Help a Newbie with $500 budget - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 02-17-2012, 07:08 AM - Thread Starter
viper20's Avatar
Hey Guys,
I have a small room that i am using for my home office. Room is approximately 13x8. I want to install a 5 channel system (I have a shiva x driver left from my HT project that i will build a sub for). I dont have a lot of room for tower speakers so i probably wont be able to utilize them. I will need something small for the office that will sound big I will be using the system for 100% music so home theater is not a concern. I want to try and stay around $500 for everything if possible, and i don't mind buying used speakers. So what do you guys recommend i should get for my situation?
Thanks much
viper20 is offline
post #2 of 13 Old 02-17-2012, 07:13 AM - Thread Starter
viper20's Avatar
I stumbled acroos this which seems to be a really good deal but what do you guys think?
http://www.newegg.com/Product/ComboD...bles-_-na-_-na
viper20 is offline
post #3 of 13 Old 02-17-2012, 07:19 AM
cjsiv's Avatar
Liked: 33
That room is relatively small. For 100% music I would go 2.1 and spend the $500 on 2 nice bookshelves to pair with the sub. I'm not much of a fan of 5.1 for music unless it's a concert DVD or bluray. Just my taste I guess.
I'm assuming the budget is just for speakers and you already have a receiver. If not, $500 for a receiver and 5 speakers will be mediocre at best, especially with music as the primary.
cjsiv is offline
post #4 of 13 Old 02-17-2012, 07:42 AM
commsysman's Avatar
Quoted: 983 Post(s)
Liked: 526
I would buy four NHT SuperZero speakers for $100 each if I wanted 4.1, but 2.1 would be fine for music. A center speaker is not needed for such a small room.
For 2.1 I would recommend a pair of Monitor Audio M2 speakers, for $270. I think that would be best in that size room.
You seem to have a sub in the works.
commsysman is offline
post #5 of 13 Old 02-17-2012, 07:52 AM
bigtim2000's Avatar
another newegg special:
Pioneer 821: $190
http://www.newegg.com/Product/Produc...82117397-L023D
Def Tech pro 60: $280
http://www.newegg.com/Product/Produc...82325104-L024C
Total: $470
I have heard the pro 60 package through reference sources at Abt and they are as good as the pro 600 package.
bigtim2000 is offline
post #6 of 13 Old 02-17-2012, 08:15 AM
cel4145's Avatar
Quoted: 2660 Post(s)
Liked: 2991
Agreed.
Unless you are buying SACDs instead of normal CDs, the music you will be listening to is 2 channel anyway.
I recommend considering the Energy RC-10s. Lotta love for them here on AVS for $300 (search the Energy owners thread).
As for a receiver, the Onkyo TX-NR509 or Harman Kardon AVR1600 is a good buy in your budget range.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #7 of 13 Old 02-17-2012, 08:21 AM
afrogt's Avatar
Quoted: 1058 Post(s)
Liked: 761
If this is for 100% music I wouldn't worry about 5.1. I'd get a nice 2.1 setup.
These Boston VS260 are highly recommended and only cost $500/pr vs their normal $1400 price.
http://www.amazon.com/Boston-Acousti...9491842&sr=8-1
http://www.avsforum.com/avs-vb/showthread.php?t=1393331
Afro GT
afrogt is online now
post #8 of 13 Old 02-17-2012, 08:34 AM
zieglj01's Avatar
Quoted: 945 Post(s)
Liked: 847
Originally Posted by afrogt View Post
if this is for 100% music i wouldn't worry about 5.1. I'd get a nice 2.1 setup.
These boston vs260 are highly recommended and only cost $500/pr vs their normal $1400 price.
http://www.amazon.com/boston-acousti...9491842&sr=8-1
x2
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is online now
post #9 of 13 Old 02-17-2012, 09:07 AM
afrogt's Avatar
Liked: 761
If that means for receiver and speakers then I need to amend my recommendation since I didn't account for a receiver.
Perhaps the Monitor Audio speakers recommended above or the Energy RC-10 for $299.
You could get a receiver like the HK 1600 for $229 and if you ever wanted to go 5.1 you'd have that type of receiver.
http://www.amazon.com/gp/product/B00...40K60QWMYKF79P
or just get a stereo receiver with subwoofer outputs.
http://www.amazon.com/Harman-Kardon-...9494790&sr=1-3
http://www.amazon.com/Onkyo-TX-8050-...9494841&sr=1-2
Afro GT
post #10 of 13 Old 02-17-2012, 09:32 AM
zieglj01's Avatar
Quoted: 945 Post(s)
Liked: 847
X2 again, if you can not swing for the for Boston
Who AM I
post #11 of 13 Old 02-17-2012, 09:53 AM
zieglj01's Avatar
Quoted: 945 Post(s)
Liked: 847
Now if you want to save
Boston CS speakers
http://www.accessories4less.com/make...-Cherry/1.html
Center
Surrounds
http://www.accessories4less.com/make...er-Each/1.html
http://www.accessories4less.com/inde..._query=b+oston
Who AM I
post #12 of 13 Old 02-17-2012, 10:13 AM
cel4145's Avatar
Liked: 2991
+1
I compared the HK 3390 and HK 1600 at home for a PC 2.1 setup. Pretty much the same SQ as far as I could tell. The 3390 has a little more volume output. Of course the advantage of the 1600 is bass management, HDMI, and optical inputs. But I ended up going with the 3390 because I didn't need those features in my PC setup.
However, I did not care for the sound of the Yamaha VX-R367, which I compared with the 1600 before getting the 3390 in. Could just be my preference for the HK sound, but then again I have a Denon I like, too.
cel4145 is offline
post #13 of 13 Old 02-17-2012, 12:24 PM
smasher50's Avatar
Quoted: 356 Post(s)
Liked: 15824
heres some suggestions if you want to buy used
focal chorus 806v $350 all on audiogon
LSA .5 $475
jamo c 803 $450
ascend acoustics cmt340se with stands $435
any of these would give you great sound in your size room and you can always bargain with the price
i'm so laid back,i'm laid out
smasher50 is online now
Reply Speakers
