Suggestions for Noob - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 04-05-2012, 07:19 AM - Thread Starter
r0nd3L's Avatar
I'm finally looking to replace my Sony HTIB. I think I'll start by getting AVR, main speakers, center, sub, and 2 outdoor speakers for zone 2.
For the receiver, I'm looking at Denon 2112ci. I need help with the speakers, though.
Bad thing, there is no floor space so bookshelves are probably the only option. I would prefer to wall mount them as that's where current Sony speakers are mounted and the wires are already routed.
This will be used for 80% movies and 20% music. I want music to pound, though
In before search first.
r0nd3L is offline
post #2 of 12 Old 04-05-2012, 07:22 AM
cel4145's Avatar
Quoted: 2668 Post(s)
Liked: 3002
Budget?
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | HE-400i | NAD HP50 | Sony MDR-1A | Soundmagic E50 & E80 | X5ii | DX50 | E12
cel4145 is offline
post #3 of 12 Old 04-05-2012, 07:51 AM - Thread Starter
r0nd3L's Avatar
Originally Posted by cel4145 View Post
Budget?
Sorry, completely forgot this important part considering the price range of different speakers.
I'd like to keep it around $1,000 for front pair, center, and sub. Or maybe I would be better of buying just the front pair for now and the rest later, which would allow me to spend some more.
Here is the space I'm working with. The sub is located between the cabinet and the couch on the right side. Surround speakers on the side walls behind the couches. Could I potentially squeeze towers between the fireplace and the cabinets? Or would they be too tight in there?
r0nd3L is offline
post #4 of 12 Old 04-05-2012, 11:16 AM
cel4145's Avatar
Liked: 3002
Since you want to wall mount, best to go with sealed or front-ported speakers, or rear-ported speakers that are meant to be plugged.
I like the Energy RC series. The RC-10s and RC-LCR would work (or 3 RC-LCRs), although you would need to use the port plug that comes with them.
For subs, look at the BIC F12 (<$190), Premier Accoustic PA-120, or BIC PL-200 (around $280). The PL-200 is the higher output of the three.
If you can wait on the sub, 12" subs from ID vendors such as Epik, HSU, SVS, Outlaw Audio, and Rythmik are much better, but currently out of your budget range.
cel4145 is offline
post #5 of 12 Old 04-06-2012, 02:04 AM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 221
What's the measurements between the tv and the top of the fireplace? That looks like a pretty small space for a center...
Jay1 is offline
post #6 of 12 Old 04-06-2012, 08:40 AM
zieglj01's Avatar
Quoted: 1710 Post(s)
Liked: 1626
Wall-mount seems to be the way to go. I would look at a pair
of the Atlantic Technology FS-3200 speakers.
Move down the page
https://dmc-electronics.com/Others.html
And a Rythmik or Epik sub
http://www.rythmikaudio.com/FV12.html
http://www.epiksubwoofers.com/legend.html
__________________________________________
Who AM I
Speakers -- Canton GLS 2 > Boston VS240
Receiver -- Integra 50.2
zieglj01 is online now
post #7 of 12 Old 04-09-2012, 11:45 AM - Thread Starter
r0nd3L's Avatar
Thanks for suggestions! It's definitely a tough decision. Would wall mounts sound good enough?
Jay, I could potential cut a whole in the fake(gasp!) fireplace and mount it there.
And Epik subwoofer is definitely in my future.
r0nd3L is offline
post #8 of 12 Old 06-19-2012, 08:57 AM - Thread Starter
r0nd3L's Avatar
Well, I had to put this on hold, but finally I ordered a pair of front speakers yesterday. I went against the suggestions here and ordered DefTech BP6s. Electronics-Expo had a great deal with a coupon - $370 shipped for the pair of $800 speakers.
I also ordered Denon 3312ci receiver.
Now, I just need to find a center channel to match those, what would you guys suggest? I'm not sure if I can get another tower for the center? DefTech doesn't seem to have any bipolar centers, but that must be for a reason.
r0nd3L is offline
post #9 of 12 Old 06-19-2012, 01:54 PM
cel4145's Avatar
Liked: 3002
I'm not familiar with those Def Techs, but whatever center channel they sell to match. Not a good thing for your front sound stage to use a mismatched center. I'd go without one first.
You might research and ask in the Def Tech owners thread.
cel4145 is offline
post #10 of 12 Old 06-19-2012, 02:26 PM - Thread Starter
r0nd3L's Avatar
I agree with that. I will not be buying a center channel till later this year, but the sooner I start researching/asking opinions the better idea I will have smile.gif
Simultaneously to my post, I sent an email to DefTech support. Here is the e-mail I receieved:
Thanks for your recent email to Definitive Technology. I would recommend using our ProCenter 2000 center speaker. This model sounds clear, detailed and full. It’s also considered voice matched or timbre matched to the BP6Bs.
ProCenter 2000 seems to be in my budget, so I will search this forum for some reviews.
r0nd3L is offline
post #11 of 12 Old 06-19-2012, 03:45 PM
cel4145's Avatar
Liked: 3002
Definitely check out the Def Tech owners thread then, and even ask their opinion. The active owners threads here on AVS like the Def Tech one are a great resource for questions like this. smile.gif
cel4145 is offline
post #12 of 12 Old 06-19-2012, 04:18 PM
zieglj01's Avatar
Liked: 1626
The ProCenter will work - however, keep an eye out for the CLR2002 - this is the better option,
if you can work it in your budget.
http://www.amazon.com/Definitive-Technology-Speaker-Single-Black/dp/B000TD8XCU
http://www.definitivetech.com/products/products.aspx?path=Floor-Standing_Speakers&productid=BP6B
Who AM I
Reply Speakers
