kef T-305 vs B&W MT30/25 vs Focal Dome 5.1 vs Q Acoustics 7000 - AVS Forum | Home Theater Discussions And Reviews
Old 03-21-2012, 07:12 AM - Thread Starter
askme_scor's Avatar
Hello everyone,
Well there have already many comparison in the forum but I think this one is not the repeated one.
I have been looking for under $2000 speaker set and through all reading on this forum and others review I think these are the I am able set in y mind. Look has also been a factor as well as wall mounting option. As one would notice that all are of almost same price range except for the Q Acoustics 7000 and I think its actually comparable in terms of performance in spite being half the price. Again my knowledge about speakers is just 3 days old as I have just started searching for them so I might now be knowledgeable as you all are.
Now my question is if Q Acoustics is comparable to the other mentioned speaker is it worth to spend double the money on other speakers or I should directly Q Acoustics system
In case there is major difference of performance than what should I go for among the mentioned speaker, or is there any good system that I failed to mentioned.
Also if this information is of any use, I am planning for denon 2312 avr
Kind regards,
askme_scor is offline
Old 03-22-2012, 11:01 AM - Thread Starter
askme_scor's Avatar
more than 100 views still no reply
Old 03-22-2012, 12:09 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Sorry, I can not help you with Q Acoustics.
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
