Looking for Bookshelf speakers for 2-channel music only. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 04-23-2012, 10:33 PM - Thread Starter
AdamITR's Avatar
I had a pair of B&W 685's, but honestly I did not care for them. Can anyone suggest some speakers ... this time budget is under $400 pair. I will be using a Klipsch SW-110 powered sub. They will be on speaker stands also.
Side note: I have a pair of the Pioneer SP-BS21-LR speakers, and they actually sound pretty good, but I think I can do better.
Any suggestions would be great!
Setup:
Luxman R-117 - 160w/8ohms
Firestone DAC/Mac Mini/iTunes
AdamITR is offline
post #2 of 8 Old 04-23-2012, 10:49 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
NHT
http://www.ebay.com/itm/320893798205...84.m1438.l2649
KEF
http://www.ebay.com/itm/KEF-Q300BL-B...item43af2e84a9
PSB
http://www.ebay.com/itm/Used-Pair-of...item4d005c682b
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #3 of 8 Old 04-23-2012, 11:00 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
afrogt is offline
post #4 of 8 Old 04-23-2012, 11:57 PM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 521
I suggest that you consider the PSB Image B6 speakers and the KEF iQ30 speakers.
The iQ30 speakers were $600, but KEF Direct currently has them for $399, which is quite a deal.
Saturday Audio has the Image B6 for $439/pair (down from $550).
The Wharfdale Diamond 10.1 is another very good one ($349).
Setup:
commsysman is offline
post #5 of 8 Old 04-24-2012, 09:21 AM - Thread Starter
AdamITR's Avatar
AdamITR is offline
post #6 of 8 Old 04-24-2012, 09:34 AM
Veda's Avatar
Quoted: 124 Post(s)
Liked: 89
Based on the fact that you don't like B&W, I assume you're looking for something more accurate which means the Ascend, PSB, and KEF are most suitable for the sound you're looking for.
Veda is offline
post #7 of 8 Old 04-24-2012, 09:36 AM - Thread Starter
AdamITR's Avatar
Exactly! Well said.
I wonder how the Pioneer SP-BS41-LR would sound (I know they are cheaper)? They seem to get good ratings.
AdamITR is offline
post #8 of 8 Old 04-24-2012, 09:53 AM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Exactly! Well said.
The will mainly be lacking in the resolution department - and the
highs will sound rolled off.
Who AM I
zieglj01 is offline
Reply Speakers
