$500-800 5.1 speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 29 Old 04-04-2012, 10:52 AM - Thread Starter
damthrill's Avatar
Is there a good set of 5.1 speakers including sub on sale for $500 to $800. I was thinking some that may be on speaker stands, the front can be a tower.
I will use a denon 2312 to power.
I was looking at cheapy martin logans but they aren't made by martin logan.
Thanks in advance,
damthrill
damthrill is offline
post #2 of 29 Old 04-04-2012, 11:11 AM
Nethawk's Avatar
Liked: 118
Thanks in advance,
damthrill
There are a few posts with recommendation in this price range, you can search or browse through the topics in the speaker forum.
While seldom recommended, I would take a look at Mordaunt Short Carnival line. There are very few owners here on AVS, but every review I have found on the internet gives high praise for both quality and value. I own their small monitors, the Carnival 2, and every time they're turned on they make me smile. An entire 5.0 setup can be had from Amazon for $900, $800 if the Carnival 1 are used for surrounds.
Nethawk is offline
post #3 of 29 Old 04-04-2012, 11:12 AM
afrogt's Avatar
Quoted: 1054 Post(s)
Liked: 756
You could buy two pair of Energy RC-10's for $250/pr
http://www.vanns.com/shop/servlet/it...ures/542469405
Add the matching RC LCR center for another $250
http://www.vanns.com/shop/servlet/it...ures/542600578
You'd only have $50 left but you could buy this cheap sub for $100 and be $50 over his budget.
http://www.parts-express.com/pe/show...number=300-635
Or skip the sub for now and save up until you can ge a better one.
Or if you really want Martin Logan, Newegg has the ML-10 on sale for $130 each with promo code EMCNFNG32. Get 4 of those.
http://www.newegg.com/Product/Produc...82E16882981007
I don't know where you find the matching center speaker though.
Afro GT
afrogt is online now
post #4 of 29 Old 04-04-2012, 11:18 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
To be fair, I just posted this in another thread.
Sammy2 is offline
post #5 of 29 Old 04-04-2012, 11:31 AM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Look at Boston
A 360
http://www.accessories4less.com/make...h-White/1.html
A 225C
http://www.accessories4less.com/make...r-White/1.html
A 25
http://www.accessories4less.com/make...s-White/1.html
Save up for a nice sub
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is online now
post #6 of 29 Old 04-04-2012, 11:47 AM
afrogt's Avatar
Liked: 756
Another option
Jamo S606 HCS 5.0 system and HSU STF-2 10" subwoofer.
Dark Apple, $400
http://www.vanns.com/shop/servlet/it...ures/544012176
Black, $350
http://www.vanns.com/shop/servlet/it...ures/544231343
HSU STF-2 subwoofer, $349 plus $43 shipping
http://hsuresearch.com/products/stf-2.html
Afro GT
post #7 of 29 Old 04-04-2012, 12:36 PM - Thread Starter
damthrill's Avatar
You guys just flooded me with options, this will actually take a little bit to sort thru. I currently have the abyss by martin logan sub woofer. I think it sounds good. maybe I can look for something that delivers near the same bass with alot less price as you guys say after i get 5 five speakers.
post #8 of 29 Old 04-04-2012, 12:49 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Good call holding off on the sub. The "hidden gem" budget speaker is the Behringer 2031p. You can get 5 for $650 (single). You wont be able to match the big dynamic accurate sound with the typical mini monitors available in this price range.
Jay1 is offline
post #9 of 29 Old 04-04-2012, 01:01 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Not quite sure how that covers the mid range with a tweeter and 8 3/4" woofer?
Sammy2 is offline
post #10 of 29 Old 04-04-2012, 01:10 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Pretty well actually
Only at 60 degrees off axis does the mid range even really start to droop
Jay1 is offline
post #11 of 29 Old 04-04-2012, 01:25 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
That is pretty flat but there's a little bit of a hole at 250Hz to 600Hz?
Sammy2 is offline
post #12 of 29 Old 04-04-2012, 01:27 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
I have a question, Do you have access to these SPL's vs f for other brands?
Sammy2 is offline
post #13 of 29 Old 04-04-2012, 01:27 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
The off axis measurments are only good from 400hz up
Jay1 is offline
post #14 of 29 Old 04-04-2012, 01:29 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Just the ones I can find online
Jay1 is offline
post #15 of 29 Old 04-04-2012, 01:31 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Okay. Trying to find some for a Polk PSW 10 and the new HTD's I just bought but not having much luck.
Sorry for the interuption. Now back to our regularly scheduled program..
Sammy2 is offline
post #16 of 29 Old 04-04-2012, 03:21 PM
slider34z's Avatar
www.htd.com
I really like the Level Two set from them. LCR for a little more than $500
But I'm biased because I own them. Good luck!
slider34z is offline
post #17 of 29 Old 04-04-2012, 04:33 PM
smasher50's Avatar
Quoted: 355 Post(s)
Liked: 15697
how big is your room and is this just for tv/movies or for gaming and music also
i'm so laid back,i'm laid out
smasher50 is online now
post #18 of 29 Old 04-04-2012, 06:51 PM - Thread Starter
damthrill's Avatar
its a good sized living room without measuring it might be 15-18 feet wide and about 20-22 ft deep.
post #19 of 29 Old 04-04-2012, 06:57 PM - Thread Starter
damthrill's Avatar
the bookshelf speakers arent that appealing, is there any decent stand mount and towers? might look nicer
post #20 of 29 Old 04-04-2012, 07:00 PM
afrogt's Avatar
Liked: 756
Bookshelf speakers can easily be placed on stands...
What exactly is your definition of "stand mount"?
Afro GT
post #21 of 29 Old 04-04-2012, 07:02 PM
Khaos's Avatar
Hi, if your holding off on a sub I would probably recommend these:
http://www.lockwaresystems.com/D10HT-111-169.html
(Give paul a call for an accurate price and cabinet)
I am a swan/hivi fan, so I'm a bit biased, but I have been nothing short of amazed by the way swan sounds. The drivers in this model tend to be rated quite highly:
M4N: http://www.parts-express.com/pe/show...97-434&FTR=m4n
TN25: http://www.parts-express.com/pe/show...number=297-408
BG8N: (Not sold in America, however, being the bass driver, the towers are rated down to 35hz)
Being that swan's track record with me has been exceptional, I can only imagine that these would sound great for the price. Plus with the deep bass, holding off on a new subwoofer will be much easier xP
Please tell me what happened in this night.
It's like the cat inside the box.
You don't know if the cat in the box is dead or alive.
The cat in the box was dead.
Khaos is offline
post #22 of 29 Old 04-04-2012, 07:08 PM
afrogt's Avatar
Liked: 756
Those look cool but with $120 shipping it takes him over $1000.
Maybe he can spend more?
Afro GT
post #23 of 29 Old 04-04-2012, 07:26 PM
smasher50's Avatar
Quoted: 355 Post(s)
Liked: 15697
just a suggestion
pair of pioneer sp-f51 fronts $200 newegg
pioneer sp-c21 center $95 amazon (sold out newegg)might get cheaper if you look
pair pioneer sp-b21 rears $100
premier acoustics pa150 sub $425 acousticsounddesignyou can probably make offer of $350 on make your best offer sheet and get it(overstock.com hason sale today for $394 + $2.95 ship
total $820 shipped
post #24 of 29 Old 04-05-2012, 09:27 AM
Khaos's Avatar
That's why I said give paul a call, I'm not quite sure how accurate the prices are. You can find his number on the swan dealer list.
Khaos is offline
post #25 of 29 Old 04-05-2012, 10:00 AM
bladerunner6's Avatar
Quoted: 20 Post(s)
Liked: 59
another option
jamo s606 hcs 5.0 system and hsu stf-2 10" subwoofer.
Dark apple, $400
black, $350
hsu stf-2 subwoofer, $349 plus $43 shipping
+1
bladerunner6 is offline
post #26 of 29 Old 04-05-2012, 11:33 AM - Thread Starter
damthrill's Avatar
The Jamos have raging reviews, are they really that good? What I meant by stand was a small frame or slender stand that holds the speakers about ear level particularly for the rears since fronts would be a tower, the center i have to think about based on the placement of my projector screen I can make a stand for that, I can weld a stand for the center and paint it if I can't find one to get the center to my desired height.
I like the rich elegant wood look but wife wants boring black, is their sub any good?
post #27 of 29 Old 04-05-2012, 11:47 AM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
They're decent speakers, but remember you're in a large room. These Jamo's have 4" woofers.
Jay1 is offline
post #28 of 29 Old 04-05-2012, 11:55 AM
afrogt's Avatar
Liked: 756
Is the HSU STF-2 sub any good? It's very good and comes highly recommended in its price range. Or do you mean a Jamo sub? I wouldn't get the Jamo sub210 that you see on Vanns website. It cant compare to the HSU by any stretch of the imagination.
Here are some photos of the Dark Apple S606, they do look elegant.
http://www.minhembio.com/Sleeping%20Sun/133026/
Have no idea what language that is.
Afro GT
post #29 of 29 Old 04-06-2012, 05:20 PM
smasher50's Avatar
Quoted: 355 Post(s)
Liked: 15697
Originally Posted by smasher50 View Post
just a suggestion
total $820 shipped
update newegg has the sp-f51's for $129 and the sp-b21's for $49 sale ends 4/8
Reply Speakers
