Klipsch wb14 vs pioneer bs41 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 04-02-2012, 12:55 PM - Thread Starter
SDB30's Avatar
Quoted: 14 Post(s)
I currently own the 4 pioneer bs41's and a c21... I am pretty satisfied, but want something a bit better, I am on a budget. The pioneers seem to lack highs, I don't listen to much music, just gaming and movies. Would this be a good upgrade? I am using a 10 inch woofer, so lows wont be an issue. Also any other cheap bookshelf recommendations are appreciated, thanks!
SDB30 is offline
post #2 of 14 Old 04-02-2012, 01:14 PM
afrogt's Avatar
Quoted: 1335 Post(s)
Liked: 923
If you like horn tweeters then they may work for you. Will definitely be brighter than your Pioneers.
Afro GT
afrogt is offline
post #3 of 14 Old 04-02-2012, 01:42 PM - Thread Starter
SDB30's Avatar
Quoted: 14 Post(s)
The pioneers just don't seem to have much impact, very even. I just want something more dynamic. The pioneers get great reviews, but they don't really impress me, dunno... could be my receiver, denon avr391.
SDB30 is offline
post #4 of 14 Old 04-02-2012, 01:59 PM
wywern209's Avatar
thats not true. the pioneers were designed to have a flatish response. Like someone suggested, you should try out the horn tweeters from klipsch. also, try the arx A1. i've heard good things about its planar tweeter.
wywern209 is offline
post #5 of 14 Old 04-02-2012, 04:50 PM
JoeNc's Avatar
Quoted: 102 Post(s)
Liked: 50
hey sdb30, I have the wb14s , was using them as surrounds with the wf34s..
now have the wb14s as fronts for pc gaming plus sub 10... very good the highs are very clear with the klipsch.
But, I also have the Energy rc 10's and if you can spend the extra $50 it'd be worth the cost. Vanns has them on sale right now. but noticed newegg has the klipsch on sale !
I think either would be good with sub as long as the room isn't huge.
How big is the room ?
JoeNc is offline
post #6 of 14 Old 04-02-2012, 05:28 PM - Thread Starter
SDB30's Avatar
Quoted: 14 Post(s)
The room is only 12 x12, strictly a game/movie room. I'll check out the energy speakers as well
SDB30 is offline
post #7 of 14 Old 04-02-2012, 05:52 PM - Thread Starter
SDB30's Avatar
Quoted: 14 Post(s)
What are the thoughts on various Polk speakers? They seem to be really popular, and they're priced well.
SDB30 is offline
post #8 of 14 Old 04-02-2012, 06:12 PM
zieglj01's Avatar
Quoted: 1422 Post(s)
Liked: 1261
The Boston A26 will also give you more treble.
The price is for New, and not refurbish.
Price is for each.
http://www.accessories4less.com/make...s-White/1.html
__________________________________________
Who AM I
Speakers -- Snell K7 > Digital Phase AP-.5 > Harman Kardon Ten > Boston VS240 -- Receiver > Integra 50.2
zieglj01 is offline
post #9 of 14 Old 04-03-2012, 03:44 AM - Thread Starter
SDB30's Avatar
Quoted: 14 Post(s)
The Boston's look pretty awesome, I think those might be the ones
SDB30 is offline
post #10 of 14 Old 04-03-2012, 10:06 AM
crazyrob425's Avatar
Quoted: 443 Post(s)
Liked: 337
I would look at the RTi series they will put the Pioneers to shame
I absolutely love my RTi4's for such a small speaker they have a great mid-range, and the highs have great detail
crazyrob425 is offline
post #11 of 14 Old 04-03-2012, 01:12 PM
Dave1027's Avatar
Quoted: 12 Post(s)
Nope. The Pioneers are on the dull side. I A/B'd them at Best Buy. Some people really like a laid back sound. That's why a lot of people like them. Some poeple want more sizzle. You must fall into that category.
BIC DV62si speaker mod for warm musical sound. PM me for info.
Dave1027 is offline
post #12 of 14 Old 04-04-2012, 05:52 AM - Thread Starter
SDB30's Avatar
Quoted: 14 Post(s)
Well, I took all the grills of the speakers and turned the treble up a little bit on the receiver and it helped out a bit. I think I may just wait and save up enough money to buy some nice towers instead of getting more bookshelf speakers. Thanks for all the advice!
SDB30 is offline
post #13 of 14 Old 04-04-2012, 08:30 AM
KidHorn's Avatar
Quoted: 1460 Post(s)
Liked: 962
I have a pair of wb14's. They sound great for their size and look good too. Not much bass, but if you have a sub, they don't need it.
KidHorn is offline
post #14 of 14 Old 04-04-2012, 09:29 AM
bhazard's Avatar
Quoted: 89 Post(s)
Liked: 57
Look into high sensitivity speakers with horn tweeters like Klipsch. Klipsch isn't exactly budget friendly though.
You may like the Acoustech line, which is similar to Klipsch and cost less.
I went exactly opposite compared to how you are now. I originally had the Acoustechs for awhile (bright) which I loved, but changed over to the Pioneers and found that I liked them better.
bhazard is offline
Reply Speakers
