) of my new surround sound.....replacing old KLH satellite speakers. I am ordering Monitor 60's this week and possibly monitor 30s also. Any opinions would be appreciated. I think I am going to use 16Ga wire.And was wondering if my Kenwood VR-707 is still going to be ok with my very near future setup?? 100 watts per channel
new2polkguy is offline
post #2 of 15 Old 02-08-2012, 02:18 AM
Florida_Gator's Avatar
Quoted: 47 Post(s)
Liked: 50
You should be fine. I run MonitorII60s/CS20/R50s/R150s off a 75 WPC 7.1 receiver (Onkyo TX-SR505) with no trouble at all. I have them all set to "small", and the crossover set to 80hz on the receiver (Bic F12 sub). You'll need a sub if you don't have one. I started with all channels flat at "0", then bumped the center to +3 and surrounds to +2. Works for my room; YMMV.
Florida_Gator
Florida_Gator is offline
post #3 of 15 Old 02-08-2012, 08:08 AM
m_vanmeter's Avatar
Liked: 25
your setup will be fine, but you will want to add a powered subwoofer for the LFE (low frequency effects) channel. Amazon has the BIC F-12 on sale now (2/8/12)
my preference would be the front towers and sub first, then the surrounds when the budget allows (or Newegg has another great sale)
m_vanmeter is offline
post #4 of 15 Old 02-08-2012, 09:44 AM
cel4145's Avatar
Quoted: 2668 Post(s)
Liked: 3002
+1
Use your old KLH speakers for the rears until you can afford that upgrade later on. The BIC-F12 will add more to the HT experience.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | HE-400i | NAD HP50 | Sony MDR-1A | Soundmagic E50 & E80 | X5ii | DX50 | E12
cel4145 is offline
post #5 of 15 Old 02-08-2012, 11:29 AM - Thread Starter
Polk Audio PSW Series PSW505 12" I think I am waiting for this sub to come back in stock on new egg......Thanks for the opinions keep them coming
post #6 of 15 Old 02-08-2012, 01:17 PM
crazyrob425's Avatar
Quoted: 445 Post(s)
Liked: 339
You might end up waiting a long time
The best value for under $200 is the Bic F12
Your receiver will work though its alittle dated. The manual can be found here
Until you get a subwoofer you will have the Front set as Front LRG and the rest of the speakers to "... NML". When you get a center change the Monitor 60's to Front NML
Also given your receiver has no auto calibration might want to pick up an SPL meter from RadioShack!
crazyrob425 is offline
post #7 of 15 Old 02-08-2012, 01:31 PM
rwe416's Avatar
The Bic F12 is $188 at Amazon.
rwe416 is offline
post #8 of 15 Old 02-08-2012, 02:25 PM
commsysman's Avatar
Quoted: 1080 Post(s)
Liked: 569
!6 gauge wire is OK to 30 feet; past that use 14 gauge.
Sounds good except for the center. You should get the CS20 IMO. It will be better balanced relative to the Monitor 60s. It is a mistake to cheap out on the center speaker. You could also save some money by using the Monitor 50s for the front; with a subwoofer the slight difference is not going to be significant.
The PSW505 has been discontinued for over 6 months now, and the chance of getting any that are left for under $300 is pretty small. If you want it, I suggest you bite the bullet and spend $300.
commsysman is offline
post #9 of 15 Old 02-08-2012, 09:09 PM - Thread Starter
Ok I think I know what I am ordering now. Monitor 50s for the front, monitor 30s for the surround and bic f12 for my sub. I already have the cs1 for my center. What do you guys think?
post #10 of 15 Old 02-08-2012, 09:55 PM
Quoted: 445 Post(s)
Liked: 339
Not a bad set-up
Might want to look at newegg.com for the Monitor Series ii sales to get the biggest bang for your buck!
post #11 of 15 Old 02-08-2012, 10:53 PM
cel4145's Avatar
Liked: 3002
Originally Posted by crazyrob425 View Post
Not a bad set-up
Yep. Seems worth the little extra for the Monitor 60s over the 50s at the moment. The cheery finish 60s (promo code EMCNHNC28) are only $10 more each than the 50s through 2/13.
cel4145 is offline
post #12 of 15 Old 02-08-2012, 11:21 PM - Thread Starter
Been back and forth from 50s and 60s. One review says 50s and a good sub the next one says 60s. HA don't know. And new egg is where I have been looking/buying
post #13 of 15 Old 02-09-2012, 01:42 AM - Thread Starter
50s or 60s? $80 more to get the 60s
post #14 of 15 Old 02-09-2012, 05:01 AM
mde8965's Avatar
Quoted: 34 Post(s)
Did you look into this? If they are only $20/more then definitely go for the 60's. At $80/more I don't know. Look at newegg over the weekend...Also do a search for promo codes...
Main System: Denon AVR-4300h, LG OLED65C7, Oppo UDP-203, PS3 and PS4pro, Sonos Connect, Nvidia Shield tv (2017), Ascend RAAL Towers, RAAL Horizon Center, Sierra 2's (surround), 2 Rythmik F15's
2 other systems: 1 Onkyo, 1 Denon, Paradigm Studio V1 and V2 speakers, Panasonic Plasmas, etc.
mde8965 is offline
post #15 of 15 Old 02-09-2012, 07:40 AM
Quoted: 445 Post(s)
Liked: 339
At the monitor 60 sale price of $100 per speaker it's worth spending the extra doe IMHO
To the OP I am not sure where you are looking to buy from but you might want to hold out for a newegg.com sale
Reply Speakers
