Question on mounting Arx A1b's - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-23-2012, 02:42 PM - Thread Starter
Oiltrash's Avatar
Hello all, I'm in the process of building a front setup for my living room. 17x13.5 and 8' ceiling. I have a Denon 2112, and a Rythmik fv12 on its way. I'm wanting to run 2 A1b's as my left/right, but I'm kinda hesitant on spending $130 for the D-stands TAI offers. Came across some mounts and was wondering if using them to hang the a1b's next to the tv on the wall would be a good, cheaper alternative.
Oiltrash is offline
post #2 of 5 Old 02-23-2012, 02:43 PM - Thread Starter
Oiltrash's Avatar
Oiltrash is offline
post #3 of 5 Old 02-29-2012, 04:45 PM
SmokenAshes's Avatar
Liked: 53
I use these for my A1s for surround, working pretty good so far
SmokenAshes is offline
post #4 of 5 Old 02-29-2012, 05:56 PM
gtpsuper24's Avatar
Liked: 100
Yep I have been leaning toward a wall mount like those for my A1s too, for surround use.
gtpsuper24 is offline
post #5 of 5 Old 02-29-2012, 06:26 PM
Liked: 53
They work pretty good, real solid as long as you drill into the stud with the four screws it comes with. You could probably use dry wall anchor screws but it's not going to be as sturdy. It also comes with screws they drill into the speaker itself but their is no need because the clamp works really well.
Reply Speakers
