Weak surround sound effect with B&W CM series - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 03-15-2012, 06:54 PM - Thread Starter
unidisk's Avatar
I have just setup my 5.1 surround system using B&W series. Here is the setup:
Front: CM9
Surround: CM5
Center: CMC2
Sub: ASW12CM
Pre-processor: Rotel RSP-1570
Amp: Rotel RMB-1565
BDP" Sony BDP-S5000ES
I matched each channel with the SPL meter @ 75db. However when I play the movie, the sround effect is not very weak. It seems that the suround sound levels from the speaker are pretty low compared to the sound level from the front although the test tone is a perfect match between the front and the back. The room is a pretty large by 13"x40" in size. The fronts are at 10 and 2 o'clock and the surroundings are at 4 and 8 o'clock positions. The walls are covered with sound panels and the front is a 120" screen. What can be wrong? Should I raise the level of the surround to more than the front?
Advises are welcomed! Thanks in advance.
unidisk is offline
post #2 of 7 Old 03-15-2012, 08:21 PM
JimWilson's Avatar
Quoted: 1500 Post(s)
Liked: 1991
You should adjust them to whatever sounds good to your ears. Guidelines are just that; guidelines. Setting everything for the same output level sounds good on paper, but might not sound good to your ears. However, your ears are the ultimate judge, so it's probably best to use those when fine tuning your system.
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is offline
post #3 of 7 Old 03-15-2012, 08:40 PM
Oliver Deplace's Avatar
Quoted: 21 Post(s)
Liked: 34
Make sure they're in phase and their distances/delays are set correctly. Oh, and make sure all of their drivers are functioning.
Yo mama so fat, time slow when she near.
Oliver Deplace is offline
post #4 of 7 Old 03-15-2012, 09:23 PM
Yosh70's Avatar
Quoted: 194 Post(s)
Liked: 138
Some movies/concerts dont have a lot of surround mastered in but really, you shouldn't really notice them anyway.....they are there to fill, not to match the front. It was edited that way as the director wanted it to be.
If you feel you want to go against the grain, switch it to all channel stereo on your pre.
Yosh70 is offline
post #5 of 7 Old 03-16-2012, 12:52 AM
the rick's Avatar
I'd also make sure your sources are sending a 5.1 signal to the receiver. Many people incorrectly setup the output and end up with pro logic instead of dolby digital etc
the rick is offline
post #6 of 7 Old 03-16-2012, 06:20 AM
Scout's staff's Avatar
I had a similar issue - after speaking with my audio dealer, I increased the center and surrounds 2db over the mains. I'm happier with the result. See what you think - every room is different
Scout's staff is offline
post #7 of 7 Old 03-16-2012, 07:00 AM
chikoo's Avatar
Front: CM9
Surround: CM5
Center: CMC2
Sub: ASW12CM
Amp: Rotel RMB-1565
This seems like my worst fear coming true, which is Warm musical speakers are not very effective in a surround sound setup. you may want to bump up the level on the surrounds, but my instinct tells me that will not improve your surround effects. Try it though.
chikoo is offline
Reply Speakers
