Pioneer CS-88A issues - AVS Forum | Home Theater Discussions And Reviews
Old 04-11-2012, 03:46 PM - Thread Starter
mystery123's Avatar
Got a pair of used Pioneer CS-88A speakers but it has few issues.
1. Tweeter surrounds are rotted but do work.
2. Horn tweeters do not have any sound. Is there a good way to test them?
3. Mid drivers in one speaker do not work on "Increase" position but work on "Normal" and "Decrease" positions. I think I can fix that after cleaning or resoldering inside.
4. There are quite few water rings and marks on the top of the cabinets.
Can I use some stain over them without sanding to make them look good?
Thanks for suggestions.
mystery123 is offline
