Bose 901 VI, havent found the right amp - Page 7 - AVS Forum | Home Theater Discussions And Reviews
post #181 of 222 Old 02-18-2013, 05:49 PM
taichi4's Avatar
Quoted: 354 Post(s)
Liked: 166
Originally Posted by JerryLove View Post
Indirect lighting is certainly not uncommon.
And heavy use of reflected sound is something you'll find in a lot of designs (Ohm, Martin Logan, Magipan, half of everyone's surround speakers, etc). I'm not defending the 901, but the premise that reflected sound can add positively to the experience is reasonable.
And I'm not sure of how they do the crossover: but since their drivers are about big enough that a single one could do midrange; it's possible that the wall-facing drivers are mainly for LF extension.
I'm pretty sure that the 901s have no crossover. The identical drivers cover the same frequency range. From what I read elsewhere, the nine drivers in aggregate average out the random resonances that each individual driver produces, helping to produce a more even response curve.
Now the spectral information that the reflecting speakers produce are not lost in rooms with reflecting surfaces, but are presented with delays relative to the direct facing driver output. So your ears essentially receive all the sound energy, with minute delays. The direct driver (essentially without delays) provides sound localization.
You would only lose the reflected energy if absorptive materials are used in the room.
In the case of indirect light if you use enough light energy you can read by indirect light (unless dark surfaces are absorbing it), but essentially in most circumstances you want a narrow beam focused on the page. Compared to the eyes, the ears are faced outwards picking up sound from a much wider area, so the total acoustic energy is received and interpreted even when the majority of it is indirect (reflected)..
taichi4 is offline
post #182 of 222 Old 02-18-2013, 06:02 PM
JerryLove's Avatar
Liked: 82
I'd be worried about very basic stuff: like comb filtering.
Now the spectral information that the reflecting speakers produce are not lost in rooms with reflecting surfaces, but are presented with delays relative to the direct facing driver output. So your ears essentially receive all the sound energy, with minute delays. You would only lose the energy if absorptive materials are used in the room.
Most materials absorb in some frequencies.
In the case of indirect light if you use enough light energy you can read by indirect light (unless dark surfaces are absorbing it), but essentially in most circumstances you want a narrow beam focused on the page. Compared to the eyes, he ears are faced outwards picking up sound from the a much wider area, so the total acoustic energy is received and interpreted even when the majority of it is indirect (reflected)..
The building I work in is lit with indirect lighting. It's an office.
My family room is also indirect (those 300w halogens you can buy at Walmart... direct would be literally (if temporarily) blinding.
JerryLove is offline
post #183 of 222 Old 02-18-2013, 06:26 PM
taichi4's Avatar
Quoted: 354 Post(s)
Liked: 166
...Most materials absorb in some frequencies.
As I mentioned, indirect lighting, if the total amount of light output is high, will light up a page as much as a less radiant, but focused light source. I'm no enemy of indirect lighting!
If a room has hard reflecting surfaces little sound energy is absorbed.
A quick net search:
"For this reason, acoustically minded builders of auditoriums and concert halls avoid the use of hard, smooth materials in the construction of their inside halls. A hard material such as concrete is as dissimilar as can be to the air through which the sound moves; subsequently, most of the sound wave is reflected by the walls and little is absorbed. "
http://www.physicsclassroom.com/Class/sound/U11L3d.cfm
Regarding the comb filter effect comment, I was just addressing your remark by pointing out that the 901s do not use crossovers, not discussing the potential negative effects of systems employing a high degree of reflection.
However. comb filter effects are likely reduced by positioning the 901s close to the walls (as Bose recommends), because you are thereby introducing less complex reflections, minimizing the reinforcement and cancellation effects that produce the comb filter phenomenon.
taichi4 is offline
post #184 of 222 Old 02-18-2013, 06:53 PM
JerryLove's Avatar
Liked: 82
Comb filtering is unavoidable when two drivers have part of their surface more than 1/4 wavelength of a frequency they are both producing (unless they have an almost complete lack of off-axis output, or there's a baffle in excess of 1/4 wavelength in between (or is that 1/2 wavelength)).
A *lot* is done in crossovers and speaker design for line arrays to reduce this effect.
post #185 of 222 Old 02-18-2013, 07:10 PM
taichi4's Avatar
Quoted: 354 Post(s)
Liked: 166
Understood, but crossovers introduce their own problems.
Now a speaker design like the Walsh full range driver is crossover-less, and doubtlessly produces cancellation and reinforcement effects, as it radiates omnidirectionally, but in my experience sounded better than any other speaker I've ever heard.
taichi4 is offline
post #186 of 222 Old 02-18-2013, 07:36 PM
Bill Fitzmaurice's Avatar
Liked: 5684
So do contour networks. Rule #1 of acoustical engineering is that there's no such thing as a free lunch. What the Bose gains by having no crossover it gives back with the necessity of a contour network, and the narrow HF dispersion that results from having no tweeter. Comb-filtering doesn't occur with the 901, as the eight drivers that do comb-filter are facing the wall, but the downside there is the vague imaging that also results from so doing.
Bill Fitzmaurice is offline
post #187 of 222 Old 02-18-2013, 07:52 PM
taichi4's Avatar
Quoted: 354 Post(s)
Liked: 166
Once again, no argument.
My speaker of choice is the Walsh design, followed by BMRs (balanced Mode Radiators).
taichi4 is offline
post #188 of 222 Old 02-19-2013, 06:10 PM
darthray's Avatar
Quoted: 1163 Post(s)
Liked: 1063
Understood.
Hail Alberta, Canada...and Canada in general. I've always had a good time there...as far East as Nova Scotia,
and West as Toronto (not far west). Now I live in LA, yet have never been up to Western Canada. wink.gif
How's the healtcare plan in Alberta?
It must suck to be stuck in California:)
Sound like You pay attention to Politic abroad.
The richest Province in Canada and pay the most in healthcare and only get half the services of other Provinces.
I do not have a problem as far of services, but way too much money spend on managment.
Now back to Audio topics.
All the best.
Ray
darthray is offline
post #189 of 222 Old 02-20-2013, 06:09 AM
dat56's Avatar
Amen to that! The thing is, everyone is so conditioned by the ubiquitousness, if that's a word:) of crossovers and multi-band speaker systems that their deleterious effects are not even noticed. They are just accepted because most people don't hear any alternatives.
I had the opportunity a number of years ago to buy a mint, used pair of Ohm F's for $400. I passed, and have regretted it many times since.
dat56 is offline
post #190 of 222 Old 02-20-2013, 08:56 AM
taichi4's Avatar
Quoted: 354 Post(s)
Liked: 166
The good news is that even if Ohm is no longer making full range Walsh speakers, HHR Exotic is. Not only are they fabricating them, they are also carefully rebuilding Ohm full range Walsh systems. something Ohm no longer offers.
I had never heard of HHR until, spurred by this discussion, I searched for articles and posts about crossoverless systems, and about my favorite concept...the Walsh driver. By the way, Lincoln Walsh, the creator of this driver, was involved with developments in the early days of radar. I guess that made him think about waves in sound reproduction.
When I heard the Ohms the speakers did disappear, and the soundstage hung in the air so transparently and clearly. And this just goes to show how concepts about sound reproduction and real world experience may differ. I had convinced myself that speakers should, as much as possible, minimize reflection, but the Walsh driver radiates omnidirectionally. And yet, I have never heard anything as good.
As for that $400. !!!!!! But we all have stories like that.
And yes, ubiquitousness is a word, and a very good one at that!
Cheers
taichi4 is offline
post #191 of 222 Old 02-20-2013, 09:04 AM
taichi4's Avatar
Quoted: 354 Post(s)
Liked: 166
All the best.
Ray
Before we return to the subject at hand, which Province has the best healthcare system?
As far as California is concerned, you have been here and experienced the weather? wink.gif
taichi4 is offline
post #192 of 222 Old 02-20-2013, 09:21 AM
Liked: 5684
post #193 of 222 Old 02-20-2013, 03:29 PM
JerryLove's Avatar
Liked: 82
I think in the first world the majority of people that would actually discuss audio have heard headphones before (which are single-driver crossoverless speakers). I am dubious of your premise.
post #194 of 222 Old 02-20-2013, 06:50 PM
darthray's Avatar
Liked: 1063
I would say Quebec, British Colombia, Ontario and now Sakachawan.
Not in many years, but California is nice and warm, not snow day after day.
Ray
darthray is offline
post #195 of 222 Old 02-20-2013, 07:04 PM
ex-labdriver's Avatar
Quoted: 25 Post(s)
Liked: 35
I have a bit of a rarity in Canada. On Vancouver Island, I have a nice 20 foot windmill palm tree in my front yard that I planted close to 20 years ago when it was only 2 feet tall. It is quite happy in its location & continues to flower & send out more fronds every year. Obviously it must like lots of water - and we have lots of that in winter up here, ha!
As for healthcare, it's great except for the fact that it is bankrupting us both as a Province & a Country. Our friends to the south are about to find that out as well...
TAM
ex-labdriver is offline
post #196 of 222 Old 02-21-2013, 03:11 AM
JD in NJ's Avatar
Liked: 37
I can't decide whether it's worse for us to go individually bankrupt paying the insurance companies and then paying medical bills anyway because things are not covered, or going bankrupt as a nation for essentially the same reason.
JD in NJ is offline
post #197 of 222 Old 02-21-2013, 07:00 AM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 165
Get our stupid govt out of the equation and watch prices go down.
Processor: Emotiva UMC-200
Blu Ray: Panasonic DMP-BD655
flyng_fool is offline
post #198 of 222 Old 02-21-2013, 07:05 AM
JerryLove's Avatar
Liked: 82
really guys? So off-topic
post #199 of 222 Old 02-21-2013, 07:09 AM
JD in NJ's Avatar
Liked: 37
Not entirely.
If I had more free cash left after paying my health insurance bill, I could afford some nice new speakers. wink.gif
JD in NJ is offline
post #200 of 222 Old 02-21-2013, 07:18 AM
JerryLove's Avatar
Liked: 82
Time to move to the country with the lowest per-capita healthcare costs then. I believe that's Germany.
post #201 of 222 Old 02-21-2013, 07:20 AM
JD in NJ's Avatar
Liked: 37
I've only been there once, and enjoyed it very much.
JD in NJ is offline
post #202 of 222 Old 05-30-2014, 06:38 PM
cs286's Avatar
If you can find one, an old sansui 9000 reciever... perfect match.
cs286 is offline
post #203 of 222 Old 05-30-2014, 06:52 PM
cs286's Avatar
I agree. So many people buy quality equipment 2nd hand and have no clue of its capabilities or applications. Just because their Bose doesn't guarantee best sound in any situation. Any mfgr will tell you this. When purchasing high end equipment do your homework. Most models of mfgrs have guidelines or specific perameters for that model. Its all about sweet spots. I reiterate, do your homework. These speakers are tops when in the right environment.
cs286 is offline
post #204 of 222 Old 05-30-2014, 07:03 PM
oOOBillO0o's Avatar
Yeah, like who reads the manual!
That being said, Bose updates thier list of compatible receivers often
http://worldwide.bose.com/productsupport/assets/pdf/guides/speakers/901_series6/en/st_list_en_901.pdf
And for HT
http://worldwide.bose.com/productsupport/assets/pdf/guides/speakers/901_series6/en/ht_list_en_901.pdf
McIntosh Labs! What am I listening to?
oOOBillO0o is offline
post #205 of 222 Old 02-02-2015, 12:41 PM
Liked: 0
I Absolutely Agree!
Enjoy your BOSE 901 and save your money on expensive amp.
Ray
I not agree. If you have a big room, a great amp can deliver all quality, power and dynamics through a pair of 901!
I think you already know the Acoustimass A-5 dimensions...
Well, put the Bose 901 where you will see them veeery little in that room! Exactly, when you see two Acoustimass cubs in a normal room.
Connect them to a very muscular amp (but good quality is required also), set your preferred track and go full throttle!
It's unthinkable what can really do the 901 System. In certain situations (non obstacles, big walls, no windows near 901s), in example, a rear wall 23 ft. long.
Stay 16,5 ft. away from them and give to them (through a great amp) some good title, the "little" speakers will disappear, the room will transform in a great invisible speaker, musical instruments and low frequencies everywhere, no sound-colorations, only a live sensation!
I've tried this experience only one time in my life, in a photographic studio (of my ex girlfriend's father).
I will never forget that unthinkable, marvellous acoustic experience!![/quote]
Yes, buy and listen to what YOU like not what someone else says you SHOULD like. F* that. I've tried everything under the sun. I came back to 901's. I will probably buy two pairs. I use Class D Rotel 600 watts/channel right now (no longer available) with Emotiva Stealth DAC preamp. I'll probably get Emotiva XPR-2 or MacIntosh 452 next. I only care what I feel. I don't buy stuff for other people. I buy it for me! I'm a physicist with a side hobby of live sound. (Means high dynamic range, full human spectrum, direct and reflecting, and an absolutely personally wonderful experience!) Enjoy your 901's.
Rotoavs is offline
post #206 of 222 Old 03-13-2015, 07:38 PM
Liked: 0
901s
I have the 901s series VI with the EQ. Have them for 7 years now . Initially I was using NAD C355BEE integrated amp , with Cambridge Azure 650p phono preamp.
Now I have The Mcintosh MC452 Power amp , with the Mcintosh C2500 tube preamp connected to my Bose 901s with the Eq. The sound is nothing but Phenominal.
prashc is offline
post #207 of 222 Old 05-13-2015, 11:51 AM
Liked: 0
About 3 pages in I had to stop reading and register so I could post. First, as far as power amps for 901s, you must go big. I use a pair of NAD2700 bridged mono to drive mine. I chose them not only for the 400w into 8ohms, but also because at the time they offered the most headroom, which I feel is very important. Also they are class A.
Now for those 901VI disasters. Only buy them if you can have at least 2 feet behind and next to them, and at least 12' between them. If you can give them the space, they sound amazing, and do have great bass as well. These little speakers depend on the corners to complete the design. If you push them into a corner it's just like cutting the back off a box speaker.
Excluding extremely expensive special order speakers, nothing you can buy has deep bass. Not even the subwoofers. For that you must custom build. I built a 4th order bandpass using a 21"driver. With 1-1/2" MDF walls it comes in at 550lbs, but it has solid output down to 19hz. Powered with a bridged Crown XLS2500 (1550w @ 8ohm) it can take things off the walls. Coupled with the 901s and played at moderate volume it is unbelievable, amazing. If you don't have a large enough room then you're better off with a box speaker until you can get into a place with at least 20' width, if not 30.
RockinSystem is offline
post #208 of 222 Old 05-13-2015, 11:57 AM
oOOBillO0o's Avatar
Wow! What a post!
Do you have a picture (s) or example of what you describe?
post #209 of 222 Old 05-14-2015, 08:39 PM
Elihawk's Avatar
Quoted: 1336 Post(s)
Liked: 1166
A good speaker does not have this many "requirements"...
Lots of speakers you can buy have better bass, but it is true that no 3 inch woofer can produce great bass! When 901 measurements have been posted, they don't hit much below 100 hz +/- 3 dBs...
Set up #1: EMP e5Ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, SVS NSD SB12 sub, Marantz Slimeline 1504 AV receiver
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and EMPtek10i10i sub, Denon 1910 AV receiver
Set up #3: Philharmonics- BMR in a 2.0 system, music only, Yamaha RXV-363 AV receiver
Elihawk is online now
post #210 of 222 Old 05-14-2015, 10:31 PM
dsrussell's Avatar
Quoted: 2261 Post(s)
Liked: 3095
Don't kid yourself, Elihawk. Actually, the 901's can hit the mid to lower 30 Hz range. When I hung my Series II (ages ago, in the mid 70s), an audio pro buddy of mine had a pink noise generator and mic to help me get them spaced properly and ran the graphs (I spent a lot of time in my attic). After a half dozen holes through the ceiling (popcorn, so it was easy to fill and cover up) I got them spaced properly. They have 4-inch drivers, if memory serves me, and had shocking bass response, which is based upon their "active equalizer" module. They were immensely power hungry little buggers, and I ran them with a 200 watt McIntosh amp. They could have used two or three times the power (my power guard circuitry on my amp blinked red often). They could fill a room like very few speakers could. Essentially the whole wall was a huge soundstage. Bose did it right with the 901s, so I give credit where credit is due. I was very happy that I owned them. Great party and dancing speaker (in my partying days). Of course, I'm much happier with my Maggies, and for different reasons (although the soundstage played an important role in my selection of the Maggies).
Music area: Magnepan 3.6, McIntosh MC2205 amp & C48 preamp, SVS SB13-Ultra, Oppo BDP 95, dbx 3BX, and assorted equipment.
Movie area: EMP Tek E5Bi (were rebadged to R5Bi), RBH/EMP Tek R55Ti, PSA S3000i, Denon X2000, Oppo BDP 83.
dsrussell is online now
Reply Speakers
