Energy RC 10 vs Polk rti a3 vs klipsch rb 51 ii vs klipsch rb 61 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 04-08-2012, 08:33 PM - Thread Starter
mickyd98's Avatar
I am looking to set up a speaker system in my bedroom for music only. I do not have access to a store where I can listen to these speakers. I am also new to the world of speakers so if you know of any other speakers in my price range (up to $400) could you please suggest them. I will be listening to mostly jazz and techno. If you have used any of these speakers could you also list your setup. Aswell as cds I would also like to play music from my ipod, my music is all in Apple lossless format (.m4a).
mickyd98 is offline
post #2 of 15 Old 04-08-2012, 11:18 PM
CalgaryCowboy's Avatar
For music only I would go to RC-10s. Very detailed and smooth for music. Great for Jazz but a little laid back (lacking attack if you know what I mean?) for techno. Still better than those other IMHO. Find horn tweeter to harsh for music and the Polk is to soft and lacks detail.
My review comparisons of Energy RC-70s to Veritas V6.3 http://www.avsforum.com/avs-vb/showt...8#post21199418
CalgaryCowboy is offline
post #3 of 15 Old 04-08-2012, 11:26 PM
pokekevin's Avatar
Liked: 102
For just music take a look at the s30s from cambridge. I used the rc 10s and s30s before and both are great! Dig low for bookshelves. If you listen to a lot of bass songs check out the hsu hb1 mk2s
pokekevin is offline
post #4 of 15 Old 04-09-2012, 12:29 AM
cel4145's Avatar
Quoted: 2657 Post(s)
Liked: 2987
Although on the plus side, what I like about the RC-10s is the strong mid-bass for their small size. They will need a sub for that low end bass for techno; any speaker this size will.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #5 of 15 Old 04-09-2012, 03:36 AM - Thread Starter
mickyd98's Avatar
Thanks for all the suggestions so quickly I think i'll go with the RC 10s. Also do you have any suggestions for a receiver or integrated amp for at most 150 -200?
mickyd98 is offline
post #6 of 15 Old 04-09-2012, 08:32 AM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
You may want to look used for a receiver if you only want to spend $150-$200.
Since the RC-10's only cost $250/pr, can you add that to your receiver budget?
Whoops, I see the price is back up to $299/pr. Call Vanns and you might be able to get a better deal by speaking with a salesperson.
Afro GT
afrogt is online now
post #7 of 15 Old 04-09-2012, 08:41 AM
wyen78's Avatar
accessories4less.com has refurbished receivers and they are authorized dealers. They have denon, marantz, onkyo, you should be able to find a good receiver at a good price there.
wyen78 is offline
post #8 of 15 Old 04-09-2012, 08:59 AM
afrogt's Avatar
Liked: 755
If you only need a stereo receiver then there are a few available at AC4Less under $200.
http://www.accessories4less.com/make...ceivers/1.html
Afro GT
post #9 of 15 Old 04-09-2012, 09:55 AM
buzzy_'s Avatar
Quoted: 66 Post(s)
Liked: 89
NewEgg regularly has deals on new Yamahas and Pioneers (so they include the warranty) that are being replaced by newer models. They're not absolutely up to date but they have a lot of features that may turn out to be useful. Eg, HDMI, iPod connections, subwoofer management. For example:
Pioneer VSX 821 $180 shipped
If you're only using two channels you might actually get the rated power - usually the power supply is the limiting factor.
"Similar items" at NewEgg
NewEgg is an excellent vendor.
Or Denon 1312 at Amazon, $175
buzzy_ is offline
post #10 of 15 Old 04-09-2012, 09:59 AM
cel4145's Avatar
Liked: 2987
+1
If you definitely want a 2 channel receiver instead of an AVR, there are also Denon and Onkyo 2 channel receivers in your budget range at accessories4less. If you want new, you should up your budget a little for the HK 3390 or Onkyo TX-8050.
cel4145 is offline
post #11 of 15 Old 04-09-2012, 10:31 AM
buzzy_'s Avatar
Quoted: 66 Post(s)
Liked: 89
mickyd98, don't assume that just because someone has posted a comment, that they've actually read your post, or thought about your needs. Much of the time, the comments here are what the person posting would buy, for their own needs and budget, or what was discussed the last time a question sorta like this came up.
In particular, this forum is flooded with "Raise your budget and get a _______" posts with no explanation of why that meets the needs of the person who asked the question, or even what the benefit might be (if any).
buzzy_ is offline
post #12 of 15 Old 04-09-2012, 11:50 AM
cel4145's Avatar
Liked: 2987
Since I'm the only one who suggested upping his budget, I would assume you are talking about me but either are (a) too shy to respond directly, (b) feel inarticulate at the moment, or (c) speaking generalizations when you have no direct feedback to offer on the recommendation.
Your first assumption would be wrong if you'd read the thread carefully. My first post in the thread indicated that I was aware of his needs. Plus, the difference in budget is not dramatic, especially considering the speakers he is going with come in significantly under his budget for that. But it's up to him to decide.
Now, the OP did mention an integrated amp. Since quality integrated amps that people would normally recommend to go along with the RC-10s are way outside his budget range, one alternative is 2 channel stereo receivers. In fact, we don't even know from his post whether or not he is interested in AVRs at all.
Granted, the HK receivers and that Onkyo are very highly recommended in general on the 2 channel audio forum on AVS. However, you would be wrong in your assumptions again. I tested the HK 3390 against 2 AVRs in the $175 to $250 range, as well as against an older HK AVR and vintage Denon integrate amp (devices I own) with RC-10s (I'm listening to the RC-10s and the HK 3390 right now) before purchasing the 3390. As for the Onkyo TX-8050, there is another user on this forum whose opinion I greatly respect who has commented on it very positively repeatedly.
Finally, with any purchasing recommendation here on AVS, there comes the assumption from most posters that the OP will do their due diligence on research. I'm sure mickyd98 would read up on those receivers and ask questions if he was interested, and of course he is under no obligation to consider them at all. It's free advice here. Take it or leave it. Although advice like yours is even less helpful
cel4145 is offline
post #13 of 15 Old 04-09-2012, 01:57 PM
Macstatic's Avatar
Wow, the fact that you took the time or space in this thread to actually write that... Everyone knows (or should know) that people's suggestions will always be slightly biased and to pull the good advice from each person's post to help.
@mickyd98, as far as the RC-10s go, I have a pair in a music only 2.1 setup. It's possible that you could find a good used stereo receiver in your area on craigslist. This might give you a little more of a budget for a small subwoofer. Or do it the other way around and get a new/refurbished receiver and buy a cheaper subwoofer to handle the lower end. The RC-10s are great alone, but with a subwoofer there isn't ANYTHING to complain about on frequency response.
For those looking into getting Energy speakers, or upgrading their current Energy setup, here are some reviews I've written that may help:http://www.tempestaudio.blogspot.com  (haven't updated in a while, but include Energy Take Classic 5.1, RC-10, CF-70, and CC-10)
Macstatic is offline
post #14 of 15 Old 04-16-2012, 05:03 AM - Thread Starter
mickyd98's Avatar
Thanks for all the replies and suggestions, one last thing, im a Bit new to all this so please bare with me. I would just like to know if i ran a 2.1 setup with a cd player what size amp would I need in terms of overall power output, i am not in a position to by a sub aswell at the moment but i definitely Will purchase one eventually. Thanks in advance.
mickyd98 is offline
post #15 of 15 Old 04-16-2012, 09:44 AM
cel4145's Avatar
Liked: 2987
This might help. Read the AVS Amplifier FAQ.
cel4145 is offline
Reply Speakers
