Pre-wire and speakers for fireplace tv (ughh, another fireplace question?!) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-25-2012, 08:26 PM - Thread Starter
Greavesk's Avatar
Hello all. New member, first time poster. To preface this post, I've searched the forums and read ~10-15 of the fireplace threads regarding speakers. I'm aware that this would not be the best location, but, like most people posting, I have limited options so it is what it is. However, I've included pictures of the room to allow for opinions on other options. Now, on to my story...
My wife and I just entered a contract with a builder for a new-construction townhouse and, you guessed it, we're almost to the pre-wire stage. Like I mentioned before, I've looked through some of the fireplace threads so I'm familiar with some of the options available. That being said, I figured I still might get some ideas that are applicable to my exact situation, instead of trying to extrapolate ideas from others. First of all, here is are 2 links to pictures of what the finished house will look like:
h ttp://tourimaging.com/vt/TheCarlisleHouse/support/slideshow/large/25liv.jpg
h ttp://tourimaging.com/vt/TheCarlisleHouse/support/slideshow/large/24livinsideunit.jpg
Now, an alternative option to above the fireplace might have been the opposite wall, but, for a couple of reasons, my wife would be extremely unhappy with that set-up, so above the fireplace it is. (What can i say? happy wife, happy life). As far as the tv, it is a 51" sammy plasma. The fireplace itself will be gas, and we don't plan on using it often, maybe 1-2 times a year, so I'm not worried about damaging the tv. The distance from the floor to the top of the mantel will be ~65-68 inches. Now, on to my original questions...
1) Before I can decide where to pre-wire, I think I need to decide what speakers to use. The builder's "audio" guy (whose primary practice is alarm installation...) suggested I use in-ceiling speakers. From that point, I knew I would need to consult my own sources. I like the idea of in wall speakers (probably enclosed type) or even on-wall speakers, but I prefer not to use floor speakers. My preferable budget for LCR is around $700-800 total(which eliminates the artison Portraits and such). I've also considered the idea of a phantom center, but I don't have a current setup to test it. Anyways, I was looking for some suggestions for other possible in-wall speakers, which would lead me to my second question
2) where should the speakers be placed? From what ive read, I would want them at ear height when sitting down. However, that would mean that they would be below the mantel and it might not line up mentally with my picture (like the idea of having ceiling speakers). Would an in-wall speaker with directional tweeter (~speaker craft Accufit iw-7) be an appropriate selection?
Basically, at this point, I was hoping to get a few suggestions for speakers and where "exactly" I would need to put them (maybe I should have started with this and skipped the book written above?). Anyways, I hope I covered all of the appropriate variable areas.
Oh, and the receiver I will be using to power them will most likely be an Onkyo mod-level AVR (~$500-700 lever)
Thanks in advance for any and all help!
Greavesk is offline
post #2 of 3 Old 03-25-2012, 08:34 PM - Thread Starter
Greavesk's Avatar
Also, as fas as the reference to the builder's audio guy and in-ceiling speakers: I've always thought the front LCR should be placed on the wall or in line with the tv to avoid the idea that the sound is coming from somewhere else (e.g. Aura effect). However, in this situation with the tv being so high (ughhhhh), could ceiling speakers be appropriate?
Greavesk is offline
post #3 of 3 Old 03-26-2012, 08:42 AM
m_vanmeter's Avatar
installers like in-ceiling installations because they are "easy" and cheap. You are correct, the "front 3" speakers should be in-wall or on-wall, and usually they are centered on the TV. Most in-wall speakers have a pivoting tweeter that can be aimed at the listening position and help with the height offset, while on-wall units can be slightly angled with a wedge block, or something similar, to get the aiming effect, or they have a flexible mount.
The side surrounds (5.1 setup) or side and rear surrounds (7.1) can be in-ceiling units with a pivoting tweeter and a 15 degree angled mid/woofer so they can also be aimed towards the listening position. Speaker layout is usually a series of compromises from the ideal shown on this site, but get as close as you can. NOTE, many "installers" have never bothered to look at the Dolby Labs site. http://www.dolby.com/us/en/consumer/...ide/index.html
m_vanmeter is offline
Reply Speakers
