5.1 setup for new HT, questions - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 39 Old 02-22-2012, 03:26 PM - Thread Starter
chaneyj1's Avatar
If I get them, I'll be sure to let you know.
I know there is a seperate Sub forum, but I thought I would keep this question on my current thread. In searching today, I noticed Rythmik sells a kit (DS1500) for around $600. This saves a good amount of money, and I am a pretty good wood worker. This seems like a no brainer to do this, or some other DIY sub, am I missing something?
chaneyj1 is offline
post #32 of 39 Old 02-22-2012, 03:44 PM
Dan Hitchman's Avatar
Quoted: 3414 Post(s)
Liked: 1767
I think you'd get an overall better sub for the money with the HSU VTF-15h. To build your own servo controlled subwoofer, it can be a bit daunting for the first time DIY'er.
If you screw things up, you're out $619.
Listen up, studios! Just say "NO" to DNR and EE!!
Dan Hitchman is offline
post #33 of 39 Old 02-24-2012, 06:28 PM - Thread Starter
chaneyj1's Avatar
You are probably correct. Ok, I am sold, VTF-15 it is.
On the surrounds, could I use something like the PSB CW50R for the surrounds? For one, the future wife will love the in-walls, and I like the $300 compared to $900. I know PSB makes the CW260, but those are more than the S5's.
Jeremie
chaneyj1 is offline
post #34 of 39 Old 02-24-2012, 06:56 PM - Thread Starter
chaneyj1's Avatar
What I am thinking about, is going to a 7.1 setup. I could put CW50R's in as the rears, and then CW50R's, or maybe CW60R's since they have pivoting tweeters, as the side surrounds.
Nice and wife friendly.
Jeremie
chaneyj1 is offline
post #35 of 39 Old 02-25-2012, 02:04 PM
Liked: 1767
I wouldn't go with the round in-walls. Their dispersal pattern would be "off" for a main home theater setup. Besides, those look like they're more for in-ceiling mounting for ambient sound in a kitchen or bedroom.
If at all possible, match your surrounds with their in-room counterparts for proper timbre matching. A PSB dealer should be able to tell you which ones have matching tweeters, other mid and lower frequency drivers, and crossovers. I don't see in-wall models that seem to match up with PSB's Image line, but I could be wrong.
Bipolar/dipolar surrounds for the sides, direct radiating speakers for the rears. You'll have a good mix of dispersed and direct surround ques.
The typical 7.1 layout is: side surrounds at 90 degrees to the main listening space, rears at 150. That's how many 8 channel soundtracks are monitored and mixed for.
post #36 of 39 Old 02-28-2012, 01:57 PM - Thread Starter
chaneyj1's Avatar
I posted my question to PSB and got this response.
"The CW50, CW60, CW80 and CW160R/S all match well to the Image line. The CW160R/S would be the best one.
Being that you pointed out the S5, have you seen the CW260 Model?"
Jeremie
chaneyj1 is offline
post #37 of 39 Old 02-28-2012, 05:45 PM
Liked: 1767
Jeremie
I have not, but you might want to ask them about their rectangular in-walls that match the Image line of in-room speakers (direct radiating and bipole surround).
Again, I don't recommend the round in-walls for a main home theater installation... only a secondary one for another A/V zone in a bedroom or living room where critical audio quality is not warranted.
post #38 of 39 Old 04-04-2012, 12:44 PM - Thread Starter
chaneyj1's Avatar
Just to finish this thread off, I have everything setup and it sounds great. The B6 fronts sound fantastic, and I feel the CW60's work fine as the rears and surrounds.
I went with the VTF-15H, but I still need to get it setup correctly. I found out my seating location is in the null spot in the middle of the room. I need to do a subcrawl and find a better spot for it. Dr. HSU suggested I put it directly behind my seating location, so I might try that too.
Thanks for everyones help,
Jeremie
chaneyj1 is offline
post #39 of 39 Old 04-04-2012, 02:12 PM
Liked: 1767
Jeremie
Great!
Tell us how you like it when it's all setup.
Reply Speakers
