6 ohm SX-WND7 full-range speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-10-2012, 10:28 AM - Thread Starter
David Haymond's Avatar
Send a message via Skype™ to David Haymond
I have a pair of Aiwa SX-WND7 speakers with built-in woofers. Each speaker has two wires, one for mid-to-high frequencies, and one for low frequencies. Both frequency ranges are rated at 6 ohms. The main unit that came with these speakers finally went out, and I would like to buy a new receiver, but I would like to reuse the speakers for front L and R if possible to save money, since the speakers have great sound and still work fine. I have several questions:
Most receivers seems to be rated at 8 ohms. Can I drive my 6-ohm speakers with an 8-ohm receiver?
Since each speaker has it's own built-in subwoofer, there are essentially two 6-ohm woofers to connect to the system. Can I use a Y-splitter to connect both woofers to the receiver, or will the receiver not be able to handle the load?
I would like to eventually get surround speakers, but I'm not sure when. Can I use a 5.1 receiver with only two speakers in case I decide not to buy surround speakers right away?
I will be using this system mostly for listening to classical music, and some movies. Is it a good idea to get a less expensive center and surround speakers?
Thanks in advance for your advice. I am looking to buy very soon, so I appreciate a quick reply.
David Haymond is offline
post #2 of 3 Old 02-27-2012, 08:36 AM
Hefty1620's Avatar
If and when someone answers your question could you pleas notify or tell em tha answer?
thanks
Hefty1620@comcast.net
Hefty1620 is offline
post #3 of 3 Old 07-15-2012, 10:29 AM
MarshallLaw's Avatar
Hi David. Would you be interested in selling those speakers? Even one would do the trick for me. Please repond at your earliest convenience. You can contact me at Amarshall2112@gmail.com.
MarshallLaw is offline
Reply Speakers
