speaker high and dipolar suggestions for me? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-27-2012, 06:29 PM - Thread Starter
amb7247's Avatar
what are some good dipolar speaker that would complement the TSC TSS speaker since you can't get them anymore?
And what about the front high's?
Xbox Live: ShadyFusion23
PSN: Nukleard1sa5t0r
amb7247 is offline
post #2 of 2 Old 03-27-2012, 07:36 PM
Espo77's Avatar
Quoted: 179 Post(s)
Liked: 84
I'm a bit confused about the above post. What are you running, 7.1...9.1?
What exactly do you have now, and what do you want to add to your system? Timber matching is what you want to end up with, but there are other things to consider when miss matching speakers.
Post more detailed info on your current configuration, and where you want to go with your system, and I'm sure you'll get your responses.
Espo77's living room equipment: RECEIVER: Yamaha RX-A3030- SPEAKERS: Boston Acoustics M350, M25 center, surrounds, and front heights-
BLU-RAY: Oppo BDP103D- SUBWOOFER: HSU VTF-15H MK2- dedicated circuits for A/V- TV: Vizio P55C-1
Auralex Acoustics LENRD - Auralex Acoustics Roominator
Espo77 is offline
Reply Speakers
