martin logan mlt-1 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 04-02-2012, 06:25 AM - Thread Starter
montyburns1's Avatar
so newegg has the mlt-1 5.1 set for 250...
i was thinking about slowly building up a set of polk audio monitors, but now this deal seems pretty sweet...
any advice?
montyburns1 is offline
post #2 of 6 Old 04-02-2012, 08:14 AM
buzzy_'s Avatar
Quoted: 66 Post(s)
Liked: 89
Yes,
1) Hang on for a deal on the MLT-2s, the larger size significantly improves the sound quality
2) Consider trying out the search feature here and on Google, there's a lot of discussion about these
buzzy_ is offline
post #3 of 6 Old 04-02-2012, 08:41 AM - Thread Starter
yah i did a quick google search, and didnt find too much...ill keep looking.
how much should a set of mlt-2's go for? how do they compare to building a set of polks?
post #4 of 6 Old 04-02-2012, 09:19 AM
afrogt's Avatar
Quoted: 1059 Post(s)
Liked: 762
MLT-2 comes on sale for around $300 at Newegg.com. Sign up for their email specials.
What Polks are you trying to compare them with? If you mean Monitor series speakers I'd rather go with the Polks. Even the Monitor 30's have 5.25" drivers and play lower than the MLT-2 satellites.
Afro GT
afrogt is offline
post #5 of 6 Old 04-02-2012, 10:40 AM - Thread Starter
yah i was thinking of slowly putting together a set of the monitors. 30s at first, then maybe a center, then a sub, then 2 40s...
post #6 of 6 Old 04-02-2012, 10:43 AM
pokekevin's Avatar
Liked: 102
I have The mlt 2s. Id suggest svaing up for seperate components
pokekevin is offline
Reply Speakers
