Houston We have a problem - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 73 Old 03-10-2012, 12:31 AM
Fastslappy's Avatar
Liked: 749
buy 1/2" wood dowel ,buy 1/2" wood drill bit . drill out the stripped holes ,then cut dowel in to lengths about as thick as the cabinet walls (stubby little barrels of 1/2" wood) then wood glue the barrels into the 1/2" holes you drilled wait 2 days for glue to set .MARK THE HOLES , use the driver & a felt pen to mark the holes / then drill small holes slightly smaller than the screw size & then thread the screws in & DO NOT OVER TIGHTEN THE SCREWS . whoooH yer done !
Very important that you wait 2 days for the wood glue to set up !!! it must be rock hard
Mike
JAZZ IS NOT DEAD IT JUST SMELLS FUNNY ; FRANK ZAPPA
Fastslappy is offline
post #62 of 73 Old 03-10-2012, 01:12 AM - Thread Starter
Joshjp's Avatar
Quoted: 13 Post(s)
Liked: 115
thank you
HT~
PANASONIC TC-P50ST60, OPPO BDP-103D, ONKYO TX-NR818, PANAMAX MR4000, KLIPSCH RF-62's, RC-62, RS-52's, PSA TRIAX
2.1CH~
ADAM AUDIO F5's, EMOTIVA STEALTH DC-1, SVS SB-2000
Joshjp is offline
post #63 of 73 Old 03-10-2012, 01:29 AM
Nethawk's Avatar
Liked: 118
Originally Posted by YeuEmMaiMai View Post
I'll make this simple for you two.
The screw holes are at 45 degrees, 135 degrees 210 degrees and 305 degrees. Rotating your speaker 45 degrees would result in your new holes being at 0 degrees, 90 degrees, 180 degrees, and 270 (assuming you divide the circular opening into 360 degrees).
Now don't you think it would look odd with 2 identical speakers having the woofers installed with different mounting points?
I am sure that if you actually took just .00001 second longer, you would have understood what I was saying...
But alas, I digress as the speakers cannot be rotated if these are indeed as pictured below (courtesy of Kilpsch website) so the OP will have to restort to other means to solve the issue at hand.
Yes, it doesn't work like that. I thought this was obvious.
Nethawk is offline
post #64 of 73 Old 03-10-2012, 03:33 AM
sivadselim's Avatar
Quoted: 162 Post(s)
Liked: 154
Oh, thanks!
No, I don't think it would look odd. Especially behind a grill. But why 45°? If the speaker were circular, all you would have to do is rotate it a few degrees in order to move the screw holes.
Why waste any more time?
Uh, yeah.......... exactly.
This was already discussed earlier in the thread, btw.
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is offline
post #65 of 73 Old 03-10-2012, 08:59 AM
chikoo's Avatar
Originally Posted by Nethawk View Post
LOL!! I think you and I are the only two laughing at the hilarity of this thread. I have to admit, I did think for .0005 seconds about rotating a perfect circle so that it matches another perfect circle.
really? I am the one who posted the picture to show the hilarity of rotating a square speaker
chikoo is offline
post #66 of 73 Old 03-10-2012, 12:24 PM - Thread Starter
Joshjp's Avatar
Quoted: 13 Post(s)
Liked: 115
YAYYYY i fixed the problem, i just used toothpicks, and it works, BIG THANKS to everyone who helped me. Hooked them up and they sound pretty good, but not as good or as loud as my RB-61's, so i might sell them, if anybody wants them and lives in the Minneapolis/Saint Paul, MN area, ill give you a good deal.
HT~
2.1CH~
Joshjp is offline
post #67 of 73 Old 03-10-2012, 04:02 PM
Geoff4RFC's Avatar
Quoted: 317 Post(s)
Liked: 1573
Dude, that was a rock star suggestion
Mucho congracion, most entertaining thread.
Spinning the rear tire at 150mph while at 3/4 lean angle will put wrinkles in your seat
Set up:
Integra 70.4--Oppo 103--LG50"Plasma--Emotiva: XPA-3, XPA-2 x 2--PolkAudio: RTiA9 x 4--CSiA6--FXiA6 x 4--Epik: Empire x 2--XBOX 360--Furez 10awg homemade cables
Geoff4RFC is offline
post #68 of 73 Old 03-10-2012, 07:06 PM - Thread Starter
Joshjp's Avatar
Quoted: 13 Post(s)
Liked: 115
HT~
2.1CH~
Joshjp is offline
post #69 of 73 Old 03-11-2012, 03:30 AM
losservatore's Avatar
Quoted: 2298 Post(s)
Liked: 2046
awesome thread we need more threads like this one lol
Living Room :Oled 65" B6 / Marantz SR7010 / Xbox One S / PS4 Pro / HTPC / 2 PSA XS30 / Revel Performa3 F206 / Revel Performa3 C205 / Revel Surrounds / Sonos Connect / Roku 4 Ultra /Amazon Fire tv /
losservatore is offline
post #70 of 73 Old 03-11-2012, 07:38 AM
Reefdvr27's Avatar
Quoted: 1564 Post(s)
Liked: 1038
Science now proves, you cannot fit a square peg in a round hole!
Reefdvr27 is offline
post #71 of 73 Old 03-11-2012, 03:37 PM
Pet Motel's Avatar
Liked: 68
Houston, the Eagle has landed! I guess it wasn't "rocket science" after all! Toothpicks, and a little superglue can work wonders, almost as handy as a roll of duct tape !
Heavily addicted SACDBA member, starting the twelve steps tomorrow!
Jay
Pet Motel is offline
post #72 of 73 Old 03-11-2012, 03:40 PM - Thread Starter
Joshjp's Avatar
Quoted: 13 Post(s)
Liked: 115
Yea i agree, i personally thought the toothpics would never work.
HT~
2.1CH~
Joshjp is offline
post #73 of 73 Old 03-11-2012, 05:03 PM
chashint's Avatar
Quoted: 18 Post(s)
Liked: 54
That is about the most common way to fix stripped screw holes in wood or wood products.
Probably been around since wood screws were invented.
Charlie
chashint is offline
Reply Speakers
