Surround speaker level - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-07-2012, 07:24 AM - Thread Starter
destiny 21's Avatar
Quoted: 12 Post(s)
hi i have a pair of energy vs surround speakers and when i run audessy it sets the level of one of them at -10 and the other at -5. do you think they both should be set at the same level
destiny 21 is offline
post #2 of 5 Old 04-07-2012, 07:53 AM
jimfrench's Avatar
Not necessarily, it judges what's needed in its findings and adjusts for balance. You can probably manually reset it to your own taste. The number is often reasonably close, but most people fine tune.
jimfrench is offline
post #3 of 5 Old 04-07-2012, 09:32 AM
dharel's Avatar
Liked: 33
Check what it calculated the speaker distances to. A difference in levels like that may indicate the surrounds are no equidistant.
dharel is offline
post #4 of 5 Old 04-07-2012, 03:29 PM
HAMP568's Avatar
Quoted: 22 Post(s)
Liked: 31
I'm with you -10 and -5 is a big difference. How was the mic placed? Where you using a mic/camera stand or did you lay it flat on the top of your chair?
How far apart are you speakers?
HAMP568 is offline
post #5 of 5 Old 04-07-2012, 07:56 PM
Espo77's Avatar
Quoted: 179 Post(s)
Liked: 84
Do you have a "Reference Disc" that you can pop in and check out the surround effects? ... a movie scene or a song on a Blu-Ray that you know very well. Play it and listen.
Espo77's living room equipment: RECEIVER: Yamaha RX-A3030- SPEAKERS: Boston Acoustics M350, M25 center, surrounds, and front heights-
BLU-RAY: Oppo BDP103D- SUBWOOFER: HSU VTF-15H MK2- dedicated circuits for A/V- TV: Vizio P55C-1
Auralex Acoustics LENRD - Auralex Acoustics Roominator
Espo77 is offline
Reply Speakers
