Most Important Aspect of an Audio System - Page 10 - AVS Forum | Home Theater Discussions And Reviews
View Poll Results: What (in order of preference) is the most important aspect of an audio system?
Speakers, Room, Electronics 1 50.00%
Room, Speakers, Electronics 1 50.00%
Speakers, Electronics, Room 0 0%
Electronics, Room, Speakers 0 0%
Room, Electronics, Speakers 0 0%
Voters: 2. You may not vote on this poll
post #271 of 276 Old 04-06-2012, 07:22 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 221
Originally Posted by ntrain96 View Post
Pointsource drivers have the best imaging period. No crossover network means less coloration, no crossover network many times means better power handling and/or efficiency as well. Which is why I am a big fan of only using an active xover system if a xover is needed.
Proof? Just because you state something doesn't actually make it true. How does a speaker with a ragged on axis response, horrid non existent off axis response, and all kinds of IM distortion from producing bass have less coloration?
There are to many examples of high sensitivity, high power handling multi driver speakers to even try to bring that up lmao
Jay1 is offline
post #272 of 276 Old 04-06-2012, 09:05 PM
kwarny's Avatar
The decay spec is great, how are the dynamics though? There are always TRADE OFFS.
RAAL tweeters while very nice, don't have the dynamics of some of their hard dome counterparts, and they generally tend to roll off quickly in the top octave even when they are directly on axis. Not necessarily a bad thing as I like ribbon based speakers and drivers, bu the RAAL tweeters would not be my first choice when it comes to a dynamic lively soundting top end.
Some trade offs are bigger than others. How are you defining dynamic? If it is not dynamic; is it due to a memory effect, power compression, or less energy storage? IMO, tweeters and drivers with less energy storage may sound so called less dynamic?
Rolloff is related to the radius of the tweeter. Curtis already corrected the top end roll off. The RAAL also has excellent CD off in the horizontal axis. I would agree with what you said if you enjoy doing squats and jump roping near the speakers. Salk states that the dual ER15 or W18 drivers will be damaged before the RAAL is damaged. That includes their MTM speakers.
Ive heard the RAAL tweeter first hand on a Zu Essense. Flat to 20k it was not. Off axis the response roll off becomes very dramatic. I think there are even a few online reviews with "pro" measurements with similiar results. Regardless, its a good driver, not the best Ive heard though, nor would it be my first choice. One of the best sounding un-EQ'd speakers I've heard with incredible treble came from a pair of Maxxhorn's. Single full range driver, no xover. Incredible detail and dynamics in the treble, solid, detailed smooth bass down to 30hz. All from a single 5" driver.
So you criticize the RAAL above for those features but then a 5" full-range driver is excellent? This larger diameter driver has better high frequency extension than the RAAL tweeter? better off-axis response than a high end tweeter? all while possible suffering from non-perfect BL curve, Le(i), Le(x), CMS(x), IM, and limited power handling since it needs less wire in the motor to extend to the treble region. Full-range drivers do have their advantages though. I enjoyed the Jordan driver when I had a chance. Imaging is one of those as long as there is no excursion. I don't disagree about you enjoying their sound.
I will get back to you on passive versus active crossovers. The Salk employees could not tell a difference when using an A/B switcher when not EQ the bass. Speaking of Salk, they produce a speaker with the Jordan when asked. I plan on asking a few more companies regarding passive versus active.
The greatest enemy of knowledge is not ignorance, it is the illusion of knowledge - Stephen Hawking
Kyle Bosso - SOB
kwarny is offline
post #273 of 276 Old 04-06-2012, 10:13 PM
N8DOGG's Avatar
Quoted: 1111 Post(s)
Liked: 1212
Originally Posted by Matt34 View Post
Is this the same guy that got outed on the Emotiva forum when it was discovered he was ripping people off on a Harley Davidson forum??
O ya it is
N8DOGG is offline
post #274 of 276 Old 04-07-2012, 01:06 AM
NIN74's Avatar
Well let me ask you this? WHy use say air core inductors over iron core inductors? WHat about sandblocks? WHat happens when they heat up? How about caps? Do you want these items inline at the speaker level? People who are big on "time coherant" speakers........what kind of xovers do these speakers use? Why does any of this matter if passive xovers dont hurt or alter the audio signal?
How about knowing what your talking about?
Sound and video is not magic, it is pure physics. Physics that can be magical
NIN74 is offline
post #275 of 276 Old 04-07-2012, 04:28 AM
ntrain96's Avatar
Who is to say a good single full range driver is going to have a ragged on/off axis response? Or IM distortion from playing bass frequencies? If you actually HEARD(which you obviously havent)a good point source speaker with both a low Fs and low VC inductance you wouldn't even be quoting this.
Tossing out some of the specs of a ribbon tweeter and what its capable beyond what you can actually hear is great, but the most important driver and frequency range is the MIDRANGE. When you dont have to couple a midrange driver or share midrange frequencies with a xover and a secondary driver that doesnt even disperse the audio wave in the same uniform pattern as your most important driver, you already have a disadvantage in design in many important audio aspects.
ntrain96 is offline
post #276 of 276 Old 04-07-2012, 10:30 AM
kwarny's Avatar
What part can't most people hear? I don't think anyone said the importance of the RAAL was that it can play past 20 kHz.
Low Fs drivers have lower sensitivity and drivers with low VC inductance have less power handling. Don't forget to factor in BSC when looking at drivers. Didn't you mention earlier, what if you want to play louder? Variations in inductance across excursion will change the frequency response of the driver also.
Seas Prestige FA22RCZ
Seas Prestige FU10RB
Seas Exotic X1-04 EXOTIC F8
Seas Exotic X1-08 EXOTIC F8
Jordan JX-92S
http://documents.jordan-usa.com/JX92S.pdf
From Zaph Audio.
Comments: Very wide and smooth frequency response. This is a full range driver that actually sounds good run full range with a simple baffle step compensation circuit. When you get 10 degrees off axis however, the high end disappears from beaming. Decent overall performance, but a poor value. A pair of better sounding 2-way systems could be built for the cost of a single JX92S. If you're convinced there's some sort of magic to a full range driver, this is one of the best, far surpassing most others I've come across. Tested March 2008.
RAAL 70-10
http://www.raalribbon.com/images/products/70-10-m.htm
Kyle Bosso - SOB
kwarny is offline
Reply Speakers
