Speaker Wattage Higher than Receiver? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 03-25-2012, 07:35 PM - Thread Starter
RocknRolla's Avatar
Hello!
I'm slowly upgrading my audio system and the first place I'd like to start is the front L/R speakers. I want to get the Klipsch RF-7II. They have a Power Handling of 250W RMS / 1000W Peak and a Nominal Impedence of 8 ohms compatible.
My current recover is an Onkyo TX-SR705 with 100 Watts/Channel at 8 ohms (FTC).
If I use the speakers with this receiver, could they be damaged?
RocknRolla is offline
post #2 of 7 Old 03-26-2012, 07:23 AM
Hamilcar Barca's Avatar
The only real danger from a receiver which delivers significantly less power than
the speakers can handle is if the amplifier clips its output signal because it's
being asked to deliver too much power. IOW, some caution is indicated before
you crank the volume to 11.
Hamilcar Barca is offline
post #3 of 7 Old 03-26-2012, 11:36 AM
commsysman's Avatar
Quoted: 1080 Post(s)
Liked: 569
If you buy tires for your car that are rated for a maximum speed of 130 MPH, you are not going to damage them unless you drive the car faster than that.
If you use a speaker that is rated for a maximum power level of 250 watts, you are not going to damage them unless you use an amplifier that can put out MORE than that.
The only exception to that would be if you turn the amplifier up to where it is distorting horribly, in which case it CAN put out more power than its RMS power rating (which is maximum UNDISTORTED power). This is clearly audible and anyone with half a brain will turn the volume down before speaker damage occurs.
I would advise you to look at the PSB Image T6 speakers, or the KEF Q900 speakers, which are IMO opinion MUCH better-sounding speakers than the Klipsch speakers you refer to.
Both of these speakers have repeatedly had reviews praising their incredibly good sound quality and describing them as the best speakers in their price range, and I agree with that. The Klipsch speakers are generally regarded as mediocre and overpriced, and you would be well-advised to slow down and do some research on the subject.
Hello!
commsysman is offline
post #4 of 7 Old 03-26-2012, 11:52 AM
cel4145's Avatar
Quoted: 2668 Post(s)
Liked: 3002
Yep. When you hear your speakers starting to lose composure at louder points in music and songs, back the volume off a little bit. This point may vary on your volume dial depending on the input signal of the recorded medium (some songs or movie may play louder). Your tweeters will thank you if you don't clip the amplifier
As for the Klipsch RF-7 II, a lot of people like them for HT use because of their very high sensitivity rating. They will play louder with the same receiver wattage output than many other speakers. Just be sure to budget for the matching center channel from Klipsch.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | HE-400i | NAD HP50 | Sony MDR-1A | Soundmagic E50 & E80 | X5ii | DX50 | E12
cel4145 is offline
post #5 of 7 Old 03-26-2012, 12:03 PM
CalgaryCowboy's Avatar
Yeah, what he said. The amp section is rated at a certain total harmonic distortion (THD). It can put out more but at a higher THD (clipping) which can damage speakers. Even if the actuall wattage is lower than the speakers can handle.
Klipsch speaker have a particular sound that I do not favour but many do and they are well regarded especially for home theater. Have you had a chance to listen to these are similar speakers? If you have and like the sound go for it. The nice thing about these speakers is that they have a high sensitivity. Meaning that it take less power (watts) to produce louder sound (SPL)
My review comparisons of Energy RC-70s to Veritas V6.3 http://www.avsforum.com/avs-vb/showt...8#post21199418
CalgaryCowboy is offline
post #6 of 7 Old 03-26-2012, 07:01 PM - Thread Starter
RocknRolla's Avatar
Thanks for the help, everyone!
I've always been keen to the sound of Klipsch, so I'll stick with the RF7 IIs.
Last question is, will it be a problem having much lower end/power speakers on the other channels for the time being?
post #7 of 7 Old 03-27-2012, 10:11 AM
NuSoardGraphite's Avatar
Quoted: 402 Post(s)
Liked: 367
For you Center channel, yes it will likely be a problem. For your surrounds, not unless you listen to a lot of music in surround format (multi-channel A-DVD's, SACD's, concerts on BD or All-Channel Stereo).
If you center speaker doesn't have the sensitivity to compete with your Fronts, you could have a problem hearing the dialogue, or your AVR's room compensation software might EQ your Fronts in strange ways to try and get them to match your center (or vice versa).
At the very least try and get a Center speaker that matches well spec-wise (mainly Sensitivity and Ohm) with your Fronts.
Stand tall and shake the heavens...
NuSoardGraphite is offline
Reply Speakers
