Houston We have a problem - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 73 Old 03-08-2012, 11:19 PM - Thread Starter
Joshjp's Avatar
Quoted: 13 Post(s)
Liked: 115
HT~
PANASONIC TC-P50ST60, OPPO BDP-103D, ONKYO TX-NR818, PANAMAX MR4000, KLIPSCH RF-62's, RC-62, RS-52's, PSA TRIAX
2.1CH~
ADAM AUDIO F5's, EMOTIVA STEALTH DC-1, SVS SB-2000
Joshjp is offline
post #32 of 73 Old 03-08-2012, 11:30 PM - Thread Starter
Joshjp's Avatar
Quoted: 13 Post(s)
Liked: 115
The only thing is if you rotate the woofer the holes are all in the same place.
HT~
2.1CH~
Joshjp is offline
post #33 of 73 Old 03-09-2012, 08:48 AM
barryecohen's Avatar
Drill all the way through and use a T-Nut on the inside of the cabinet to hold a machine screw to hold the drivers in place and never worry about stripping out the particle board again
Click the pic...
So much media, so little time...
Oppo BDP-83 > Emotiva UMC-200 > Audio Alchemy OM-150 Dual Mono > Gallo Reference 3.5
_____________________________ > Audio Alchemy OM-150 > Gallo Strada
barryecohen is offline
post #34 of 73 Old 03-09-2012, 09:32 AM
chikoo's Avatar
Plug the holes using toothpicks, matchsticks, or like.
chikoo is offline
post #35 of 73 Old 03-09-2012, 10:32 AM
Reefdvr27's Avatar
Quoted: 1392 Post(s)
Liked: 908
Originally Posted by Pet Motel View Post
"Houston We have a problem"
Got a mouse in your pocket?
If the screw holes are stripped, you might get by with a toothpick pushed down in the hole and snapped off flush with the surface. You could also rotate the drivers if they are concentric and drill new holes.
I agree with a toothpick, but be careful, you can split the wood if your not careful.
Reefdvr27 is offline
post #36 of 73 Old 03-09-2012, 10:38 AM - Thread Starter
Joshjp's Avatar
Quoted: 13 Post(s)
Liked: 115
So i take some toothpicks and stuff them in the holes, then screw the screws in?.
HT~
2.1CH~
Joshjp is offline
post #37 of 73 Old 03-09-2012, 10:53 AM
Nethawk's Avatar
Liked: 117
OK, I just have to ask since nobody else has. Maybe I'm missing something in the normal process of installing new speakers, but my procedure would typically be to plug them in, have a listen then hop straight to Audyssey. Am I missing something by skipping the [apparently important] step of mucking with driver mounts?
Nethawk is offline
post #38 of 73 Old 03-09-2012, 01:04 PM
Geoff4RFC's Avatar
Quoted: 117 Post(s)
Liked: 1436
Yes, you're missing something. The speakers work, the driver mount is stripped.
Spinning the rear tire at 150mph while at 3/4 lean angle will put wrinkles in your seat
Set up:
Integra 70.4--Oppo 103--LG50"Plasma--Emotiva: XPA-3, XPA-2 x 2--PolkAudio: RTiA9 x 4--CSiA6--FXiA6 x 4--Epik: Empire x 2--XBOX 360--Furez 10awg homemade cables
Geoff4RFC is online now
post #39 of 73 Old 03-09-2012, 01:23 PM
From the factory?
post #40 of 73 Old 03-09-2012, 01:47 PM
Pet Motel's Avatar
Liked: 68
The OP says he bought the speakers used, there must have been a reason he checked the screws holding the drivers. Wouldn't be something the average speaker would have a problem with, and no you're not missing anything.
In my case with cabinets made of bamboo, I'm relatively certain the screws would fail before the bamboo would strip, the common MDF baffle needs to be handled with respect, it will certainly not do well with a heavy handed power driver.
Plenty of ways to skin this cat, the tee nuts are a good idea also, or you could also drill and tap for brass threaded inserts. You could fill the holes with JB weld, coat the screws with grease or vaseline, and screw them in once the epoxy first starts to set up (model airplane/helicopter builder here, I've done it many ways).
Heavily addicted SACDBA member, starting the twelve steps tomorrow!
Jay
Pet Motel is offline
post #41 of 73 Old 03-09-2012, 02:19 PM
Nethawk's Avatar
Liked: 117
I know, there was a level of sarcasm in my message. I would never have thought to check the screws holding my speakers together.
Nethawk is offline
post #42 of 73 Old 03-09-2012, 02:27 PM
Geoff4RFC's Avatar
Quoted: 117 Post(s)
Liked: 1436
Actually, that was my bad. I don't know if the OP ever mentioned that his speakers worked or not, just that he couldn't tighten the driver screws.
Your question was valid.
Set up:
post #43 of 73 Old 03-09-2012, 02:32 PM
sivadselim's Avatar
Quoted: 82 Post(s)
Liked: 107
Yeah, even bought used, I'd like to know why the OP felt the need to futz with his speakers. Were they noticeably loose? Or did you, perhaps, strip them yourself futzing with the speakers?
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is offline
post #44 of 73 Old 03-09-2012, 02:36 PM
zieglj01's Avatar
Quoted: 900 Post(s)
Liked: 805
Dip the ends of the toothpicks in wood glue - depending on the hole
size, you may need more than one - leave a little play room, so you
will not split the wood, when screwing back in. Break the toothpicks
off, and put the woofer back on - then screw it down, and be carefull
to not over tighten the screws.
__________________________________________
Who AM I
Speakers > MB Quart VS05, Boston VS260, Snell K7, EOS 150SP
Subwoofer > Mordaunt Short Aviano 7
Receiver > Tascam PAR-200, Pioneer VSX-30
zieglj01 is offline
post #45 of 73 Old 03-09-2012, 02:39 PM
sivadselim's Avatar
Quoted: 82 Post(s)
Liked: 107
bubble gum
post #46 of 73 Old 03-09-2012, 04:05 PM
Nethawk's Avatar
Liked: 117
Word.
Nethawk is offline
post #47 of 73 Old 03-09-2012, 06:38 PM - Thread Starter
Joshjp's Avatar
Quoted: 13 Post(s)
Liked: 115
ok thanks guys, at work we have some q-tips but there made out of wood, i might try that there about the same diameter at toothpicks.
HT~
2.1CH~
Joshjp is offline
post #48 of 73 Old 03-09-2012, 06:42 PM - Thread Starter
Joshjp's Avatar
Quoted: 13 Post(s)
Liked: 115
WHEN i unpacked them there were two screws laying in the box, and i tried to screw them in but they wer stripped, and there were more screws that were sticking out.
HT~
2.1CH~
Joshjp is offline
post #49 of 73 Old 03-09-2012, 07:09 PM
Nethawk's Avatar
Liked: 117
Hmm, have you verified they are the correct drivers? Very odd, that.
Nethawk is offline
post #50 of 73 Old 03-09-2012, 07:24 PM
zieglj01's Avatar
Quoted: 900 Post(s)
Liked: 805
Somebody has messed with that speaker - I have opened around 60 +
speakers, and have never found more than one or two stripped screws
per speaker - and Klipsch has always done a decent job with mounting.
Who AM I
zieglj01 is offline
post #51 of 73 Old 03-09-2012, 07:48 PM
Geoff4RFC's Avatar
Quoted: 117 Post(s)
Liked: 1436
Yeah somebody messed with it. OP said they were used and that he traded his RC-35 for them
Set up:
post #52 of 73 Old 03-09-2012, 08:30 PM
YeuEmMaiMai's Avatar
OK If you are for rotating the driver and re screwing it in you are going to have to do the same to the other speaker so that they look identical. This means taking your time and measuring and doing them both right.
Personally I would roate them so that they are 45 degrees from where they are now.
If any of the scew holes are stripped I would call into question their QC as I have never ran into a speaker that had stripped screw holes from the factory and I have been fixing things for 20+ years.
Strong or weak in the end we are all dead
YeuEmMaiMai is offline
post #53 of 73 Old 03-09-2012, 08:46 PM - Thread Starter
Joshjp's Avatar
Quoted: 13 Post(s)
Liked: 115
Im preaty sure there the correct drivers, i can take pics when i get home at 12:00am
HT~
2.1CH~
Joshjp is offline
post #54 of 73 Old 03-09-2012, 08:55 PM - Thread Starter
Joshjp's Avatar
Quoted: 13 Post(s)
Liked: 115
Mayby there the wrong screwa, does anybody have a close up of the Screws/Woofer.
HT~
2.1CH~
Joshjp is offline
post #55 of 73 Old 03-09-2012, 08:56 PM
sivadselim's Avatar
Quoted: 82 Post(s)
Liked: 107
post #56 of 73 Old 03-09-2012, 08:57 PM - Thread Starter
Joshjp's Avatar
Quoted: 13 Post(s)
Liked: 115
Yea if you rotate the driver, the holes and the driver match up.
HT~
2.1CH~
Joshjp is offline
post #57 of 73 Old 03-09-2012, 09:18 PM
Nethawk's Avatar
Liked: 117
LOL!! I think you and I are the only two laughing at the hilarity of this thread. I have to admit, I did think for .0005 seconds about rotating a perfect circle so that it matches another perfect circle.
Nethawk is offline
post #58 of 73 Old 03-09-2012, 09:32 PM
zieglj01's Avatar
Quoted: 900 Post(s)
Liked: 805
As the world turns!
Who AM I
zieglj01 is offline
post #59 of 73 Old 03-09-2012, 09:42 PM
zieglj01's Avatar
Quoted: 900 Post(s)
Liked: 805
OK guys, at work today i asked are machanic, and he said to fill the holes with EPOXY, and drill the holes again, then screw in the screws, i hope it WORKS.
Maybe you should get the mechanic at work, to help you.
Who AM I
zieglj01 is offline
post #60 of 73 Old 03-09-2012, 11:31 PM
I'll make this simple for you two.
The screw holes are at 45 degrees, 135 degrees 210 degrees and 305 degrees. Rotating your speaker 45 degrees would result in your new holes being at 0 degrees, 90 degrees, 180 degrees, and 270 (assuming you divide the circular opening into 360 degrees).
Now don't you think it would look odd with 2 identical speakers having the woofers installed with different mounting points?
I am sure that if you actually took just .00001 second longer, you would have understood what I was saying...
But alas, I digress as the speakers cannot be rotated if these are indeed as pictured below (courtesy of Kilpsch website) so the OP will have to restort to other means to solve the issue at hand.
Reply Speakers
