Is the CMC2 wall mountable? - AVS Forum | Home Theater Discussions And Reviews
Old 02-09-2012, 11:44 PM - Thread Starter
iAusio80's Avatar
I am still deciding between 683s, CM8s and CM9s (top-end of budget). Honestly, pulling my hair sicne I have been sitting on this for a while. I even considered used 604 S3s
Either I'll end-up with HTM61/62 or CMC2 for center channel. In either case, floor stand is not an option. Wife just wouldn't approve as it will block the fireplace.
So, looking for wall mounting options. The fireplace is surrounded by a 1/2 to3/4 inch naked backer board (no tiles - don't ask me why, just decor ;-) which may help with wall mounting without studs.
Any suggestions? Thx!
iAusio80 is offline
Old 02-10-2012, 08:47 PM - Thread Starter
iAusio80's Avatar
iAusio80 is offline
Old 02-10-2012, 09:17 PM
Geoff4RFC's Avatar
Quoted: 317 Post(s)
Liked: 1573
It would be nice to see the area you have to work with.
Spinning the rear tire at 150mph while at 3/4 lean angle will put wrinkles in your seat
Set up:
Integra 70.4--Oppo 103--LG50"Plasma--Emotiva: XPA-3, XPA-2 x 2--PolkAudio: RTiA9 x 4--CSiA6--FXiA6 x 4--Epik: Empire x 2--XBOX 360--Furez 10awg homemade cables
Geoff4RFC is offline
Old 02-10-2012, 10:40 PM
CaTaSTrOphiK's Avatar
Quoted: 14 Post(s)
Have you seen these speakers???? You definitely CANNOT wall mount them. They need some space and they are fairly deep cabinets. Maybe you can build a nice shelf for it?? Well I'm sure you could one way or another mount them but I don't think you realize how goofy it would probably look.
CaTaSTrOphiK is offline
Old 02-11-2012, 11:01 AM
Geoff4RFC's Avatar
Quoted: 317 Post(s)
Liked: 1573
Yeah, my thought as well. the B&W center is too nice a speaker to be mounted to the wall. A nice stand (give wife mind change inducing drugs) or a cabinet of some kind would do these babies some justice.
Set up:
