Banana Plugs not secure.... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 56 Old 03-27-2012, 05:27 AM - Thread Starter
chess's Avatar
I was trying to hook up my Center speaker Martin Logan 8 last night, and the "closed" banana plugs from monoprice dont fit snug in the banana plug slot.
Any suggestions on ones to replace ? I am pretty bummed, as I planned on having everything hooked up today, but I guess that isnt happening.
Any thoughts or suggestions would be appreciated.
Was thinking about buying these instead....
http://www.monoprice.com/products/pr...0115&p_id=2943
Thanks fellas
chess is offline
post #2 of 56 Old 03-27-2012, 06:51 AM
Retspin's Avatar
Quoted: 30 Post(s)
I just got rid of those same Monoprice plugs. I replaced them with GLS black chrome plugs, these have a good snug fit and wire termination is much better and secure than the Monoprice plugs.
http://www.speakerrepair.com/mm5/mer...ode=AHH_Banana
Retspin is offline
post #3 of 56 Old 03-27-2012, 08:14 AM
holt7153's Avatar
Quoted: 139 Post(s)
Liked: 221
Same here (replaced Monoprice with GLS black chrome). GLS bananas are easier for me to work with and look better as well.
Anything good in life is either illegal, immoral, or fattening.
holt7153 is offline
post #4 of 56 Old 03-27-2012, 08:23 AM
bfreedma's Avatar
Liked: 51
The same vendor also offers high quality locking plugs if you want a very secure connection.
bfreedma is offline
post #5 of 56 Old 03-27-2012, 09:16 AM
Dave1027's Avatar
Quoted: 12 Post(s)
You could try taking a small flat blade screwdriver to spread the post part out till it's fatter and fits snug.
BIC DV62si speaker mod for warm musical sound. PM me for info.
Dave1027 is offline
post #6 of 56 Old 03-27-2012, 09:52 AM - Thread Starter
chess's Avatar
Thanks everyone for the replies....
chess is offline
post #7 of 56 Old 03-27-2012, 09:53 AM - Thread Starter
chess's Avatar
I just ordered some different ones... if they dont work I will buy the GLS ones...
Thanks again so much !!
chess is offline
post #8 of 56 Old 03-27-2012, 10:01 AM
commsysman's Avatar
Quoted: 1080 Post(s)
Liked: 569
The best thing to use is the "GR" or General Radio dual banana plug made by Pomona Electronics. They are designed to hold up in the lab being removed and replaced hundreds of times. A standard for 50 years. Top quality.
Amazon has them in red and black for $2.80.
"Pomona Double Banana Plug" - Amazon
commsysman is offline
post #9 of 56 Old 03-27-2012, 10:02 AM
Nethawk's Avatar
Liked: 119
I use GLS locking banana connectors where they add the most convenience, but the most foolproof method is directly connecting wire to terminals. This is the norm in my setup.
Nethawk is offline
post #10 of 56 Old 03-27-2012, 11:00 AM
bfreedma's Avatar
Liked: 51
It's generally best to avoid the dual banana plugs as they require the connectors to be set at the standard spacing and can be difficult to work with and fit in tight spaces. There are numerous speakers and amps/AVR's where they don't work.
If the OP does want to go this route, order one unit first and make sure it fits your application.
bfreedma is offline
post #11 of 56 Old 03-27-2012, 11:08 AM
afrogt's Avatar
Quoted: 1432 Post(s)
Liked: 982
I would agree with the above, not all speaker terminals have the same spacing.
Afro GT
afrogt is offline
post #12 of 56 Old 03-27-2012, 11:14 AM
chikoo's Avatar
I got 14 plugs for $10.97 from Ebay and they fit very well.
http://www.ebay.com/itm/ws/eBayISAPI...E:L:OC:US:3160
chikoo is offline
post #13 of 56 Old 03-27-2012, 01:20 PM - Thread Starter
chess's Avatar
Agreed I dont want dual banana plugs....
chess is offline
post #14 of 56 Old 03-27-2012, 01:40 PM
Bill Fitzmaurice's Avatar
Liked: 5687
+1. Plugs only add unnecessary cost and complexity.
Bill Fitzmaurice is offline
post #15 of 56 Old 03-27-2012, 01:46 PM
ccotenj's Avatar
Liked: 101
ever since you turned me onto the gls plugs, they are my "go to" ones... i use the "safe connect" ones...
to be fair, it can sometimes be a royal pita to wire directly to an avr, especially if you have limited room to work in... for what they cost, they are "worth it" to me... they also eliminate the "stray wire boo boo" that many make...
as far as complexity goes... it's not exactly rocket science to terminate wire with bananas...
- chris
ccotenj is offline
post #16 of 56 Old 03-27-2012, 02:11 PM
Liked: 5687
You would not have to search far to find a thread where the poster stated his complete inability to do so.
post #17 of 56 Old 03-27-2012, 02:30 PM
ccotenj's Avatar
Liked: 101
LOL! yes, i suppose you have a point there...
- chris
ccotenj is offline
post #18 of 56 Old 03-27-2012, 02:39 PM
holt7153's Avatar
Quoted: 139 Post(s)
Liked: 221
They're probably not the most robust plugs in the world, but they're easy to work with, inexpensive, and decent looking.
When are we gonna get our first glimpse of your custom cables? .
holt7153 is offline
post #19 of 56 Old 03-27-2012, 02:43 PM
Nethawk's Avatar
Liked: 119
I agree on the receiver/amp side that banana plugs are convenient, but will also agree as simple as they are to apply they are still the only point of failure, and if they can be avoided it's best.
Nethawk is offline
post #20 of 56 Old 03-27-2012, 02:50 PM
ccotenj's Avatar
Liked: 101
soon, hopefully... i've got the pants, nanners/spades and speakons... waiting on techflex and heat shrink, should be here by end of week...
conduit is run (although needs to be painted), center speaker stand and box for next to the rack are done, just need to solder the male speakons with some short connector wires and install them into rack box... with any kind of luck, should be new pics in the build thread next week...
- chris
ccotenj is offline
post #21 of 56 Old 03-27-2012, 02:57 PM
holt7153's Avatar
Quoted: 139 Post(s)
Liked: 221
nice, should be interesting with the speakons.
holt7153 is offline
post #22 of 56 Old 03-27-2012, 03:31 PM
Nethawk's Avatar
Liked: 119
Sorry, but what are speakons?
I hope you didn't get rattlesnake techflex. It was the only thing available to remotely match my stellar interior design (which is not based upon anything reptilian) and it's butt ugly! Cables are made, so I'm going to live with them for awhile but I expect to tire of them quickly.
Edit, nevermind, I used the google for speakon info. Very cool!!!
Nethawk is offline
post #23 of 56 Old 03-27-2012, 04:15 PM
hermeslyre's Avatar
Easier still, unscrew the banana end from the jacketed end, put it length wise between a pair of pliers or channel locks and gently squeeze. The banana's flair out beautifully.
I even do this to my new banana plugs from monoprice, I like 'em snug. I can't justify spending extra money on something new when this problem can be remedied so easily.
hermeslyre is offline
post #24 of 56 Old 03-27-2012, 04:49 PM
4DHD's Avatar
Quoted: 205 Post(s)
Liked: 114
But the standard way for bare wire is to 'tin' the wire so you don't get loose, bent wire strands. And stops corrosion.
Custom, one of a kind pair, MJC212 mains, mod PT800 center, PT800 surrounds, SUB1500s. Parasound P7, Citation 19, Parasound HCA2205A, HK AVR3600, Marantz TT, Samsung BD player, Denon DVD-A player, MacBook Pro w/ Dirac Stereo Suite.
4DHD is offline
post #25 of 56 Old 03-27-2012, 05:12 PM
afrogt's Avatar
Liked: 982
I'll take banana plugs all day before using only bare wire again. It is much more convenient with banana plugs. It makes it much easier to just plug in than unscrewing the terminals and inserting bare wire.
And I like to switch my speakers around trying out different combinations so banana plugs on the speaker end is a no brainer for me.
Afro GT
afrogt is offline
post #26 of 56 Old 03-27-2012, 05:24 PM
jproy13's Avatar
Liked: 26
I use the same ones with no probs
jproy13 is offline
post #27 of 56 Old 03-27-2012, 06:30 PM
CalgaryCowboy's Avatar
I have always used the "safe" type (another brand) and never seen the screw type. Is there a non convenience advantage to one or the other?
My review comparisons of Energy RC-70s to Veritas V6.3 http://www.avsforum.com/avs-vb/showt...8#post21199418
CalgaryCowboy is offline
post #28 of 56 Old 03-27-2012, 07:10 PM
ccotenj's Avatar
Liked: 101
true...
but realistically, how many have a soldering iron thee days?
- chris
ccotenj is offline
post #29 of 56 Old 03-27-2012, 07:32 PM
Liked: 5687
Don't tin. The screw won't grip it as tightly as bare wire, so it's more likely to loosen. And tinning doesn't stop corrosion. In fact soldering flux promotes oxidation.
post #30 of 56 Old 03-28-2012, 03:31 AM
4DHD's Avatar
Quoted: 205 Post(s)
Liked: 114
I've never seen either happen. But I only use silver solder.
I've bought a couple of those types, I don't like them as much as the ones sold in RS. That you bend the wire over the collar edge and then screw on the tip.
I also bought the welded locking banana plugs from BJC. I like the fact the wire is welded, but I'm not too thrilled with how they tighten to the amp or speaker. In fact one banana plug, the thongs broke off after a few times being tightened, making it totally useless.
4DHD is offline
Reply Speakers
