Replace center speaker or L&R front speakers? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 04-05-2012, 09:40 PM - Thread Starter
SquirlKiller's Avatar
I don't exactly have much money to spend, so I am not sure which to replace: the center speaker or L&R front speakers (or rear speakers)?
The speakers I have now are what came with this: http://www.amazon.com/Samsung-HT-TX7.../dp/B000PU6MAC
SquirlKiller is offline
post #2 of 12 Old 04-05-2012, 10:37 PM
Joebilly's Avatar
First of all, what is your budget?
In general, you should upgrade all 3 (left, right, and center) in order to match the timbre of the front speakers. Otherwise, if dialogue or action moves from left to right, the same person or object will sound different as it moves along the different speakers.
With that said, you also have to make sure that you can upgrade the speakers at all. Some HTIB have a proprietary connection that prevents you from upgrading to better speakers. If you were able to use generic speaker wire, then you're set.
Hope this helped!
Josh
Joebilly is offline
post #3 of 12 Old 04-06-2012, 06:38 PM
m_vanmeter's Avatar
also, many inexpensive HTiB sets have amplifiers which expect to output to 2 or 3 Ohm speakers (thats how they get their outrageous power claims). If you attach 8 Ohm speakers, the apparent "loudness" may decline.
m_vanmeter is offline
post #4 of 12 Old 04-07-2012, 09:30 PM - Thread Starter
Budget is $150-$200 (US) the speakers are connected through standard speaker wire
post #5 of 12 Old 04-07-2012, 09:52 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Jay1 is offline
post #6 of 12 Old 04-07-2012, 11:48 PM
Joebilly's Avatar
+1 to the Pioneers.
If you plan to make a next step, you'll want to upgrade the sub. The solid Dayton 8" sub is the minimum you'll want to spend for it to be a worthwhile upgrade.
Joebilly is offline
post #7 of 12 Old 04-08-2012, 02:57 PM
Ratified's Avatar
+2 to the Pioneers. I am running 3 of the c21 LCR setup and they sound better than most $600+ setups Ive heard.
Samsung 51" Plasma E530, Pioneer SC-1222-K, Sony BDP-S5200, Roku 3, Custom HTPC/XBMC, KEF Q600c -center, KEF Q900- mains, Definitive Technology SM450- side surrounds, Definitive Technology SM350- rear surrounds, Custom sub 'end table' with 12" Oz Audio Matrix Elite, Crown XLS 1500 sub amp, Harmony Ultimate and IRule remotes
Ratified is offline
post #8 of 12 Old 04-08-2012, 04:26 PM
patricksull's Avatar
I would buy a used set off the classified area here, ebay, or audiogon. People are always upgrading and there are deals to be had on used speakers. Just my input.
patricksull is offline
post #9 of 12 Old 04-08-2012, 09:17 PM - Thread Starter
A question, the current center speaker i have says Impedence is 3, but the Pioneer SP-C21 says 6, will anything be damaged by using it with my current htib? I read m_vanmeter's post and i interpret that it would just not be loud as it would be. If this is true, will it be equally as loud as the current speaker?
post #10 of 12 Old 04-10-2012, 05:09 PM - Thread Starter
anyone?
post #11 of 12 Old 04-10-2012, 09:03 PM
Joebilly's Avatar
Yea, going higher won't short your receiver, but it will force it a lot more. It'll probably decrease the life of the receiver, but you'll need (want?) to upgrade that once you have the funds.
Joebilly is offline
post #12 of 12 Old 04-11-2012, 08:22 AM
afrogt's Avatar
Quoted: 1335 Post(s)
Liked: 923
Pioneers are a very good start for the money. Eventually you'll want to get away from your HTIB receiver so these would go well with whatever you buy next too.
Afro GT
afrogt is offline
Reply Speakers
