Please help me adjust the bass on Bose cinemate (series I) - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 67 Old 03-15-2012, 07:16 PM
chashint's Avatar
Quoted: 18 Post(s)
Liked: 54
I really feel for anyone that ventures in here asking for assistance with a Bose system, while humor is humor a bunch of you are down right mean.
dg_sound as you already know the Bose system turned out to be rather limited in its capability.
With a $500 budget you might consider something like this:
This is an entry level receiver but it is 3D capable, iPod connectivity, auto cal, 4 HDMI inputs for $180 its pretty darned good http://www.newegg.com/Product/Produc...82E16882117397
Not sure about this subwoofer but the budget goes quick, and to get better is going to cost double. Some might recommend that its money well spent and to get lesser speakers but I think this would be better than the Bose bass module and the price is right at $120 http://www.newegg.com/Product/Produc...82E16882290034
These are on clearance and at $200/pr they are a steal of a deal, the Bose cubes cannot compete with these on any level other than being smaller. http://www.newegg.com/Product/Produc...82E16882780084
Newegg is a well know reliable dealer that has been in business a long time so you can order with confidence.
Charlie
chashint is offline
post #32 of 67 Old 03-16-2012, 06:17 AM
Elihawk's Avatar
Quoted: 1022 Post(s)
Liked: 869
Well, Nethawk...the OP even stated that Bose customer service told him they couldn't help him and only offered that he needs a more expensive system. Talk about a company admitting the system in question is crap!
Set up #1: EMP e5ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, EMP 10i10i sub
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and Klipsch 12wD sub
Set up #3: Philharmonics- BMR in a 2.0 system, music only
Elihawk is offline
post #33 of 67 Old 03-16-2012, 10:35 AM
cel4145's Avatar
Quoted: 2660 Post(s)
Liked: 2991
+1
There is a lot you can do with a budget of approximately $500 that would be a significant improvement in sound over that Bose setup. The Pioneer VSX-821-K receiver is a good choice. I would steer away from that Polk PSW10 sub and lean toward the Pioneer SW8. Although for more serious bass for HT use, the BIC F12 is often recommended as the lowest entry level sub for budget systems and would be well worth the price difference. The BIC F12 is as low as I would go in a sub purchase. You don't want to be underwhelmed on bass again.
For speakers, you could also look at the Polk Monitor40 and PolkMonitor30. Typically, they are on sale even cheaper a couple of times a month at Newegg (subscribe to their mailing list). The Infinity Primus bookshelves (check Amazon and Crutchfield for pricing) are also often recommended here on AVS.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #34 of 67 Old 03-16-2012, 12:55 PM - Thread Starter
dg_sound's Avatar
I have already made up my mind that the Bose Cinemate needs to go back. After the call with their customer service, I would have returned it even if it was a very good system.
cel4145 and chashint have great suggestions, thank you! I am also able to convince my better half about an increase in budget... so here are the ones I am thinking of based on my research -
Pioneer VSX-821-K + Polk Audio Monitor40 Series II + Polk Audio PSW10 $450
Denon AVR 1912 + Energy Take Classic 5.1 $949
Denon AVR-2112CI + Energy RC Micro 5.1 system $1250
Ideally, even if I extend the budget to $1000, I want to get the best value for money (i.e. best sound : price) and yet get a system that is easy to use. Thank you for your suggestions...
dg_sound is offline
post #35 of 67 Old 03-16-2012, 01:05 PM
jproy13's Avatar
Liked: 26
Of your 3 options, number 1 would be my pick but minus the PSW10 (I had 2 of them). The little Polk sub won't fair much better than your Bose bass module. Look for the Bic America f12 (I had 2 of them), it isn't much more expensive the the PSW10 but easily twice the sub. If you shop a bit, it is below $200 at your door.
Number 2, scrap the 1912 and go with the 1712. Less money, better room correction (MultiEQ vs. MultiEQ XT for the 1712). They're virtually the same except for a few options.
Number 3 is good also, but you would have to spend on a good sub that can handle frequencies up to 150Hzish as the RC Micro will only go down to that area.
cheers
jproy13 is offline
post #36 of 67 Old 03-16-2012, 01:13 PM
mrrame's Avatar
@OP: If you do decide to open the bass module, can you post some pic. Would like to see what they have inside
mrrame is offline
post #37 of 67 Old 03-16-2012, 02:30 PM
cel4145's Avatar
Liked: 2991
If you are willing to budget $1250, most people will agree put a lot of that money into the speakers, not the receiver. That's where the most bang for your buck is in audio quality. So I agree with jproy13. Get the Denon 1712 or even the 1612. Both of those have Audyssey MultiEQ or better.
Also, a full set of Polk Monitors will give you better sound than the two Energy satellite packages. Bigger drivers. Those Energys are only better choices if you don't have room for the more full sized bookshelves. Should be able to get Polk Monitor 40s for the front, Monitor30s for the rear, and then the CS2 center for a very reasonable price if you watch Newegg sales for just a few weeks (buy them separately as they go on sale).
Another option is the Pioneer 5.0 speaker set at BestBuy for $300. Lot of good testimonials in this thread for them: Pioneer's Speaker Genius Hits Low Price Point.
Then add the BIC F12 from Amazon to it. While it might seem a lot to spend almost $200 on a sub, consider that you are buying a speaker and an amplifier with a subwoofer.
cel4145 is offline
post #38 of 67 Old 03-16-2012, 02:48 PM
jproy13's Avatar
Liked: 26
Originally Posted by cel4145 View Post
...Another option is the Pioneer 5.0 speaker set at BestBuy for $300...
good call
Also just want to point out to the OP that there is nothing wrong with the Energy Micro and/or Take series but in my opinion, like most satellite, you are paying more for "style" rather than substance.
cheers
jproy13 is offline
post #39 of 67 Old 03-16-2012, 03:36 PM
chashint's Avatar
Quoted: 18 Post(s)
Liked: 54
Earlier you said surround sound was not what you wanted due to wires.
Think about what you want in your room and the budget you are willing to invest in it.
There is a huge difference between a budget of $500 and $1k.
If $1k is put into a 2.1 channels you get a lot better speakers than you do at the $500mark.
With a $1k budget for everything I would stick to AVR's similar to the Pioneer 821, the electronics make way less difference than better speakers will.
Charlie
chashint is offline
post #40 of 67 Old 03-16-2012, 03:45 PM
zieglj01's Avatar
Quoted: 945 Post(s)
Liked: 847
Do not spend too much on a receiver - the Pioneer 821 or a Denon refurb,
from AC4L is a nice option. Also skip the Polk 110 sub. I would also aim
higher than little sat speakers. 3.1 is a good option to start with.
And I would pick the Polk RTi4 over the Monitor series
http://www.ebay.com/itm/PAIR-RTi4-BL...item35ba6d6ec5
And, I would look at the Carnival 2 speakers and Carnival 5 center
Here
http://www.dedicatedaudio.com/inc/se...nival&n=467098
There are decent options out there for $1250.
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #41 of 67 Old 03-16-2012, 04:39 PM
jjackkrash's Avatar
Quoted: 932 Post(s)
Liked: 804
Make sure to call Electronics' Expo and maybe several other authorized online resellers for the best price on a Denon receiver. And you have to actually call to get the best price.
The Denon 2112 can be had for <$450 shipped, new in the box, and is a great little unit, with MultEq XT and nice networking features and, importantly, only $10 more than a 1912 at EE. Skip the 1912. I agree, if you don't need networking, skip down to the 1712 for a substantial savings, but I like the networking features and think the 2112 is a very nice unit and for $10 more is a no-brainer over the 1912. Here is a thread regarding the Denon XX12 line, read the first three posts closely.
http://www.avsforum.com/avs-vb/showthread.php?t=1334369
Here is a deals thread with some places to call to find deals on Denons from authorized resellers.
http://www.avsforum.com/avs-vb/showthread.php?t=1388096
jjackkrash is offline
post #42 of 67 Old 03-16-2012, 04:48 PM
jjackkrash's Avatar
Quoted: 932 Post(s)
Liked: 804
Also, while I agree with the posts above that say speakers are the most important, I also think its nice to have a receiver with the features you want. Again, take a look at the XX12 thread, Batpig gives good advice on how to select the Denon receiver that meets your needs.
post #43 of 67 Old 03-16-2012, 09:09 PM - Thread Starter
dg_sound's Avatar
The Denon 2112 can be had for <$450 shipped, new in the box, and is a great little unit,...
That was a great tip! I called Elec. Expo and the sold me the 2112 for $449 shipped. So now I have the receiver picked. Expo doesn't sell the BIC F12... so looks like I'll have to get it from Amazon for $188+tax ~$200 (unless someone can suggest a great deal for this one). For the speakers, I am still quite undecided. The space I have to put the speakers under the tv is just about 6.5 inches high, so I think I really want good but small speakers. I can put the center speaker above the tv and the two side speakers below the tv, at most 2.5 ft apart. What is a good choice? As I mentioned earlier, the room is 11'x20' and the TV/HT system is in a corner, while we watch/listen from the other corner.
dg_sound is offline
post #44 of 67 Old 03-16-2012, 10:49 PM
HardBat's Avatar
I disagree with the quote about the PSW10 not being much better than the Bose. I have heard both, and there is no comparison. The PSW10 is easily 10 times the sub as the Boss bass module. I haven't heard the Bic America, and I'm sure it is better than the PSW10, but I was just trying to stick within the OP's budget when I was building a setup for him.
The PSW10 is a great sub for the price.
HardBat is offline
post #45 of 67 Old 03-17-2012, 12:44 AM
jjackkrash's Avatar
Quoted: 932 Post(s)
Liked: 804
Sweet! I'm glad you found two good pieces, that is a great start.
As far as speakers placement, can you post a pic of the room where they will go? If at all possible, you want the front three (L/C/R) speakers about the same height and as close to ear level as possible and you want the left and right to be outside the edges of the TV, if possible. If you can't, you can't, but here is a link to a basic placement guide:
http://www.dolby.com/us/en/consumer/...ide/index.html
post #46 of 67 Old 03-17-2012, 03:34 AM
dowop's Avatar
Quoted: 42 Post(s)
I agree. There is no comparison between the Bose & Polk. I think the Polk is a excellent sub for the price.
dowop is online now
post #47 of 67 Old 03-17-2012, 05:24 AM
jproy13's Avatar
Liked: 26
fair enough, although I disagree wholeheartedly, I respect your opinion. But to say it's an "excellent" or "great" sub for the price is a little extreme. It's a "sub" for the price. Sure, the build quality is very good, it looks very good too (in my opinion) and the amp is of good quality. But just know that at 50watt (the Canadian version anyway) of continuous power will more than likely be drawn out by the Monitor 40 if the friend chooses to go with that.
Think about it, 50watts continuous power (100watts peak) + 10" driver + low ends of 35Hz (claimed, if it does it 35hz, one more than likely wouldn't hear it as their is just not enough juice to push it)
If the friend wants that, then just get it, I was just trying to to relay that having owned a dual setup of them, I quickly noticed that I was missing a great deal of low ends from movies.
Good luck
cheers
jproy13 is offline
post #48 of 67 Old 03-17-2012, 10:40 AM
jjackkrash's Avatar
Quoted: 932 Post(s)
Liked: 804
I just saw another member recommend these in another thread. I can't vouch for them, but it looks like a great deal if you could find room for a pair of floor standers:
"4.9 of 5.0 stars out of 91 reviews and only $400
http://www.vanns.com/shop/servlet/it...10030302008005
or
http://www.vanns.com/shop/servlet/it...h&SSAID=389818"
post #49 of 67 Old 03-17-2012, 03:39 PM
chashint's Avatar
Quoted: 18 Post(s)
Liked: 54
deleted
Charlie
chashint is offline
post #50 of 67 Old 03-17-2012, 04:39 PM
Raymond Leggs's Avatar
the op should adjust the bose into the trash can
Raymond Leggs is offline
post #51 of 67 Old 03-17-2012, 04:44 PM
Nethawk's Avatar
Liked: 118
Nevermind. You're not worth it.
Nethawk is offline
post #52 of 67 Old 03-17-2012, 10:11 PM
porsche951's Avatar
Originally Posted by Nethawk View Post
Geez, what a bunch of whiny elite buttheads. He didn't ask for your opinion on his equipment, he asked for help. If you can't provide it, move on.
dg_sound, pay no attention to them. Half haven't a clue why they hate Bose, they just think it's cool to hate because someone else does. Get your system the way you like it, and enjoy it. That's all that matters.
Whiny elite butheads? I love when someone uses the word, elite, as if it's somehow an insult. I suppose to the unwashed masses wallowing in mediocrity, it is...
porsche951 is offline
post #53 of 67 Old 03-18-2012, 07:05 AM
Nethawk's Avatar
Liked: 118
You're reading it wrong. In your case, focus on 'butthead' and instead of thinking it an insult, consider it a compliment.
Nethawk is offline
post #54 of 67 Old 03-18-2012, 09:07 AM
porsche951's Avatar
. I rest my case.
post #55 of 67 Old 03-18-2012, 09:14 AM
cel4145's Avatar
Liked: 2991
There was a mini review by another AVS member over in the subwoofer forum that confirms this conclusion:
Originally Posted by eljaycanuck View Post
Based on the hour or so that I did play with it, my conclusion is that this would be a decent sub for a very modest two-channel or home-office system in a smaller room. I don't think it would work very well in a large room (at louder volumes) or in any quasi-serious HT application.
cel4145 is offline
post #56 of 67 Old 03-18-2012, 09:29 AM
Nethawk's Avatar
Liked: 118
. I rest my case.
Ahh, but I've gone through your forum responses and observed how many whiny elitist butthead posts you've made. You never really had a case.
Nethawk is offline
post #57 of 67 Old 03-18-2012, 10:00 AM
porsche951's Avatar
. I'm flattered that you took the time to go through my forum responses. Maybe, If you're a good boy and behave yourself, I might let you wash one of my Porsches.
post #58 of 67 Old 03-18-2012, 10:01 AM
Ratman's Avatar
Quoted: 1289 Post(s)
Liked: 1029
Keep on topic and stop with the "personal" retorts.
Ratman is offline
post #59 of 67 Old 03-18-2012, 10:31 AM
Nethawk's Avatar
Liked: 118
I rest my case.
Nethawk is offline
post #60 of 67 Old 03-19-2012, 06:33 PM - Thread Starter
dg_sound's Avatar
Here is the pic - thanks for sparing the comments on the existing speakers, because that's being returned in favor of Denon AVR 2112 CI + BIC F12 + ??
The place where the speakers currently are is only 6.5" high, they are slightly below listening level. The center speaker (in my previous Sony system) was on top of the TV. I don't really want to run wires through the room. We usually sit on the sofa facing the TV, which is about 15' away (as you see, the tv is set diagonally in one corner, we listen from almost the other corner in the 11'x20' room). What kind of speakers should I get? Thanks for your suggestions!
dg_sound is offline
Reply Speakers
