Problem with Yamaha Receivers - AVS Forum | Home Theater Discussions And Reviews
Old 03-06-2012, 11:37 PM - Thread Starter
astrallite's Avatar
Quoted: 25 Post(s)
Liked: 27
I've got two Yamaha Receivers in the house, one is an RX-A3000 and the other is an RX-V371. They are in two different rooms, but right next to each other (one opens up to the other--living room and family room).
The problem is when I use one remote to turn up volume or input, it affects both receivers, even though they are completely different models! Is there any way to "lock out" one remote from the other receiver?
astrallite is offline
Old 03-07-2012, 12:03 AM
kiwi2's Avatar
Quoted: 35 Post(s)
Liked: 160
Yep, if you go into 'advanced setup' by holding down the 'straight' button when you power on, you can change 'remote ID'.
kiwi2 is offline
Old 03-07-2012, 12:42 AM - Thread Starter
astrallite's Avatar
Quoted: 25 Post(s)
Liked: 27
The thing with that is, on the RX-V371, if I set it from Remote ID 1 to 2 in advanced setup, then neither the RX-A3000 OR the RX-V371 remote works...I still want the 371 remote to work :P
How do I make the RX-V371 remote work under Remote ID 2? Thanks
Old 03-07-2012, 01:17 AM
kiwi2's Avatar
Quoted: 35 Post(s)
Liked: 160
Do you have the manual for your 371?
There is a small 'code set' button on the remote. A 465 manual I have says... code set > setup > 5020 .. to set it to ID2.
kiwi2 is offline
Old 03-07-2012, 01:23 AM - Thread Starter
astrallite's Avatar
Quoted: 25 Post(s)
Liked: 27
Yeah thanks it worked. No more manual knob twisting. Cheers!
