Home theater - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 04-01-2012, 08:59 PM - Thread Starter
semschaf's Avatar
Please help! I am building a home theater with either in wall or on wall speakers. Will be used 80% movies 20% music. My budget is around 4K. I am considering definitive technology mythos xtr-60 or mythos ten, and possibly artison masterpiece. I am open to other suggestions as well. Please advise.
semschaf is offline
post #2 of 14 Old 04-01-2012, 09:09 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Room size, and layout considerations (is there a reason for on/in-walls)? Is $4k for speakers/subs/receiver?
Jay1 is offline
post #3 of 14 Old 04-01-2012, 09:12 PM - Thread Starter
semschaf's Avatar
It is already wired for on walls. Large room 16x45 with 14 foot ceilings.
semschaf is offline
post #4 of 14 Old 04-01-2012, 09:13 PM - Thread Starter
semschaf's Avatar
Yes speakers sub and receiver however budget is slightly flexible
semschaf is offline
post #5 of 14 Old 04-01-2012, 09:20 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Do you have a quick sketch of how this is going to be placed (speakers and seats) in a very long, narrow room like that?
Jay1 is offline
post #6 of 14 Old 04-01-2012, 09:23 PM - Thread Starter
semschaf's Avatar
Tv is mounted over fireplace facing the long direction of the room. The other end of the room is a bar.
semschaf is offline
post #7 of 14 Old 04-01-2012, 09:29 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Ok so you have the 45' area cut down, just one row of seating? How far back from the tv will your seats be?
Jay1 is offline
post #8 of 14 Old 04-01-2012, 09:32 PM - Thread Starter
semschaf's Avatar
Yes one row about 15 feet from the tv
semschaf is offline
post #9 of 14 Old 04-01-2012, 09:52 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Ok that is far more manageable speaker wise! You will still need a sub capable of filling the entire volume of the room if you want bass you can feel. Those Def Techs are still much to small, I wouldn't bother with them. I would look at something like JBL L-series, LC2, L820, L810 for the 5 channels, then something like an Onkyo 809 receiver, for the kicker add a Captivator 1000 for an attempt to pressurize that room.
Jay1 is offline
post #10 of 14 Old 04-01-2012, 09:55 PM
callas01's Avatar
Quoted: 829 Post(s)
Liked: 463
Id suggest 2 subs, Hsu VTF series would be a good start. Receivers, onkyo is always good. Speakers.... audition, find what YOU like in your price range.
Dynaudio Focus 260s, Focus 210C, DM 2/6, Hsu VTF3 MK5 HP, Oppo BDP-103, NaimUniti 2, Naim Stageline N, Pro-ject 2xperience Classic, Marantz SR7007, 60" 4K Samsung LED LCD
callas01 is online now
post #11 of 14 Old 04-01-2012, 10:01 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
You're probably annoyed with all the questions, but out of curiosity do you plan on mounting the speakers above your tv, which is over the fireplace? If so you're going to need speakers designed for that kind of height. If that's the case I change my recommendation to these JBL 8320's for all channels if they are high on the wall.
Jay1 is offline
post #12 of 14 Old 04-01-2012, 10:05 PM - Thread Starter
semschaf's Avatar
I plan to mount the center directly above or below the tv. The left and rights are at 8 feet but I may try to move them down.
semschaf is offline
post #13 of 14 Old 04-01-2012, 10:07 PM - Thread Starter
semschaf's Avatar
And I greatly appreciate the questions and the help.
semschaf is offline
post #14 of 14 Old 04-01-2012, 11:28 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Ok, as long as you can get them closer to ear level it won't be a big deal. Ideally you would want your l/c/r all at the same height and identical, so if you can swing it three of those LC2's I linked earlier across the front would be best. All mounted equally spaced and level below your tv.
Jay1 is offline
Reply Speakers
