In ceiling speakers and insulation - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 04-11-2012, 09:45 AM - Thread Starter
dissfigured's Avatar
I am using monoprice in ceiling and in wall speakers.
Obviously the backs of the speakers are exposed so to speak.
Do I need to do anything to keep the insulation off the speaker?
Any sort of risk of fire there?
I know there is very little electricity there but just curious.
I am installing in the ceiling which just has attic space above it but there is insulation laying on the ceiling. It s that insulation with cotton candy looking junk that has paper on both sides.
I did this in my last house for 3 yrs w/ no problem but I am thinking things through a bit more this time.
dissfigured is offline
post #2 of 2 Old 04-11-2012, 10:06 AM
pureiso's Avatar
Fiberglass insulation is completely safe for speakers, it is commonly used in enclosures. Personally I would remove the paper, and then you should be good.
pureiso is offline
Reply Speakers
