Best Surrounds $300-500 Help NEEDED!!! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 03-13-2012, 02:57 PM - Thread Starter
Onlooker101's Avatar
I recently purchased the EMP E55TI Towers along with their E56ci center. I was looking at picking up their E55Wi Surround speakers while there on sale.
Question is, could i pick up better sounds for around the same price range?
What would be recommended?
Onlooker101 is offline
post #2 of 11 Old 03-13-2012, 06:15 PM
jaeelarr's Avatar
Quoted: 46 Post(s)
Liked: 42
I wouldn't spend very much money on surrounds to be honest.
jaeelarr is offline
post #3 of 11 Old 03-13-2012, 06:25 PM - Thread Starter
What would you recommend then???
post #4 of 11 Old 03-13-2012, 06:30 PM
Khaos's Avatar
http://www.emptek.com/e5bi.php
Bookshelfs work as rear's just fine.
Unless you want dipole?
Please tell me what happened in this night.
It's like the cat inside the box.
You don't know if the cat in the box is dead or alive.
The cat in the box was dead.
Khaos is offline
post #5 of 11 Old 03-13-2012, 06:37 PM - Thread Starter
dipole would be nice, but would i really notice a difference between that or a standard bookshelf?
post #6 of 11 Old 03-13-2012, 07:12 PM
Khaos's Avatar
I think I meant to say bipole, my bad.
Depends on placement and room, bipole in general I think has a bigger sweet spot (and may sound more natural on ambient effects), don't quote me though, I'm not sure.
As far as bipoles, I would recommend the emotiva erd-1's but as far as I'm concerned I don't think they sell them anymore. You can call them and ask about b-stock. The XRS-4.1 is the x series surround, but there isn't a review or comment on their sound yet.
Khaos is offline
post #7 of 11 Old 03-13-2012, 09:17 PM
Audiophile34's Avatar
These are Di/bi pole selectable and for the money, to my ears have never been beat.
http://store.cambridgesoundworks.com/dp/B00345E900
I have four of these in my 7.1 setup, and these are never what I consider to be my weakest link in my system.
My first DIY project. A dual, dual opposed setup
www.avsforum.com/avs-vb/showthread.php?t=1345494
Audiophile34 is offline
post #8 of 11 Old 03-16-2012, 11:11 AM - Thread Starter
Any other surrounds that would piece well with the EMP Tek speakers?
post #9 of 11 Old 03-16-2012, 11:48 AM
zieglj01's Avatar
Quoted: 945 Post(s)
Liked: 847
You can look at the HTD Level Two - if budget is tight.
http://www.htd.com/Products/level-tw...l-TWO-Surround
If you want to spend more, then get the EMP surrounds.
I am in the monopole camp - however, the preference and choice
is yours to make.
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is online now
post #10 of 11 Old 03-16-2012, 03:30 PM - Thread Starter
is yours to make.
What would really be the audible difference in going with the different surrounds? Say going from the emp surrounds to Level Two surrounds???
Are the emps really worth the $400 price tag for surrounds?
post #11 of 11 Old 03-16-2012, 04:27 PM
zieglj01's Avatar
Quoted: 945 Post(s)
Liked: 847
For surround sound, my main concern is to level match.
I do not know what the EMP surrounds sound like - Also, I do not
spend a lot of money on surround channels (for surround effects).
For me, I want the front 3 channels to timbre (voice/tone) match.
It is not that big a deal to me, for surround effects. Now, if I were
to do surround music, then I would want the surrounds to timbre
match > and I would do bookshelf/monopole speakers for that.
I am mainly old school stereo, or 2.1 for music. Your choice and
option - good luck!
Who AM I
Reply Speakers
