Can In-Ceiling speakers be used as In-Wall? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-10-2012, 12:31 PM - Thread Starter
jmsnyc's Avatar
Quoted: 18 Post(s)
I am buying speakers for my mother. She is far from an audiophile and I am looking at speakers in the $50 to $90 price range. She prefers round to rectangular.
Round speaker products on the market are generally ceiling and rectangular are generally wall which is why I ask this question - if ceiling can be used in wall. According to Audiosource FAQ the answer is yes but I figured I'd ask here to be sure.
I was originally looking at the Audiosource AC8C which I ordered for a great price from J&R ($69 for the pair), I thought it was a price mistake - now they are $99 for the pair and even higher elsewhere. The problem is JR have them backordered with no estimated shipping date.
I am also looking at the Yamaha IW360C
http://www.amazon.com/Yamaha-NS-IW36...1407091&sr=8-1
J&R has these for $79 direct, and I am thinking I can get them to pricematch my original Audiosource order since they are backordered and get them for $69. I know the Yamahas are 6 Ohm and the Audiosource were 8 - not sure if that makes a difference
Appreciate any opinions.
jmsnyc is offline
post #2 of 3 Old 03-10-2012, 01:25 PM
m_vanmeter's Avatar
yes, round "in-structure" speakers can be used in walls or ceilings. The advantage the rectangular speakers is two or more actual separate speakers in the enclosure and larger speakers as well. That said, if round enclosures is what is wanted, try for the larger round enclosures with 5" or 6" mid/woofer speakers and all should be well.
Remember, you will need to get speaker wiring into the wall cavity and up to the speakers.
m_vanmeter is offline
post #3 of 3 Old 03-10-2012, 02:05 PM
losservatore's Avatar
Quoted: 2300 Post(s)
Liked: 2047
you can get the Energy RC-6C for 49.97 each
from this online authorized stores
tiger direct
http://www.tigerdirect.com/applicati...433&CatId=5700
compusa
http://www.compusa.com/applications/...433&CatId=5700
circuit city
http://www.circuitcity.com/applicati...433&CatId=5700
Here is the owner manual
http://a248.e.akamai.net/pix.crutchf...32/732RC6C.PDF
Living Room :Oled 65" B6 / Marantz SR7010 / Xbox One S / PS4 Pro / HTPC / 2 PSA XS30 / Revel Performa3 F206 / Revel Performa3 C205 / Revel Surrounds / Sonos Connect / Roku 4 Ultra /Amazon Fire tv /
losservatore is offline
Reply Speakers
