Paradigm Studio CC590-too big??? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 04-11-2012, 07:35 PM - Thread Starter
sfeldman721's Avatar
Room is only 12 x 14. Will be using Studio 60's for front and Studio 10's for surrounds. Is the 590 too much for that size room. The Studio 60's have 2 5 1/2 inch mid/bass drivers and the center is using 2 7inch bass drivers. The 490 uses the same size bass drivers as the studio 60's. Of course the mid driver on the 490 is 3 1/2 inches versus 4 1/2 inches on the 590. In a few years the whole setup will be going to a larger room so that is why I am leaning towards the 590, but not if it's going to overwhelm the other speakers or the small room it is going to be in currently. Knowledge and advice needed..PLEASE!
sfeldman721 is offline
post #2 of 2 Old 04-11-2012, 07:43 PM
callas01's Avatar
Quoted: 956 Post(s)
Liked: 584
you'll be fine with the 590, depending on how big the new room will be, it might be a good thing to get the 690.
Dynaudio Focus 260s, Focus 210C, DM 2/6, Hsu VTF3 MK5 HP, Oppo BDP-103, NaimUniti 2, Naim Stageline N, Pro-ject 2xperience Classic, Marantz SR7007, 60" 4K Samsung LED LCD
callas01 is offline
Reply Speakers
