5.1 Surround placement (TV in corner) HELP! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 03-03-2012, 09:32 AM - Thread Starter
MattleyHD's Avatar
I have just bought a house with a basement. Pretty sweet setup. Though Ive never had my TV in a corner before. I really dont want to move it from the corner because it will eliminate room for a future wet bar and pool table. I just got a really nice leather theater style sectional that curves. I drew a picture of what im working with and what i believe is the best place for my speakers. I am just not sure if I should put the speakers on stands, on the wall at ceiling, or on the end tables. I have a somewhat budget system. A Pioneer VSX-520 receiver, polk audio rm7 satellite speakers (two front, to back, and center), and a polk audio ps-10 woofer. I am using 16 gauge wire. Could someone give me their input?
Attachment 239208
MattleyHD is offline
post #2 of 8 Old 03-03-2012, 09:44 AM
eljaycanuck's Avatar
Quoted: 1229 Post(s)
Liked: 1804
First off, congrats on the new home!
IMO, the location of your surrounds is fine, but placing them on the end-tables might set them too low relative to your ears when you're sitting down. I suggest either stands or tilt-and-swivel mounts so that you can wall-mount the surrounds and aim them at your listening position.
BTW, don't be surprised if your sub doesn't perform very well in that large basement (concrete floor) HT room. Once you lose "floor effect" (vibration transmitted through suspended-floor joists), the sub has to pressurize the entire room...and I don't think the PS(W?)10 is up to the task. On the bright side, that means: subwoofer upgrade!!
eljaycanuck is offline
post #3 of 8 Old 03-03-2012, 09:45 AM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Take a read/look for some info
http://www.infinitysystems.com/home/...rplacement.pdf
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is online now
post #4 of 8 Old 03-03-2012, 09:49 AM
DAB
DAB's Avatar
Quoted: 26 Post(s)
Read up on the room treatment thread- and get a calibration disc [free AVS download-here]- and RS meter- if you don't have auidyess.
DAB is offline
post #5 of 8 Old 03-03-2012, 11:28 AM
cavu's Avatar
Put the sub in the corner behind the TV.
"The greatest obstacle to discovery is not ignorance  it is the illusion of knowledge." - Daniel Boorstin
"Our lives begin to end the day we become silent about things that matter.
" - MLK
cavu is offline
post #6 of 8 Old 03-03-2012, 02:07 PM
Espo77's Avatar
Quoted: 179 Post(s)
Liked: 84
Personally, I don't like the idea of pointing the surround speakers directly at the listener. Often the surround information coming from them is intended to, NOT be localized.
Espo77's living room equipment: RECEIVER: Yamaha RX-A3030- SPEAKERS: Boston Acoustics M350, M25 center, surrounds, and front heights-
BLU-RAY: Oppo BDP103D- SUBWOOFER: HSU VTF-15H MK2- dedicated circuits for A/V- TV: Vizio P55C-1
Auralex Acoustics LENRD - Auralex Acoustics Roominator
Espo77 is offline
post #7 of 8 Old 03-03-2012, 02:12 PM
Liked: 1804
Okay, so don't point your surrounds at yourself.
post #8 of 8 Old 03-05-2012, 07:53 PM
Espo77's Avatar
Quoted: 179 Post(s)
Liked: 84
...but this is not about me, and what I prefer. It is about discovering the correct way to configure ones system for the most convincing sound in the average home theater...doing it right. That is ultimately what I want to achieve.
Espo77 is offline
Reply Speakers
