Houston We have a problem - AVS Forum
post #1 of 73 Old 03-07-2012, 09:34 PM - Thread Starter
Joshjp's Avatar
Liked: 114
Well i just got a pair of Klipsch RB-3's, and none of the screws that hold the speaker tighten, all they do is keeeeeeep spinning and spinning, is there a way to fix this? THANKS.
HT~
PANASONIC TC-P50ST60, OPPO BDP-103D, ONKYO TX-NR818, EMOTIVA XDA-2, PANAMAX MR4000, KLIPSCH RF-62's, RC-62, RS-52's, PSA TRIAX
2.1CH~
ADAM AUDIO F5's, EMOTIVA STEALTH DC-1, SVS SB-2000
Joshjp is offline
post #2 of 73 Old 03-07-2012, 09:41 PM
Geoff4RFC's Avatar
Liked: 1364
Hold the speaker tighten? Can you be a tad bit more specific? Is the terminals where you screw down on the speaker wire, or the speaker drivers themselves?
Spinning the rear tire at 150mph while at 3/4 lean angle will put wrinkles in your seat
Geoff4RFC is offline
post #3 of 73 Old 03-07-2012, 09:44 PM - Thread Starter
Joshjp's Avatar
Liked: 114
its the speaker driver, i think its the wood, were the screws go in, they don't tighten.
HT~
2.1CH~
Joshjp is offline
post #4 of 73 Old 03-07-2012, 09:48 PM
Geoff4RFC's Avatar
Liked: 1364
Hmmmm, maybe stripped threads in the driver. Can you remove the screws completely?
If so, try pulling out the driver and seeing if the screws will tighten down all the way.
post #5 of 73 Old 03-07-2012, 09:51 PM - Thread Starter
Joshjp's Avatar
Liked: 114
Yea i think i can get them all out, i got most of them out, will post back in a min.
HT~
2.1CH~
Joshjp is offline
post #6 of 73 Old 03-07-2012, 09:56 PM
Pet Motel's Avatar
Liked: 63
"Houston We have a problem"
Got a mouse in your pocket?
If the screw holes are stripped, you might get by with a toothpick pushed down in the hole and snapped off flush with the surface. You could also rotate the drivers if they are concentric and drill new holes.
Heavily addicted SACDBA member, starting the twelve steps tomorrow!
Jay
Pet Motel is offline
post #7 of 73 Old 03-07-2012, 09:57 PM - Thread Starter
Joshjp's Avatar
Liked: 114
Ok so got all of the screws out, and pulled out the driver, and screwed the bolts in to the wood without the driver in place, and it keeps spinning.
HT~
2.1CH~
Joshjp is offline
post #8 of 73 Old 03-07-2012, 09:59 PM - Thread Starter
Joshjp's Avatar
Liked: 114
[quote=Pet Motel;21750084]"Houston We have a problem"
never heard that before, what does it mean.
HT~
2.1CH~
Joshjp is offline
post #9 of 73 Old 03-07-2012, 10:00 PM
Geoff4RFC's Avatar
Liked: 1364
If it's stripped, wouldn't it be the driver that's stripped?
post #10 of 73 Old 03-07-2012, 10:01 PM - Thread Starter
Joshjp's Avatar
Liked: 114
its the wood that's stripped.
HT~
2.1CH~
Joshjp is offline
post #11 of 73 Old 03-07-2012, 10:03 PM
Geoff4RFC's Avatar
Liked: 1364
Okay, pet motels idea should work for rotating and drilling new holes should work for you?
post #12 of 73 Old 03-07-2012, 10:04 PM
zieglj01's Avatar
Quoted: 99 Post(s)
Liked: 370
Rotate the driver and drill new screw holes - or break off a couple of
toothpick pieces and glue them in each hole, with something like the
Tighbond wood glue.
__________________________________________
Who and Where - is the Way, the Truth and the Life?
Speakers > MB Quart VS05, Boston VS260, Snell K7
Subwoofer > Mordaunt Short Aviano 7
Receiver > Tascam PA-R200, Pioneer VSX-30
zieglj01 is online now
post #13 of 73 Old 03-07-2012, 10:04 PM - Thread Starter
Joshjp's Avatar
Liked: 114
Did you try screwing them into just the driver while it was out?
No, just the wood.
HT~
2.1CH~
Joshjp is offline
post #14 of 73 Old 03-07-2012, 10:05 PM
Pet Motel's Avatar
Liked: 63
[quote=Joshjp;21750090]
You said "WE have a problem", who are the "we"?
Jay
post #15 of 73 Old 03-07-2012, 10:06 PM - Thread Starter
Joshjp's Avatar
Liked: 114
[quote=Pet Motel;21750112]
The royal WE
HT~
2.1CH~
Joshjp is offline
post #16 of 73 Old 03-07-2012, 10:06 PM
Geoff4RFC's Avatar
Liked: 1364
Also, if they're brand new since you just picked them up, could you return them easy enough? Which scenario seems better to you?
post #17 of 73 Old 03-07-2012, 10:08 PM - Thread Starter
Joshjp's Avatar
Liked: 114
There used, i traded my RC-35 for them.
HT~
2.1CH~
Joshjp is offline
post #18 of 73 Old 03-07-2012, 10:17 PM - Thread Starter
Joshjp's Avatar
Liked: 114
I just watched a video and they said to use a wall anchor, do you guys think it will work?...
HT~
2.1CH~
Joshjp is offline
post #19 of 73 Old 03-07-2012, 10:33 PM - Thread Starter
Joshjp's Avatar
Liked: 114
I just wanted to say thanks for all the help guys.
HT~
2.1CH~
Joshjp is offline
post #20 of 73 Old 03-07-2012, 10:47 PM
Geoff4RFC's Avatar
Liked: 1364
Hey Josh, that wall anchor sounds like a great idea. I'm sure you can get a small enough on that will fit snug and work perfect.
Anytime brother.
post #21 of 73 Old 03-07-2012, 10:51 PM
cel4145's Avatar
Quoted: 34 Post(s)
Liked: 636
Tighbond wood glue.
+1
Old tried and true method for filling back in a stripped wood hole
cel4145 is online now
post #22 of 73 Old 03-07-2012, 10:56 PM - Thread Starter
Joshjp's Avatar
Liked: 114
yea i going to try to find one that fits. i hope it works.
HT~
2.1CH~
Joshjp is offline
post #23 of 73 Old 03-07-2012, 11:01 PM - Thread Starter
Joshjp's Avatar
Liked: 114
do you guys think i should get a pair of rs-42 for my surrounds? as of now i use a pair of rb-61's.
HT~
2.1CH~
Joshjp is offline
post #24 of 73 Old 03-08-2012, 07:51 PM - Thread Starter
Joshjp's Avatar
Liked: 114
OK guys, at work today i asked are machanic, and he said to fill the holes with EPOXY, and drill the holes again, then screw in the screws, i hope it WORKS.
HT~
2.1CH~
Joshjp is offline
post #25 of 73 Old 03-08-2012, 08:15 PM
zieglj01's Avatar
Quoted: 99 Post(s)
Liked: 370
I have done that more than once.
post #26 of 73 Old 03-08-2012, 08:19 PM - Thread Starter
Joshjp's Avatar
Liked: 114
Did it work for you?.
HT~
2.1CH~
Joshjp is offline
post #27 of 73 Old 03-08-2012, 08:20 PM
zieglj01's Avatar
Quoted: 99 Post(s)
Liked: 370
Yes
post #28 of 73 Old 03-08-2012, 08:20 PM - Thread Starter
Joshjp's Avatar
Liked: 114
He was also thinking of putting the EPOXY in the holes, then right away put the speaker in, then i could leave the screws in like that.
HT~
2.1CH~
Joshjp is offline
post #29 of 73 Old 03-08-2012, 08:21 PM - Thread Starter
Joshjp's Avatar
Liked: 114
How did you do it?.
HT~
2.1CH~
Joshjp is offline
post #30 of 73 Old 03-08-2012, 08:37 PM
zieglj01's Avatar
Quoted: 99 Post(s)
Liked: 370
How did you do it?.
You rotate the woofer - then get a marker and make a mark through
the woofer screw hole on the woofer, so you will know where to drill.
Take the woofer out, fill the old holes with puddy to prevent air leaks.
Then drill the new screw holes - put the woofer back in and screw it
down, be carefull not to over tighten it.
Or, do it this way - do not use epoxy
http://www.colomar.com/Shavano/cons_stripped.html
Reply Speakers
User Tag List
